Thread Tools
Old 10th September 2008, 01:32   #1 (permalink)
Default SubWoofer and Amplifier query - 8K Budget
Ok i'll keep it short. My current set up is in my signature (jvc*with polks)
Lately I felt that I need a SW since the current sound lacks the lows i want.
The issue is I am short of funds and want to use minimum space.
Other requirements are that I dont want the bass to overshadow the sound. All I want is to add definition and depth to the sound. And since I dont hear my music too loud, anything good at fidelity and lacks in too much power will do.
The budget is 8K. And the thing should be able to get under the current MDF tray and should be able to leave some usable luggage space.
__________________
Maruti Alto LXi 2008 (Pearl Silver)
JVC KD BT1 | Polk Audio DB691 | Polk Audio DB401
Acoustic Research 16 AWG OFC wiring
nitin.dangayach is offline   Reply With Quote
Old 10th September 2008, 03:17   #2 (permalink)
abhibh's Avatar
SW - JBL CS1204(gray) - around 2.8K (more or less depending upon the location)
Amp - kenwood 8401(gray) - 4.5K
Sealed box - around 1.5 K
Overshooting budget here cuz of a good sealed MDF box. Sealed box for CS1204 is 1 cubic feet. Its a very small box and will get under the tray easily and leave around 60% space in the boot.
Will post the pic tomorrow for the size of the box.
__________________
tinypic.com/player.php?v=35mo01l&s=4
Old 10th September 2008, 09:57   #3 (permalink)
Thanks for the reply.
Well instead of having a separate enclosure, do we have some option of the company fitted sealed enclosure with sub ? I guess the company fitted stuff will be far more efficient.
Also what about the cables and all ? What all will I need ?
__________________
Old 10th September 2008, 12:35   #4 (permalink)
hydrashok's Avatar
Getting a sub-driver and building a box for it will be the less costlier option. I think Abhibh's post covers the best VFM option.
If you want a sub-in-a-box, I think the most VFM one available now is the BULL ESW-12 - 12" sub in a ported box. The box will be carpeted and will have the speaker-wire terminals outside. Rs.6700/- if I remember right.
As for cables, you will need a 4AWG power cable (8AWG might also do, but 4AWG is better, considering upgrades), 2 sets of 2-ch RCAs (for a 4-ch amp). Good VFM Cabling can be done in 2.5K, I should think.
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 10th September 2008, 12:57   #5 (permalink)
cooldude1988765's Avatar
Wont a ported box be bigger than a sealed one ?
__________________
I never thought it was humanly possible, but this both sucks and blows.
- Bart Simpson
cooldude1988765 is offline   Reply With Quote
Old 10th September 2008, 13:16   #6 (permalink)
low_bass_makker's Avatar
It is for 8.5k approx, Also the sub is 200 watts rms. One can get better options in 8.5k
Old 10th September 2008, 15:49   #7 (permalink)
Guys trust me, I m totally confused. I cant cross the budget. If the SW itself is 7-8K, and cables demand at least 2K, my budget will get exhausted in these two itself. I need an AMP as well.
Ok getting to the basics, please let me know first that can the said requirement be fulfilled in the said budget ? Since I am sure I can not extend the budget, I would rather wait than going for a compromise on the sound.
The polks have good bass. All I was is to add some groove, some lows. If my budget is less, i'd rather leave the idea of upgrading :(
Suggestions friends.
__________________
Old 10th September 2008, 16:22   #8 (permalink)
Do you want to add an amp to your front speakers also ?
kenwood/blau/jbl 4 channel 5-6k
pio/jbl/gz sub 4-6k
cables, box and installation 3k
That is about 12-15k
__________________
- Bart Simpson
Old 10th September 2008, 16:32   #9 (permalink)
mobike008's Avatar
pio/jbl/gz sub 4-6k
Don't we always have a solution to overshoot a fella's strict budget?
