| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Aug 2008 Location: faridabad
| i just bought a new honda city gxi model and decided to go in with the following config. 1. head unit : did no changes with it ,i am using the company fitted HU alpine (CDE-9871EHI) 2. JBL 637 at the back 3. JBL 607 component speakers at the front 4. KENWOOD KAC-8401 (4-channel amp) i got everything installed from a reputed shop in delhi (DRIVEN) but still i am not happy with the sound quality. The clarity is good but somehow i feel that the treble is way too high while there is no bass atall . What should i do to get that thump which is missing. I spoke to a friend of mine who suggested me to go in for a JBL bass tube but i am confused . One more thing do i need to change my head unit or should i stick with this one . Looking forward to the replies of all the GURUS pls help!!!! |
| | #2 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Did you come away from Driven without getting your setup tuned to your taste? You must have been in a tearing hurry to give up on that important part!
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #3 (permalink) |
| it was getting really late i had already spent 6 hrs there and to be really frank i wasnt happy with the installation ..the installer actually damaged my dash board which is why i was really frustrated ...and Mr. rana had tried his level best to tune the system but in vain he could not ...i know even i am at fault but somehow i want to set thngs right now is the config fine ...should i go in for the gto 937 at the back , should i change my head unit ,install a bass tube or tuning of the system will solve my problem ???? Last edited by aah78 : 7th August 2008 at 23:03. Reason: Posts merged. |
| | #4 (permalink) |
| Newbie Join Date: Jul 2008 Location: coorg
| u can try this set your equalizer option to custom setting ,and in custom setting try adjusting the frequency controls one by one it might work . gurus, correct if i am wrong
__________________ when u drift u feel the rush |
| | #5 (permalink) |
| Distinguished - BHPian ![]() | Since you claim that the install was bad, you must check to see if the phasing of the speakers is correct. If the phase is wrong, all the bass will will cancelled, leaving the higher frequencies. If you do not want to go back to Driven, here is what I suggest. Put the fader completely to the rear. Now go to the balance control. Go completely left, then centre, then completely right. When in the centre, the bass should be highest. It should reduce as you either go left, or right. If the bass seems LEAST when you are in the centre, the phase is incorrect. Now go to the boot of the car and reverse ONE speaker wire only. Just ONE, not both. Reverse the wire. Put the red to the black and black to the red. Then go back into the car and see if the bass has improved. Let us know.
__________________ Live the YetiLife® |
| | #8 (permalink) |
| thanks sam ill try what you suggested and see if it works .....gunbir sir i have heard a lot about you if things still dont get any better then it would be very nice of you if i could meet you somewhere and have the problem rectified |
| | #11 (permalink) |
| sam , i tried what you said and there is a very funny thing i noticed i put the fader compeletely to the rear but there was hardly any change in the sound and then comes the funny part when i put the balace compeletely to the right my (right front speaker was working) and when i put the balance compeletly to the left my (left rear speaker was working) how is that possible |
| | #12 (permalink) |
| BHPian Join Date: Aug 2008 Location: Bangalore
| try this go to the boot and on the amp shut off both the cut off frequencies you would only need the filters IF you bought a sub and a separate amp. second there is a lil knob there that lets you control the bass boost. turn it up just a little. now all this time you have to keep your volume constant to the level you listen to. also the head has to be on flat eq and no bass mid or treble boost. now once you feel you are getting sufficient punch from the speakers close boot and fiddle with the eq. that should do the trick. but as a suggestion try putting in 6x9 in the back say a 3-way or a 4-way set. if you do want to kill your wallet you could pick up a new head which comes with 3 pre-outs thats sub, front and rear and then take up a sub and an amp. but thats just overkill if its only passive listening which is what im presuming you use it for. |
| | #13 (permalink) |
| Senior - BHPian Join Date: Sep 2005 Location: New Delhi
Infractions: 0/1 (4) | Nishant, I will be @ Driven sometime tomorrow evening. I would be glad to tune your setup... Do give the installer a chance to set your system right. Mistakes happen, give them a chance to correct it.
__________________ Often imitated, never duplicated! Last edited by gunbir : 8th August 2008 at 04:49. |
| | #14 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Your wiring is not done properly. The front/ rear outputs have been wrongly connected. You will have to check whether the RCAs are incorrectly plugged into the amp, or the speakers are connected to the wrong outputs.
__________________ Operator! Give me the number for 911! |
| | #15 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: Delhi. Travelling as usual! Mumbai was great.
Infractions: 0/1 (4) | Your wiring is wrong bro! Get in touch with the Installer itself. As you've paid him money, it becomes his responsibility to make you satisfied for what you've spent. Now, as Gunbir has agreed to look into your system, fix up a time and meet up at DRIVEN itself. You'll be very happy with the outcome I'm sure. Mr. Rana will also be happy that he hasn't harmed a customer's feelings. As you're in Free da bad, stay away from that mad Sardar who has one of the loudest setup in India. He will shake your car with his BAAASS and chew you down for lunch. The minimum effect one will inherit from his is a 15" hard pounder in a ported box. ![]() Jokes apart, your system needs an urgent attention. I would suggest you to add a 12" sub in a sealed box and power it from 2 bridged channels of your amp. The rear coaxials can be powered from the HU and the components can be powered from the 2channels of the amp. Do all these while Gunbir is around and under his supervision. But remember, he charges unlimited Kababs and Fosters in return I assume! LOL!
__________________ A very big THANK YOU, Bombay! Will miss you guys! :( |
| Thread Tools | |
Similar Threads | ||||
| Double-DIN head unit with excellent sound quality | theEnd | Ask the Gurus | 4 | 5th October 2008 03:28 |
| Which (ICE Component) will make the most difference in Sound Quality? | low_bass_makker | Ask the Gurus | 43 | 7th April 2008 11:00 |
| Vendor quote: "The key for good sound quality is the way its installed" | harmon_bro | Ask the Gurus | 36 | 26th March 2008 12:12 |
| Sound Quality not good on new ICE setup. Help! | maverickzCar | Ask the Gurus | 24 | 28th December 2007 15:15 |
| How to Improve the Ride Quality - | Ikhanna | Technical Stuff | 10 | 7th January 2007 00:03 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
