Thread Tools
Old 14th August 2008, 13:13   #1 (permalink)
RAC
Default Is this true - ICE affects 'onboard computer' in an mpfi cars
Hi
I was reading up on another thread about retrofitting AC in a car and I came upon this newspaper clip posted by another member about retrofitting AC's. There is a small query section at the right hand bottom about ICE affecting 'onboard computer' in an mpfi cars.
Is this really true. It is a worrysome statement.
Link to the other thread:
http://www.team-bhp.com/forum/modifi...-should-i.html (M800 : RetroFitted AC, Should I ?)
RAC is offline   Reply With Quote
Old 14th August 2008, 13:29   #2 (permalink)
NOTORIOUS's Avatar
i do not agree with this !!
__________________
Bajaj Pulsar 180 DTSI 22 oct 2008
Booked a Arctic White Swift VDI with ABS
Jaspreet Singh Rattan
NOTORIOUS is offline   Reply With Quote
Old 14th August 2008, 13:43   #3 (permalink)
ramie2400's Avatar
If the ICE would have affected "onboard computer" I am sure many of our fellow members cars including me would have gone kaput .... Lolz
__________________
Behind every successful student there is a girl...
But!!,what about unsuccessful student's like "US"??
...Lots of girls. :D
Old 14th August 2008, 13:45   #4 (permalink)
greenhorn's Avatar
Maybe if we put l_b_m ji's system in a maruti 800
__________________
2007 Indica DLG
My next Truck will be a Safari!
Old 14th August 2008, 14:12   #5 (permalink)
DerAlte's Avatar
All on-board computers use internal regulation for the (lower) voltages needed for the electronics - the input can vary from 9.x V to 16.x V without affecting functionality. Has anyone tried dhakka-start when the battery was too weak to turn the engine?
When the engine is running, the alternator keeps the +12V line voltage up and charges battery. Severe electrical loads put more mechanical loads on the engine, which one can feel in the reduction in performance of the car - not complete failure.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 14th August 2008, 14:16   #6 (permalink)
vid6639's Avatar
Someone else had faced a similar problem with their car:
https://www.team-bhp.com/forum/ask-g...eavy-bass.html
__________________
\ / ][ |) `/ [_] "!"
vid6639 is offline   Reply With Quote
Old 14th August 2008, 14:27   #7 (permalink)
low_bass_makker's Avatar
If MPFI cars and Woofer does not go along. Then I think the writer of the article deserves a BUTTER Chicken in the back seat with music at full blast.
Old 14th August 2008, 15:01   #8 (permalink)
tsk1979's Avatar
If your subwoofer is so powerful that it causes headlight dimming, its not very good for electronic components.
Its better to fix up your electrical system then.
Frequent fluctuations 2-3 times a second in the voltage, eg 9-14V is certainly not good for the ECU, but its not going to damage anything as car electronics are pretty solid and can take abuse. However running on low voltage can cause some errors in the CPU if it happens for a long time, so your engine may not be operating on optimum mixture etc.,
__________________
Reclaiming.....!
Old 14th August 2008, 15:03   #9 (permalink)
navin's Avatar
greenhorn you could stuff the 800's engine into the chassis of LBM's subs.
__________________
Scixelsyd Etinu
Old 14th August 2008, 15:12   #10 (permalink)
bhp
bhp's Avatar
I recently got a JBL Bass Tube and JBL 4 Channel Amp and the lights flicker all over the car as low as on 5 volume... the more the volume the more the flicker of interior lights and headlights taillights etc etc
the car is a swift D
between i have noticed this problem with all maruti cars ??? i have a baleno with a sub and 4 channel amp and face the same problem there too..
wat is a solution for this problem ?? upgrading to a higher voltage battery or live with the way it is
Are such problems harmful for the car ??
__________________
05 suzi baleno
07 city vtec
08 swift DDIS
Live Life in the Fast Lane "vvvrrrooooommmmmmmm"
bhp is offline   Reply With Quote
Old 14th August 2008, 15:15   #11 (permalink)
gunbir's Avatar
Infractions: 0/1 (4)
I was thinking, don't most microprocessors have a watchdog circuit that shuts down the microprocessor in case of irregular / low voltage? Is this not standard in all microprocessors?
