Thread Tools
Old 19th July 2008, 21:59   #1 (permalink)
Default Help me find a powered subwoofer in budget.
Well I have bought few stuff for my Alto as mentioned in the following thread:
http://www.team-bhp.com/forum/sound-...bought-us.html (ICE components for my ALTO, bought from the US)
The primary constraint is Space. Since Alto is already cramped, I did not want to add any external subwoofer but now I am feeling that I'll miss a little more than a lot :P by not getting a SW.
Now that I am little inclined on getting a SW, I am bugged by another constraint.
The newer constraint is that I do not want to add in any amplifier and do want myself to be puzzled with that unnecessary hassles of getting a good enclosure, great cables.
All I want is a powered woofer assembly which is as small as possible. The rationale behind this is I should be able to chuck it out of the car, whenever I need the boot space.
I saw one install in a WAGON R, as posted by a fellow friend but then again he is using an AMP which i do not want to use.
Secondly i am tight on budget. I can spare 5-7000 max. Since I do not need a loud mouth stuff, anything that can produce that little sub 100Hz range, at moderate levels will be good for me. My 5K Creative 5.1 does that job good so i have a notion that I might get something similar in my modest budget.
If that is good for the purpose, I'll get one else I will be contented with the current set up.
Input guys !!!
nitin.dangayach is offline   Reply With Quote
Old 19th July 2008, 22:07   #2 (permalink)
amit_mechengg's Avatar
for a budget purpose and an inbuilt amp all i can suggest is chinese brands which are decent enough.
try for SUMUKO and CHICAGO, anything between 5-9 k.
__________________
" I dont Drive Fast , I Fly Slowly "
amit_mechengg is online now   Reply With Quote
Old 19th July 2008, 22:19   #3 (permalink)
Can you help me with some link ? I am in gurgaon and can get the things from Chandigarh as well.
Old 19th July 2008, 22:42   #4 (permalink)
rider60's Avatar
the best i can suggest is please get an amp and a sub which is very much possible in that budget for sure, a sub without a amp and powering it directly off the HU will fry it.
you can get a 2 channel sony amp and a pio 10" or 12"/ jbl 10" sub in that range which can be conveniently tucked away under the seats.
rider60 is offline   Reply With Quote
Old 19th July 2008, 22:53   #5 (permalink)
greenhorn's Avatar
rear 6x9's and a solid rear parcel shelf can give you enough bass, about as much as that creative sub of yours
__________________
2007 Indica DLG
My next Truck will be a Safari!
Old 19th July 2008, 23:02   #6 (permalink)
muneemmk's Avatar
A Polk 8" Sub with a Sony Amp will set u back by about 7K Maximum including Installation Charges. I Suggested the 8" Polk Because the Recommended Volume for the Enclosure is only 12 Liters !! Which can be tucked away under the seat i guess.Guess Your Car will be Totally "Polkified" Then.
I Suggested the Sony because it's the cheapest, A JBL Would do justice to the Polks .I would suggest a 4 channel as well to drive the 6 X 9 Maybe but it's over your Budget, Be sure to go through the classfieds of Teambhp to see weather any 4 channels are avilable for the price.
__________________
Will Hench For Petrol.........
muneemmk is offline   Reply With Quote
Old 20th July 2008, 13:00   #7 (permalink)
Mr. boombastic's Avatar
Default Dub
Hey Nitin,
IIRC DUB has a 8" powered sub with an inbuilt amplifier which i feel should siut ur need, contact B&T for details. Its small enough to fit in an alto boot and since it has an inbuilt amp it would lessen the clutter as opposed to adding an amp to the back of ur seat...
__________________
Cars make CO2 and trees absorb CO2. By driving your car you're feeding a tree and helping the environment.
Mr. boombastic is offline   Reply With Quote
Old 20th July 2008, 13:14   #8 (permalink)
if you are ready to install a separate amp then i would suggest u either sony/kenwood 2 channel amp ~ 3000 rs and JBL 1000/1100 watts sub ~ 3000 and wiring kit ~1000 rs . but mind it you wont be able to get the full potential from these subs with a basic amp.
__________________
Old 20th July 2008, 13:31   #9 (permalink)
Iam totally confused now. I am not sure if i will buy an amp. It will defeat my purpose.
As pointed by greenhorn, I think i should first see how the polks work in the current configuration.
Thanks for the comments guys.
Old 20th July 2008, 21:14   #10 (permalink)
hydrashok's Avatar
Nearly every compact Active Sub solution I've seen (Infinity BassLink, Kenwood w00x, Blau THb 210A or 200A, Pioneer PUMP etc) come at a minimum of 12-15K (I think the Blau 200A is 9K, but I'm not totally sure).
You might be able to find a Blau THb210A or a 200A at the nearest Blau showroom. They are pretty compact and will fit under most front seats. I don't think any of the other options are available with B&W (and they may not be easily available either - The Infinity is not sold in India officially & the w00x is out of production last I heard).
At any price point above 6-7K, I think an amp+sub combi will give 100% better bass.
As the others have pointed out, your best option at 7K may be a pair of 6x9s.
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 20th July 2008, 22:38   #11 (permalink)
Thanks for the input buddy. I guess its better to get an amp and a sw. But I have procrastinated the idea for stage2.
Also as mentioned in the first post, I already have polk audio 6x9 inchers. Let us see how they fare.
Old 20th July 2008, 23:17   #12 (permalink)
navin's Avatar
Originally Posted by muneemmk View Post
A Polk 8" Sub with a Sony Amp will set u back by about 7K.
Nearly every compact Active Sub solution I've seen come at a minimum of 12-15K..You might be able to find a Blau THb210A or a 200A at the nearest Blau showroom.
what you are looking for is to augment the bass of the Polk 6x9s you have now.
lets take this in stages.
get a sony 2 ch. amp (under Rs 3K) and use it to drive the 6x9s. sometimes this might be all you need.
If this does not work you will need atleast a 10" sub (think Pio 252 etc..) which sell for about 4K. an 8" wont give you much more than the 2 6x9s already do.
__________________
Scixelsyd Etinu
Thread Tools
Budget Subwoofer(<12k) for Home theater kaushik_s Gadgets, Computers & Software 10 19th October 2008 03:13
SubWoofer and Amplifier query - 8K Budget nitin.dangayach Ask the Gurus 65 18th September 2008 10:51
AMG powered SL 63 ac 427 Super-Cars & Imports in India 17 26th January 2008 01:33
Looking for a hi-powered monoblock jyobeb Shifting gears 9 20th December 2007 17:51
Can a subwoofer be powered directly off a Head unit? Rtech Ask the Gurus 10 10th August 2007 12:57
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