Even i think Abhibh's recommendation is best. CS1204 is the best value for money boom box. I have the original that comes with the box and it is more than decent in SQ. I got it for about 8K more than a year ago.
__________________
[b][i]The nail that sticks out gets hammered !!!
Old 10th September 2008, 16:33   #10 (permalink)
Ok that reminds me. The current output from my HU is good enough for the rears and fronts.
Can't I then go for a MONO AMP ? I am not sure if it'll be cheaper or not. Just wondering.
ANother cobination can be : Front coaxials on HU and the rears+SW on AMP. I can then go with a good 4ch AMP.
Any suggestions on that as well ? That way we can finalise the requirement.
The front speakers are good enough on the HU. Here are the specifcations for the fronts speakers :
db401 Car Audio Speaker from Polk Audio
Driver ComplementMid/Woofer1 - 4" Diameter (10.16cm)
Polymer/Mica Composite cone with rubber surroundTweeter1 - 3/4" Diameter (1.91cm)
Silk/Polymer composite domeElectricalOverall Frequency Response85Hz-22kHzNominal Impedance4 ohmsPower Handling (continuous)45 wPower Handling (peak)135 wEfficiency91 dB
What do you guys suggest ?
__________________
Old 10th September 2008, 16:36   #11 (permalink)
chiragh_bir's Avatar
go in for Blaupunkt GT4 Special MKII. excellllent amp!
With B&W it costs 4800/-
more info here
Blaupunkt - Amplifier - GTA-Series - GTA 4 Special Mk II
chiragh_bir is offline   Reply With Quote
Old 10th September 2008, 16:49   #12 (permalink)
cyclops's Avatar
nitin, i'd suggest you first try your setup by adding only an amp. sans any sub. if you still miss the lows, go for a sub..
even i'm planning to get an amp for my setup, but a bit short of moolah and a lot confused in the choices between the three amps, 8401/A-604/GT4 MK2
i've even compiled a comparo of these three amps in the attached pdf..
EDIT: Mods, can we create a separate thread titled "Best Entry level Amp" maybe with a poll and put this PDF there?
Sorry nitin, for going OT..
cyclops is online now   Reply With Quote
Old 10th September 2008, 17:03   #13 (permalink)
WOW thanks cyclops. I am thinking of buying some stuff second hand to keep the cost within limits.
__________________
Old 10th September 2008, 17:41   #14 (permalink)
sonic_boom's Avatar
If u want to get heavy lows at low volumes get this :
Kenwood/JBL 2 channel entry level amp(3 K)
JBL 12" 3K
Tsunami Kit (No specific idead but definitely under 2K)
(All prices approx and gray)
But beware....don't crank up the volume too much or you might end up embarrassed
__________________
If 10% of road accidents are due to drunken driving then 90% of accidents are due to driving without drinking...Hmmm...
sonic_boom is offline   Reply With Quote
Old 10th September 2008, 22:33   #15 (permalink)
harry2223's Avatar
the cheapest option woud be an alpine 4 channel amp i dont know the number but that silver coloured one.pioneer subwoofer or xplod subwoofer in custom made box. this setup is common in our city and bass is sufficient. the amp cost around 3k and the xplod woofer is around 2200 and pioneer is around 3k. all these are grey markit without warranty . but never heard any complaint
you can also exchange these if you want better stuff later on.
__________________
harry
harry2223 is offline   Reply With Quote
Thread Tools
Subwoofer without Amplifier works.. headers Ask the Gurus 52 24th July 2008 14:18
Help in selecting Amplifier and Subwoofer for my Wagon-R ravi@64bhp Ask the Gurus 37 28th June 2008 21:40
Which Subwoofer and Amplifier ramie2400 Ask the Gurus 40 4th January 2008 10:51
Blaupunkt Subwoofer and Kenwood Amplifier for sale general_neo Shifting gears 7 25th December 2005 13:32
best subwoofer-amplifier combination for Rs.10-15k nitrous Ask the Gurus 14 1st November 2004 13:21
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
