| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | i have a scorpio VLX in which i have 4 standard kenwood speakers, two 400W sony speakers in boxes and a 1000 W sony subwoofer. the amp is sony too, 2 channel. but somehow i am not getting the desired bass level. a friend told me that the standard kenwood head unit is not good enough and i have to change it. is it true? i want a good bass effect at minimum cost now! which brand of head unit should i opt for considering i need a good power output. which brand and which model has the best looks, features and power o/p at the lowest price? i will prefer upgrading the head unit and i have a budget of 7000-8000 for the same. i can also exchange or trade-in the current head unit to replace a new one. kindly suggest a good brand of head unit with good power output. also, is there anything wrong with the sub and amp (in terms of power or compatibility). the amp runs both the subwoofer as well as the 2 sony 400W speakers, is this ok? i wont prefer changing the sub or speakers as that would require a bigger budget! i am happy with the sound quality, only wish much more bass effect. here are some pics of the same: the front speaker in the front door, standard kenwood: ![]() the head unit, standard kenwood unit (NDC-MP6009UC): ![]() the subwoofer, Sony Xplod 1000W 16 inch sub: ![]() two additional speakers, Sony Xplod 400W in speaker boxes: ![]() placement of the sub and the speakers, in between the middle row and the jump seats: ![]() ![]() ![]() standard kenwood speakers on the boot door: ![]() ![]() the sony ampllifier is a 2 channel unit (XM-ZR602) placed under the front seat.
__________________ NoThInG eLsE wILL dO ... |
| | #5 (permalink) | |
| BHPian Join Date: Mar 2007 Location: New Delhi
| Quote:
Tri-Mode ??
__________________ If 10% of road accidents are due to drunken driving then 90% of accidents are due to driving without drinking...Hmmm... | |
| | #7 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Yes the sub box is too small. Sony woofers are not known to be great anyway. Use the HU to drive front and rear speakers and the 2 ch amp for the sub. Like LBM said, get a good installer and first extract the best out of your current components then think about upgrades. you have 6 speakers and a sub. you need 7 channels of amplification. so after you are done with 'extracting the best' these are the upgrades youd have to keep in mind... 1. 4 ch amp for 4 (front and rear) speakers 2. new sub 3. replace 2 ch. amp with second 4 ch. amp to drive sub and 2 speakers 4. front speaker upgrade
__________________ Scixelsyd Etinu |
| | #8 (permalink) | |
| Senior - BHPian | Quote:
You got to bridge the 2 channels in your amp & give the brridged output to the sub woofer & run the rear speakers off the HU.
__________________ Goodbye Dada, you made us proud. | |
| | #9 (permalink) |
| Senior - BHPian | Sony amps hardly have any tunning switches,which gives lesser flexibility,seems he is running both the speakers parallel and sony amp in bridge mode over the same amp,as LBM stated the subwoofer is also producing vocals.I dont think there is a need for changing the Head Unit. Where do you put up??meet me i'll help you out in tunning your existing setup..cheers Ramie ![]()
__________________ Behind every successful student there is a girl... But!!,what about unsuccessful student's like "US"?? ...Lots of girls. :D Last edited by ramie2400 : 16th September 2008 at 12:16. |
| | #10 (permalink) |
| BHPian | hey ramie, i am from mumbai, powai. i needed a cost effective solution. as per your recommendaations, i will try powering the sub with the amp alone and the 6 speakers from the HU. i hope it makes a difference to the bass level.
| | #11 (permalink) | |
We can meet up sometimes.. cheers ramie
__________________ Behind every successful student there is a girl... But!!,what about unsuccessful student's like "US"?? ...Lots of girls. :D | |
| | #13 (permalink) |
| BHPian Join Date: Apr 2007 Location: Gurgaon
| Honestly, your set up is not bad at all. I have a strong hunch that the enclosure of the sub is too small and the sub is not beind fed properly.
__________________ Maruti Alto LXi 2008 (Pearl Silver) JVC KD BT1 | Polk Audio DB691 | Polk Audio DB401 Acoustic Research 16 AWG OFC wiring |
| | #15 (permalink) |
| BHPian Join Date: May 2008 Location: Cary Usa
| I suggest you should go for a pioneer subwoof 307 and a 8 channel 5600 watt amp. Also the box you are using does it have a small hole to let the air out? It feels to me that the amp u are using is not powerfull enough.
__________________ Max Double your drive space Delete Windows. |
| Thread Tools | |
Similar Threads | ||||
| What will be the effect of 100% coolant? | DarkEraser | Technical Stuff | 41 | 2nd November 2008 07:57 |
| not getting good bass effect | trivedishivam | Ask the Gurus | 3 | 2nd December 2007 00:18 |
| do alloys effect handling?? | noidaboy | Tyre & Alloy wheel Section | 20 | 15th March 2007 16:30 |
| The Effect of Team-Bhp | Surprise | Shifting gears | 13 | 13th April 2006 14:08 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
