| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Sep 2007 Location: Pune
| The manual of my Maruti Alto specifies some specific car audio system models as part of accessories. It is necessary that one should only go for one of those specified models or even any other models/brand can also be fitted as Car Audio system. Thanks, |
| | #2 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| There is no reason why other models/brands cannot be fitted. The word should be "recommends", not "specifies". While they may have a preference for certain brands as a part of their MGS program, there is no law or contractual obligation against fitting other brands. There is a small link, though. MUL provides most of the standard wiring as a part of the harness of the car. An adapter has to be used to adapt the standard wire terminations to the specific HU brand/model. Most neighborhood installers, when installing ICE, tend to use the "cut / strip / twist / insulate" method instead of using the adapter, which may compromise the insulation integrity and cause problems.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #3 (permalink) |
| Thanks for your response. I come across this statement in the warranty Limitations clause in the Alto manual that, the warranty shall not apply to ‘any vehicle on which parts or accessories not approved by Maruti have been used. Am not sure how to interpret this..your expert opinion would be great. Thanks. |
| | #4 (permalink) |
| For that you would need to consult a legal resource, not "expert opinion". The warranty clause is generic and open-ended, though! The open questions are: * For how long is the warranty valid? * Will a user installed accessory not contribute to problems as long as the warranty is not valid? * Will MUL supply a list of "accessories approved by Maruti" (outside of MGS, which is not fair commercial practice)? * Which parts of the car are covered by the "warranty"? * Which circumstances lead a customer resort to claiming "warranty"? * What happens when a Maruti-approved "accessory" component falls far below your expectation of quality and functionality? * Will wiring ICE components to the defined interface points (+12V after fuse, ground, antenna, speakers, etc. etc.) of the Maruti-supplied wiring harness cause malfunction of the car? If the wiring is done by a person not having proper knowledge of such interface points, there is always a likelihood of problems of all kinds, whether the MUL warranty is valid or not. It will be interesting to know MUL's stand if a MUL-approved accessory malfunctions to cause functional failure of the car - surely they will point you to the accessory supplier instead of MUL taking responsibility of the warranty. ![]()
« Woofer from a computer sound system possible in a car audio setup?
need advice: 20gb ipod (4G) compatible car stereos? »
| Thread Tools | |
Similar Threads | ||||
| BlueTooth Car Audio System + Security System | venky6009 | Ask the Gurus | 1 | 2nd November 2007 05:45 |
| Suggestion for new car Audio System | jinu_joseph | Ask the Gurus | 358 | 25th September 2006 22:53 |
| Best Car Audio System under 16k | nishantv2003 | Ask the Gurus | 38 | 12th July 2006 22:38 |
| Best Car Audio System In India? | racing4cure | Ask the Gurus | 19 | 23rd December 2005 17:40 |
| Help needed for my new car audio system | vinnick_2000 | Ask the Gurus | 4 | 9th September 2004 23:25 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
