Closed Thread
Thread Tools
Old 14th September 2008, 10:03   #1 (permalink)
Post Sx4 Music System Upgrade
Hey.. i have an Sx4 which is abt 10 months old.. yesterday i changed the front two component speakers and tweeters to JBl CS 2165 C. It is a set of tweeters and component speakers.
The sound quality has improved from the stock speakers. What do your'll think of these speakers?
Would it be better to put JL Audio speakers( 6"x9") at the back ( behind the head rest) or to install a sub woofer??
Ur opinion is much appreciated.
Wayne D is offline
Old 14th September 2008, 16:26   #2 (permalink)
Hi! Wayne!! what about the Headunit? mind naming it to us? IMO components sound better than coaxials, but are a bit expensive too. I've never heard a pair of JL Audio 6 x 9, so can't really comment on this.
Always trust your ears , you won't be mistaken.
__________________
~~ Feel The Bass ~~
FeelTheBass is offline
Old 14th September 2008, 19:54   #3 (permalink)
The Headunit is the one which comes with the car. What is IMO component?? I was thinking to put the JL Audio 6x9 speakers at the back but i heard the pannel behind the head rest is made of metal so that will have to be cut for this to be installed.
So as another option i was thinkin of installing a 4 channel amp or use a Pioneer 2 channel amp which i already have and connect it to the front two component speakers. As well as add a set of JL Audio component speakers in the rear door. which do u think will be a better option?
yeah i'll have to trust my ears, jus wish that could be done before the speakers are installed and paid for
Wayne D is offline
Old 14th September 2008, 22:02   #4 (permalink)
low_bass_makker's Avatar
Go for similar brand of speaker all around, And if possible same series of the same brand else you will feel difference in sound.
Amplifying the speaker will increase loads of SQ. Also then next step will be HU upgrade.
low_bass_makker is offline
Old 14th September 2008, 23:12   #5 (permalink)
So another set of JBL cs series in the rear door or the GT series?
The amp tat i have with me is a Pioneer amp.. 100wx2..it isnt installed.. i was wondering if its worth getting this installed for only the front two speakers or, buying a 4 channel amp and another set of compnents for the rear doors?? i want some bass as well, so instead of component speakers would power speakers be better ??
I dont intend on changing the HU right away, if i do change it, it would be to an LCD touchscreen, but thats way in the future.
Wayne D is offline
Old 15th September 2008, 00:54   #6 (permalink)
anantnehru's Avatar
Get the JBL 6x9s at the back. True, you need to cut the metal; but the sound is terrific. With a 4 channel amp, doubt you will feel the need for a woofer.
anantnehru is offline
Old 15th September 2008, 17:09   #7 (permalink)
IMO = In My Opinion. and component = components , you know what i mean. Yes, cutting-shutting will be needed to place the 6x9's properly on the speaker tray. Same was done with my car, i had to sacrifice some metal from the tray part. But when it comes to cutting-shutting one really needs to think about it. Well, about JL Audio!! Guru's will be the best to help you out. Thanks!!
__________________
~~ Feel The Bass ~~
Old 15th September 2008, 17:19   #8 (permalink)
Technocrat's Avatar
The SX4 head unit & ICE has been discussed in detail, please search for relevant thread.
Thread Closed
__________________
The Holy Trinity: Traction, Torque and Tarmac
Technocrat is offline
Closed Thread
Thread Tools
Music System Problem raja748 Ask the Gurus 7 15th February 2007 11:14
My music system!! hot_rod Sound Off and Show Off 10 24th July 2006 00:43
Music System for Zen? pingme Ask the Gurus 17 4th September 2005 04:23
Music System Upgrade The X Factor Ask the Gurus 24 2nd April 2005 12:14
Music System for a VTEC aggressive_anush Ask the Gurus 8 23rd October 2004 14:42
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
