Thread Tools
Old 8th July 2008, 13:58   #31 (permalink)
navin's Avatar
Originally Posted by headers View Post
Ok sir, agreed. But if only one channel is connected to drive the sub as advised. I should not theoretically fry the HU!
no you wont but your sub will not be used fully.
Originally Posted by greenhorn View Post
Personally, I've never had issues driving speakers with underpowered amps[Driven or Elegant for this installation
actually this is more true forspeaker systems involving tweeters. an amp that clips will produce a lot of HF energy (square wave) and this energy will damage the tweeter.
__________________
Scixelsyd Etinu
Old 8th July 2008, 14:04   #32 (permalink)
redfire's Avatar
I am not a guru but have experienced this, even with well matched amps/speakers. A good quality amp though underpowered may play OK if you are very carefull with volume control. Gradually increasing the volume level and setting it to a moderate level before clipping may work and the setup may run for short/long according to the quality of components. But things will go kaput when a sudden volume level increase/something like that occurs. Last week I had to change two fuses in my home amp (100W RMS @ 8 ohms connected to matching speakers) because of my son who turned the volume control to 80% and I switched on the amp without noticing this. But I have turned the volume to 80% gradually without any problem (even he used to do it, then will get frightened by the volume/punch, cry and run to his mom ).
__________________
jay
Most automobiles problems are caused by the loose nut that connects the steering to the saddle
redfire is offline   Reply With Quote
Old 8th July 2008, 14:30   #33 (permalink)
navin's Avatar
What you are experiencing is a blown fuse (atleast that is what should happen) not a blown amp.
__________________
Scixelsyd Etinu
Old 8th July 2008, 14:39   #34 (permalink)
redfire's Avatar
Yes Navin Ji, luckily I faced only a blown fuse. But as a whole, the equipment is blown and not playing (in layman's view) and it could be some other components if not fuse next time. Hope it never happens.
__________________
jay
Old 8th July 2008, 15:29   #35 (permalink)
anujmishra's Avatar
Default Separate SUB output
In my Sony HU I can see there are 4 channel normal output plus one sub output. In settings, I can see in the SUB setup that can be set in dB from 0 dB to 10 dB.
What, if I try to connect SUB without amplifier in dedicated SUB output of HU ?
If it is not recomended, then why Sony has provided separate SUB output in HU?
__________________
Anuj Mishra
Luck will do for skill, but not consistently...
anujmishra is offline   Reply With Quote
Old 8th July 2008, 15:32   #36 (permalink)
DerAlte's Avatar
Must have been a Fast-blow fuse (thin copper wire). Replace it with a Slow-blow fuse of the same rating. This will not blow on a surge current, yet protect the amp in continuous overload conditions, like lower than designed speaker impedance etc. This used to be a common problem with old CRT TVs - surge current while switching on (early Sunday morning auntie-ji comes running: "Beta, jaldi se kuchh kar de, Mahabharat / Ramayan miss ho jayega").
Your "rotating the knob in a flick" will do the same: produce a surge current. This will, as Navin explained, only blow the fuse by not fry the amp.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 8th July 2008, 15:35   #37 (permalink)
greenhorn's Avatar
[A bit OT ] just a doubt. What if the amp had to reproduce a transient of the same magnitude ? will the fuse blow then also ?
__________________
2007 Indica DLG
My next Truck will be a Safari!
Old 8th July 2008, 19:15   #38 (permalink)
DerAlte's Avatar
Depends on magnitude and duration of transient! The fuse blowing characteristic is a time-current relationship, so higher the current for a short duration, the faster it will blow.
__________________
Old 9th July 2008, 01:10   #39 (permalink)
yup, that was one way to get surround out of a 2 channel amp in the ye olde days. however , to get the difference signal, you need to connect the + and - of the speakers to either both the +'s of the amp, or both the -'s.
a good idea would be to connect the Right surround speakers + to the left channel +, and the speakers - to the right channel +
the Left surround's + can be connected to the left channel's - , and the speakers - to the right channel's minus ( I'm not entirely sure about the polarities, but i think this should work) And since equal currents will be drawn from all terminals , it should balance everything out .
in a car HU, the amp's ground (0V) terminals are not acessible , only the + and - are ....
Connecting a speakers to both the +'s or both the -'s should not be an issue , since there wont be a lot of current flowing , only the difference.
I only objected to shorting the + and - of the HU. everything else is fine
PS: I didnt get the ridicule bit. Have we ridiculed anyone ?
a bad automotive analogy would be to claim that if you drive around with your handbrake on , the tyres wont be damaged because you are driving slowly or because the engine is underpowered.
no matter how little current you supply, a shorted output is a shorted output ,and will eventually fry your IC's
Thanks for the green signal.
and the ridicule was not for you but for those who try to make the blog more interesting.
raajsree is offline   Reply With Quote
Old 9th July 2008, 01:51   #40 (permalink)
Hmm, An Indigo One ton transport vehicle then a Sub with no Amp.
Someones really into destructive testing. But if it works - What the heck?!
Way to go Vikram. BTW I no see ,one Nitrous on this thread. How come? I thought you to go hand in hand in all threads. Fighting....
godseed1670 is offline   Reply With Quote
Old 9th July 2008, 09:27   #41 (permalink)
headers's Avatar
OT: Sir, thank you for actually coming online and browsing through the forum. You have improved!
BTW, what is destructive testing?
I am just exploring the limits! Thanks to you know who!
__________________
Walk the Talk..Always!
Old 23rd July 2008, 17:36   #42 (permalink)
+1 i also have a similar output on my 7950.. What that output for?
kalpik is offline   Reply With Quote
Old 23rd July 2008, 18:39   #43 (permalink)
esteem_lover's Avatar
Infractions: 0/1 (5)
haa! godseed, how is the seeding season this year ? Need any help to lug around your seeds, you know who to call.
Is there any limits left to explore ?
Sorry for going offtopic.
__________________
Goodbye Dada, you made us proud.
esteem_lover is online now   Reply With Quote
Old 23rd July 2008, 18:45   #44 (permalink)
greenhorn's Avatar
to drive subs , maybe smaller ones. and definitely not in bridged mode
__________________
2007 Indica DLG
Old 23rd July 2008, 20:06   #45 (permalink)
Smaller subs ?
Any examples ? Can I hook in my creative PC sub ?
nitin.dangayach is offline   Reply With Quote
Thread Tools
SubWoofer and Amplifier query - 8K Budget nitin.dangayach Ask the Gurus 65 18th September 2008 10:51
Help in selecting Amplifier and Subwoofer for my Wagon-R ravi@64bhp Ask the Gurus 37 28th June 2008 21:40
Which Subwoofer and Amplifier ramie2400 Ask the Gurus 40 4th January 2008 10:51
Blaupunkt Subwoofer and Kenwood Amplifier for sale general_neo Shifting gears 7 25th December 2005 13:32
best subwoofer-amplifier combination for Rs.10-15k nitrous Ask the Gurus 14 1st November 2004 13:21
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
