Thread Tools
Old 21st August 2008, 00:04   #1 (permalink)
Default HELP: W124 Benz needs some speaker help
If you've seen/ owned a W124 E series (Telco Benz) then you'd notice how relatively small the enclosures are. Yes, I do want to keep the car looking stock, so no cutting away anything
I had my heart set on components for front and back but it turns out that I can only install 4" 2-way speakers in the front. My audio guy recommends Boston brand
In the rear, we will try to fit the Boston 5" Component speakers.
These will be powered by the JVC AVX-44 Head unit with no amp.
Any other suggestions? Is there a better option to go with?
Screwdriva is offline   Reply With Quote
Old 21st August 2008, 00:29   #2 (permalink)
anish9000's Avatar
Default Rainbow
You can try Rainbow. The W124 has a uncommon size which is 4.75" for the front and rear and cost approx. 10k. I have them in my car powered by an amp and sounds great. You can contact Jasdeep (Autophile) for the same.
anish9000 is offline   Reply With Quote
Old 21st August 2008, 00:53   #3 (permalink)
speedzak's Avatar
Location: Delhi. Travelling as usual! Mumbai was great.
Infractions: 0/1 (4)
If you are very much persistent of keeping the car stock looking, then where're you placing the tweeters?
I'm not that aware of the speaker locations in a Telco Benz. But I assume it was somewhat similar to the 124. Ain't it?
Being a Merc, a good installer will be able to do a great job with some good equipments while maintaining the stock looks. You don't have to restrict yourself to very specific equipments I think.
__________________
A very big THANK YOU, Bombay!
Will miss you guys! :(
speedzak is online now   Reply With Quote
Old 21st August 2008, 01:14   #4 (permalink)
greenhorn's Avatar
where is the install location? dash or door? for a dash mounting , coax's will do beautifully
If you still want to get 4" comps , illusion sells them
__________________
2007 Indica DLG
My next Truck will be a Safari!
Old 22nd August 2008, 00:32   #5 (permalink)
Default No Rainbow
The speaker housings are on the Dash.Turns out Rainbow isn't available on the mainstream market anymore. Only the more popular brands like JBL and Boston alongwith the usual.Any suggestions on a sub 5" component speaker brand?
Old 22nd August 2008, 01:41   #6 (permalink)
nitrous's Avatar
A non-OE setup need not necessarily look bad.
I would suggest you look at a non-stealth 6.5" components in the front . You can have a very elegant (almost stock) looking install by a capable installer. You can paint the speaker grille the same colour as the door pad/fabric.
Using 4"/5" would plainly be a compromise and there is a huge difference in the effect.
__________________
2004 2005 2006 2007 2008 - 5 consecutive titles.
Arguably,the best the sport has ever seen!
Old 22nd August 2008, 06:10   #7 (permalink)
anish9000's Avatar
The rainbow is available in Delhi, got them a month back and BBW is getting for stock of the same. No cutting or screwing is required.
Old 22nd August 2008, 10:35   #8 (permalink)
Default But in Bombay?
Anish,
If you can give me a phone number, website or some way to get them sourced to Bombay, I'll stall installation of the Boston's that we're planned to be installed tomorrow. Best case would be a dealer in Bombay itself though.
Do they need to be amped or can they run off the head unit just fine?
Old 22nd August 2008, 11:03   #9 (permalink)
sk456's Avatar
You can contact Gunbir on the forum . He and Autophile have soem incredible W124 installs that you could search for in the Sound-off show off section.
__________________
Car : Kenwood - Tru - Rainbow - ID
Home : Dynaudio - Krell
In the audio world, adding to the music is the biggest sin.
sk456 is offline   Reply With Quote
Old 22nd August 2008, 11:25   #10 (permalink)
sk456's Avatar
http://www.team-bhp.com/forum/sound-...ice-w-i-p.html (Mercedes W124 - Pure SQ ICE (W.I.P))
__________________
Old 22nd August 2008, 11:33   #11 (permalink)
navin's Avatar
I can only install 4" 2-way speakers in the front..In the rear, we will try to fit the Boston 5" Component speakers.
If you are looking at primarily "mainstream" brands to go with the JVC44 try Infinity. If you are willing to try the "others" try Illusion, Hertz, Rainbow, etc..
Since the W124 does not have tweeter pods you'll have to make do with coax speakers.
__________________
Scixelsyd Etinu
Old 22nd August 2008, 14:24   #12 (permalink)
gunbir's Avatar
The problem is the W124 uses a 120mm stock speaker which isn't usually available in the American brands.
__________________
Often imitated, never duplicated!
Last edited by tsk1979 : 22nd August 2008 at 15:19. Reason: reference to rainbow removed. Since you market and sell that, you cannot recommend that
Old 22nd August 2008, 14:51   #13 (permalink)
panky12345's Avatar
Why dont you try illusion carbon series?
__________________
SINGH IS KINNNNNNNG..
Old 22nd August 2008, 15:18   #14 (permalink)
gunbir's Avatar
@ Scewdriva: Something I forgot to mention in my earlier post. The stock 120mm speaker has no screw holes to mount. There are clips in underside of the basket that lock into place. To fit a 4" (100mm) or a 5.25" (130mm) you would have to cut and mod the locations, after which the stock covers may not fit into place. You need a 120mm speaker that was designed to be used in the W124.
__________________
Last edited by tsk1979 : 23rd August 2008 at 14:50. Reason: removed mention to panky
Old 25th August 2008, 10:08   #15 (permalink)
Default Setup Phase 1
Allright guys!! Phase 1 complete:
HeadUnit: JVC AVX-44
Front Speakers: Boston 5.25" coaxials
Rear Speakers: Illusion Audio 4.1 Components
Misc: Backup camera + JVC steering remote
My BIGGEST issues is the damn thing won't work with the iphone, other than brilliant Bluetooth syncing. No audio tranfer whatsoever. I'm quite saddened by this! Does anyone have ANY suggestions? Workarounds? HELP!!
Phase 2:
Sub : Something that fits under the First aid storage area, probably an 8" sub
Amp: Not sure of which amp to get but it will probably power the rear components and the sub. Any recommendations?
Thread Tools
Mercedes-Benz forays into Bus business in India with launch of Mercedes-Benz Intercit hanmust The Indian Car Scene!! 34 5th November 2008 14:01
My New W124 E220 viper Long-Term Ownership Reviews 38 13th July 2008 21:12
Looking for a used Skoda RS, or a W124. tadukuttan Shifting gears 2 7th November 2007 12:49
W124 Crashed !.... maxbhp Shifting gears 42 24th April 2007 17:38
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