__________________
Often imitated, never duplicated!
Old 14th August 2008, 15:37   #12 (permalink)
I tend to agree with Tanveer also. It is not recommend to play the ICE which has heavy load on the car electrical for long. As it will put undue load on the same. Thats why I monitor the voltage very closely while playing loud.
CPU normally run at very low voltage closer to 3 or 5 volts or even less. There is a reducer in there to first reduce it to such voltage and keep it stable. Since a little noise in it will corrupt the stuff up. And I seriously fear such low level are not achieved. Even if the voltage reaches this level the CPU will not shutdown it will crash.
Also the CPU in cars in not to HI-FI wala. It is a just more of a logic controller assigend to do fixed task in a closed or open circuit as per design.
Get your wiring checked bro the cars are not at fault here
Old 14th August 2008, 16:02   #13 (permalink)
, This runs on less-than or equal to 5V. This is kind of micro controller (pre programmed control chip) not a CPU. Regulators will take input upto 7.5 V (normally 2 V more than required output).
Its output logic is used to drive other motors controls (stepper motors & various pumps) which run on 12V. There you can get degraded performance if rpm of motor falls. This is also rare possibility as alternator can handle well both - charging battery & running all electronics stuff (excluding your subs of few kW).
omishra is offline   Reply With Quote
Old 14th August 2008, 16:13   #14 (permalink)
Also the car amps trips when voltage dips to 9 volts.
Old 14th August 2008, 16:16   #15 (permalink)
tsk1979's Avatar
Not all CPUs have watchdog ciruit. In most cases the design is closed to work in a particular range.
For example the nominal operating temperature may be 25 degree C, and the normal voltage 5V
However while design the chips are made such that they can be used around -5 to 50 degree temp.
Military grade hardware is designed for even higher ranges of temperature and voltage.
High Voltage will fry your chip, no two ways around that.
Low voltage will not damage anything, but the output your chip will give will not be accurate. So you may get 2+2=5 (Note, this is utter simplification of the problem).
Now what will a subwoofer do?
Suppose your ECU board has a voltage regulator which shuts down if voltage goes below a particular level. This means your engine will shut off or you may have some misfiring.
Infact when you push start a car with a dead battery, there is voltage and thats the reason most owners manuals of ECU equipped cars say that do not push start the car unless there is no other alternative.
So subwoofer low voltage can cause data corruption, and ECU can start giving wrong parameters and data to control devices. Not a good thing at all.
This thing is valid for all input variations. Temperature, Voltage and Clock frequency.
Suppose you overclock your ECU. Unless you dip the temperature, after a certain clock frequency, the chip will start giving wrong data output.
If you are operating your car ECU in optimum temperature range(25C) there is a good change that it can tolerate more low voltage.
But why take a chance, get a bigger alternator. Your ICE should not take more than 30% of your alternator rating.
So if your alternator is 120A, your ICE should have a mean power consumption of not more than 350-500W.
Remember, when they say alternator is rated for 120A, thats the peak, not the normal amperage.
At idling speeds, alternator churns out lesser amps.
If you are going to listen to high volumes for short period of time, in that case get a bigger battery. Along with that make sure that your cars stock wiring is not taking the load, but your ICE should take load directly through a relay connected to the battery.
__________________
Reclaiming.....!
Thread Tools
3D MAX work on computer modelled cars & bikes blueraven316 Shifting gears 42 2nd October 2008 01:00
First gear clutch release operation in MPFI cars - clarification needed! gigatech2006 Technical Stuff 50 19th April 2008 11:49
True ICE enthusiast? panky12345 Sound Off and Show Off 24 1st September 2007 11:21
What affects ride comfort? Samurai Technical Stuff 32 6th April 2005 19:06
DO MPFI cars have CARB's kakx Technical Stuff 9 25th April 2004 01:54
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
