Thread Tools
Old 16th July 2008, 13:12   #1 (permalink)
Forged_Piston's Avatar
Default Upgrade to double bass for zen.
Hey everyone,
I was thinking of upgrading the present ICE in my zen.
I currently have the folowing installed.
JBL GTO 4000 600 watts amp.
JBL GTO 12" 300 watts sub.
JBL GTO 17t tweets.
JBL GTO 937 coxial.
HU-Got ROBBED (Actually was a piece of junk anyways.Imagine his surprise when he tries to sell it somewhere and the darn thing does not power up.hehe)
Have pretty much narrowed down on the following upgrades.
HU-any mp3 player will do as long it has 3 pre amps.(Suggestions!!)
Another 12" 300 watts sub.
Components upfront (Not decided yet)
Monoblock (most probably a GTO 601).
Few questions here.
1.The gto 4000 has only 1 bridged outlet.Is it possible to power 2 300 watt subs through this amp?so then i would just buy a 2 ch amp to power the compos and the coaxials would run off the HU.
2.What would be the aproximate price of a 600 watt monoblock in mumbai?
3.Any other steup i could use.
Any suggestions would be really appreciated.
Oh almost forgot..Approxiamte budget:- lower the better but somewhere around 20g's.
__________________
After all is said and done, usually more is said than done
Forged_Piston is online now   Reply With Quote
Old 16th July 2008, 14:34   #2 (permalink)
And 20 is excluding the HU
__________________
Old 16th July 2008, 17:36   #3 (permalink)
speedzak's Avatar
Location: Delhi. Travelling as usual! Mumbai was great.
Infractions: 0/1 (4)
Hi, hello and welcome to the wicked section of Team-bhp.
Any HU which can play MP3s but should have 3pre outs?
I suggest you get a Pioneer 4050. If you want to go a bit more high, then the 6050.
Get the same GTO 12" sub as you have now. It will match your current bass and output.
Run both the subs in parallel/series from the monoblock amp. Don't use your old amp for this.
Get some good components. You can choose from the vast range of JBLs, Illusion Audio, Rainbow, Bull Audio, Hertz etc..
Keep the current coaxials where it is if you want to.
Power the speakers from the old amp. Some fine tuning at the amp and HU will get your setup rocking. Make sure to get more power to the front comps rather than the rear coaxs.
Get in touch with our in house Gurus from Mumbai like B&T, Sam, Ramie etc.. For any assistance.
__________________
A very big THANK YOU, Bombay!
Will miss you guys! :(
speedzak is online now   Reply With Quote
Old 16th July 2008, 18:14   #4 (permalink)
jkdas's Avatar
4000 pumps out only 150W in bridged more. Will suggest a mono.
Old 16th July 2008, 23:31   #5 (permalink)
greenhorn's Avatar
that was one stupid thief. all these ICE goodies and the thief nicked the HU ... you are lucky
__________________
2007 Indica DLG
My next Truck will be a Safari!
Old 17th July 2008, 15:02   #6 (permalink)
Ya, i know.Not taking any chances though.Had to disconnect the autocop at that time since the already weak battery was getting drained in a days time.Not gonna happen again.
__________________
Old 17th July 2008, 15:24   #7 (permalink)
Sam Kapasi's Avatar
Since you have already decided on JBL, I will merely help you with you model choices.
GTO601 has been disconned. I would recommend the GTO7001 in its place. This was the monoblock in the Suzuki swift Evil twins.
The MRP of the 7001 is 20K
Any good true 600W mono amplifier would be in that price range.
Incorrect. The GTO4000 was a 4 channel amplifier and you could have 2 bridged outputs from this amplifier. It may be possible to run two subwoofers off this amplifier but do not compare the result to a GTO7001.
If the 7001 is above your budget (which I suspect) and you are still looking for options in JBL - you have the GTO3501(13K) and the GT5-A3001(10K) but the 3001 in not sufficient to drive 2 powerful woofers (still better than using the GTO4000)
Instead of buying a small 2 channel amplifier, i would rather you would save up and buy a good monoblock and use you existing 4 channel amplifier to drive your speakers.
