| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Mar 2007 Location: New Delhi
| Hi friends and audio lovers , good to be back on the forum after a long time. I'm going to upgrade my Amp Kit. The reason being that my current BOSS power cable got fried and almost toasted my car's wire harness along with it. Plus the el-cheapo RCAs emit continuous whine. So now it's either Tsunami/Monster/Audison with Audison being the most readily available. My amp is JBL 75.4 , sub is sony 300W / 12" Now to the queries : 1) Shud I get 4 gauge or 8 gauge Kit. 2) I use RCA splitters at AMP end due to my head unit having single pre-out. Wouldnt low quality splitters nullify the quality gains of using a good RCA cable. If yes then are there any branded splitters available and at what price?? 3) Lastly the price of Tsunami and Audison 4 gauge Kits (in Delhi).
__________________ If 10% of road accidents are due to drunken driving then 90% of accidents are due to driving without drinking...Hmmm... |
| | #3 (permalink) |
| So Nitrous bhai , I guess you are suggesting 4 gauge (25 mm Sq.). IIRC audison has FPK 600 that is a 4 gauge kit right ?? Any idea about prices anyone?? PS - checked googled on Y splitters. Audison does have them in their product line-up .
| | #4 (permalink) | |
| BHPian | Quote:
And on the splitters part, can't we connect the AUX-out of the AMP to the rear channels using an RCA to RCA cable. I think that should be the same as splitting it and feeding it. I think the front channels and rear channels are independent of each other inside the amp. And the amp doesn't provide any active connection between input and aux-output. I think they are just used for cascading.
__________________ Suzuki Swift - 2007 - Pioneer DEH P80 RS,GTO 1004,GTO 3501,GTO 1204BR,GTO 608c,GTO 638,Monster,Audison Connection - Royaltek GPS | |
| | #7 (permalink) | |
| Quote:
But what length is required including Power and Ground ?? My Car is Alto LXi and my 75.4 is mounted behind the rear seat ?? And didnt Gunbir ji say somewhere that since current travels on conductor surface , amp kit power cable is better compared to regular power cable since it is multi-stranded providing more surface area??
__________________ If 10% of road accidents are due to drunken driving then 90% of accidents are due to driving without drinking...Hmmm... | |
| | #9 (permalink) |
| Senior - BHPian | sonic boom if you plan for a mono upgrade later on then the 4gu aka 25sqmm wire will be more worth the money just like nitrous suggested, if you dont then its a dead investment. well you can still get the 8gu wiring kit if unavailable in audison, scosche and kicker have them too, they are as good as audison, if not equally good depends on the series you buy from a particular brand. might i suggest installing the Amp in the boot either to one of the sides or behind the rear seat??? this way the amp will have more air circulation and will stay cooler, will be better protected from the legs of rear passengers and in case the car's base carpet gets wet during monsoon could possibly destroy the amp, its for the same reason i reinstalled the amps in the boot in both my cars. check out a few sound off and show off threads for the pics of install. this is what i did in my swift, http://www.team-bhp.com/forum/diy-do...-my-swift.html (My First ICE DIY Install in my swift.) well the surface area being more part you are correct, but finolex FLAME guard series is way better jacketed and has better core wire, and for the surface area you can use 2 or 3, 6sq mm wires for the same amp which will cost you below 800 bucks i.e. 6meters of lenght, if you need it till boot if beneath one of the front seats then 3 meters is enough. and not the HOME guard series is usually marketed more, finding flame guard is a bit tough, you can also look at Havell's flame guard series that are fire proof, have a better core wire too. if you seriously want the flexibility then go for the car audio brand wires, which in your case i dont find the need for, in my swift i went in for the later series GTO1004 amp the 75.4's replacement from jbl and i am using the home guard 6sqmm X 4 wires, back then i thought i would even go for a mono later on so i put that thick wire, but i am kind of satisfied with the current audio setup which includes that amp a set of comps and a sub, so left it that way. well all the best finding the wires and with the installation. ![]() do get a branded fuse box and terminals along with RCAs make sure that are not basic starting range from any brand, it better be a little better series, like for example vrrraju ( http://www.team-bhp.com/forum/sound-...t-jblfied.html (Another Swift JBLfied) ) got basic ones from monster and i have the 101 XLN's which has better jacketing and core wire. you can see the red rcas in my swift thread. no offense meant to any one if did offend some one my apologies i just took the names and i am pasting the linkys for better knowledge thats all. cheers hope i have been of some help.
__________________ A Cocktail of ICE and DIESEL has pumped my ADRENALINE LeveLs, now i am addicted. haa feels blissful, so whats your Cocktail? -YDP Last edited by rider60 : 14th September 2008 at 15:03. Reason: spell check. |
| | #10 (permalink) | |
| Senior - BHPian | Quote:
Here is your answer bro about the current and conductor. http://www.team-bhp.com/forum/ask-gu...tml#post695378 (A question about cables) So it is not about the surface area it the cross-section area thicker more current will flow. Ya if you plan to add another amp then go for 25mm else 16mmsq is enough. Anna a 16 mmsq is recommended. Last edited by low_bass_makker : 14th September 2008 at 15:14. | |
| | #11 (permalink) |
| BHPian | If it is pointing towards me, then no offenses taken yash, I know we are here to give advice and share our experience, I think you will agree with me, if I say you will learn things only after burning your fingers. I did and I learnt a lot in ICE now. I went with the branded stuff since I didn't had much experience with me. If such things helps for others then we all gain....Right.
| | #12 (permalink) |
| Thanks for all the help guys. Finally got the 8 gauge Bull audio kit installed today from Driven since Bull seems to be getting good reviews and prices are okay too. Kicker was kinda expensive and the Audison 8 gauge kit was out of stock and I was in a hurry to get the job done cos the current setups power wire had burnt completely The kit had 8 gauge power and ground wire along with a pair of RCAs. Now when I compared the Bull power wire to the Boss , the difference was stark. The Boss power wire seemed to be 16 gauge compared to Bull's. And as a pleasant side-effect the irritating alternator whine is gone completely too , confirming the fact that the people at Bull Audio know their job. Yippeee...
| | #13 (permalink) | ||
my fingers were burnt when i ended up spending 10k, 5k for a set of blau comps which were destroyed due to water seepage and had to spend an additional 5k to get another set. , hence that kind of care in my cars to keep water away from ICE.Quote:
__________________ A Cocktail of ICE and DIESEL has pumped my ADRENALINE LeveLs, now i am addicted. haa feels blissful, so whats your Cocktail? -YDP | ||
| Thread Tools | |
Similar Threads | ||||
| RCA leads from Italy? | chiragh_bir | Ask the Gurus | 8 | 1st October 2008 19:09 |
| good rca and speaker wiring | makanaka | Ask the Gurus | 2 | 15th August 2008 20:22 |
| MX RCA cable and alternator whine :( | nitrous | Product Discussions | 21 | 15th December 2007 21:37 |
| RCA splitter for HU? | gopz | Ask the Gurus | 8 | 5th June 2007 18:41 |
| Good RCA Wires | low_bass_makker | Product Discussions | 42 | 11th June 2006 00:37 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