__________________
Live the YetiLife®
Old 18th July 2008, 13:17   #8 (permalink)
People Thank you for all the advise.
But..
Ive been reading some threads on the site and was just wondering, even if i do upgrade to the 7001 will the battery be able to provide enough juice to power the 2 amps without any -ve reprecussions on either the battery or the amps.
I've got an Bosch battery which is about 6 mths old.(am totally happy with it till now.good quality)
Also suggestions for the layout would be appreciated.(dont care about boot space since the car is just used by me and my dog)
__________________
Old 18th July 2008, 16:40   #9 (permalink)
Bass&Trouble's Avatar
As long as you dont use the system without the engine running, there wont be any problems. With any high power system, the battery's life is however always shortened.
__________________
Operator! Give me the number for 911!
Bass&Trouble is online now   Reply With Quote
Old 18th July 2008, 17:54   #10 (permalink)
You mean battery life will shorten even if we use only when engine is running.
mohang_j is offline   Reply With Quote
Old 18th July 2008, 18:27   #11 (permalink)
Ok. I went to check out prices and other alternatives for the stuff mentioned above.Took a couple of friends along with me.They think ive gone mad and think what i want is way OTT.They said im out to blow up my zen.
I asked them to piss off.
Just to prove to them wrong could some of you please answer this question.
On a scale of 1-10(10 being the most OTT ice uve seen till date), How much would you rate what i currently have and what i intend to add.
Please guys help a fellow music lover prove these fools wrong..
__________________
Old 18th July 2008, 20:15   #12 (permalink)
cooldude1988765's Avatar
OTT varies from person to person what is OTT for me may just suffice for you. What you want is what "you" want as long as you are happy who cares what the others think.
I would not call any install OTT.
__________________
I never thought it was humanly possible, but this both sucks and blows.
- Bart Simpson
cooldude1988765 is offline   Reply With Quote
Old 19th July 2008, 13:03   #13 (permalink)
speedzak's Avatar
If you're going to follow this thread with some serious questions and take good advice from here, then I'm sure you'll end up with one of the best ICE systems you and your friends have ever seen/heard of.
Don't worry about the OTT thingws. It will always come and go!
__________________
Old 19th July 2008, 13:16   #14 (permalink)
hydrashok's Avatar
Agree with zak & cooldude. Don't worry about your setup being OTT. Nothing ever is OTT till *you* feel so.
It would be nice if you could get component speakers in the front though. Just a pair of tweets won't let you enjoy the music.
After you finish you setup, feed your friends to the evil Zen's backseat at 90% volume. Make sure you lock the doors, roll-up the windows and keep the child-lock on.
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 22nd July 2008, 13:28   #15 (permalink)
Thank you for the responses.
I had another question though,Is it possible to connect my Ipod directly to the amp using a two pin cable(the kind you use to connect your home dvd player to the amp or whatever). i tried doing this but the amp does not power up(the power lamp does not come on).I also checked all the fuses and every thing seems to be in order.
I asked a couple of car accessories shops and they said that it cant be done.and that i needed a hu to power up the amp.
I could not understand the logic behind this as the amp is directly connected to the battery and the only connection the HU has with the amp is the two wires connecting the preamp 'out' to the 'in' plugs on the amp.
Is it possible to power up the amp without a HU?
__________________
Thread Tools
Suspension Upgrade on Zen Handling nice blueraven316 Modifications & Accessories 11 15th August 2008 18:57
Zen tyre upgrade revvedup Tyre & Alloy wheel Section 29 10th March 2008 16:06
ZEN 99 - Looks & minor performance upgrade krish82 Modifications & Accessories 1 24th April 2007 18:46
Audio upgrade in a Zen DeepTrouble Ask the Gurus 15 15th January 2006 15:41
Need Help To Upgrade Zen Music Sys... greddy Ask the Gurus 1 29th April 2005 14:53
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
