| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Sep 2008 Location: baroda
| Need Help! I have a ford Mondeo 4004 model. It has a wonderful OEM sound system by Visteon Germany. But it cannot play MP3 CD's. The shape of the mondeo oem is slighlty differnt is size, hence if ai try to change to a double din aftermarket deck from sony JVC etc, it does not fit. I need help to attach a ipod player or atleast play mp3 any help o suugestions. Also in Honda Accord 2006 model, it does not play MP3or ipod. Any suggestions to retrp fit a mp3 plaer or ipod. thanks a bunch! |
| | #2 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
The 2 options you have are either using a FM modulator to connect an ipod or CD/MP3 changer or using a product like H/K Drive & Play. THis is true of the Honda Accord too.
__________________ Scixelsyd Etinu | |
| | #3 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Navin, Visteon is Ford's automotive components unit, similar to GM/Delphi. Visaton is the specialist speaker manufacturer. The stock OE Visteon system in the Mondeo is a very competent unit, but not in the same class as Visaton drivers. @agpcool, check the manual of the audio unit - there might be an Aux-in provided in the HU terminated at the HU connector pins, but not wired to a socket. If so, it should not be too big a problem to get it wired to a headphone socket, to which you can connect you PMP / iPod with an EP-to-EP cable. If not, another way is to use an amplifier which has a direct Aux-in connection, like the Blaupunkt GTA480. I was gifted a China-made Car MP3 player a couple of months back, which has 1GB flash for song storage, MP3 player, an EP socket to connect external PMPs and an FM unit to beam the output to the HU. The whole thing goes into a cigarette lighter socket, and has an IR remote too (the main unit has only 4 buttons). Though the playback from the built-in MP3 player is tolerable (better than FM radio), the playback from iPod through the EP socket is horrendous.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #5 (permalink) |
| dear navin... thanks for your reply... but fm modulator has too much disturbance.... i will have to try H/K Drive & Play, but not sure if it will work on Mondeo and Accord OEM players.... i will check it though |
| | #6 (permalink) |
| BHPian Join Date: Jan 2008 Location: Chennai
| Hi, I used to own a Mondeo and we had swapped the O.E. system for a Kenwood DDX 7039 DVD system. This was a 2 Din system and flushed perfectly into the existing slot for the O.E. system. Also, my installer was able to connect the Kenwood system to the O.E. remote on the steering stalk, so that I could retain all the functions like track change, volume control. etc.... |
| | #7 (permalink) |
| dear deralte i am not sure if the OEM in both mondeo and accord have aux input.... i have a pinout for the mondeo, but it does not show an aux in the pinout. however on the headunit it has an option for selecting aux....... thank for your reply |
| | #9 (permalink) |
| BHPian Join Date: Feb 2004 Location: Mumbai
| Sorry for the delay. Here are the pics..quality of the pics is bad but u can get an idea of how it looks. When the panel slides down the car has to be in neutral otherwise it touches the gear knob (if in 1st,3rd or 5th). ![]() ![]() ![]()
__________________ R.I.P Robin |
| | #10 (permalink) |
| I have a 2006 Honda Accord. I will really appreciate if any one can tell me is theer any way to attach an ipod/mp3 player to the OEM system. Using FM trasmitter is not a good soluution and the music quality really become bad. any suggestions.. thanks! |
| | #11 (permalink) |
| BHPian Join Date: Feb 2008 Location: mumbai
| Even i am gonna keep a close watch on this one as there is nt any soluttion from the after market chap s which appeal s me and no one will be intrested in chopping slicing wires and risk other utilities ! The fm transponder really give s poor quality sound and is not worth it !! Any audio guru could please throw some light to this issue !! |
| | #12 (permalink) |
| BHPian Join Date: Aug 2008 Location: Bangalore
| hi to state the obvious. in most manuals the pin config is given in a cryptic like my blaupunkt. so only an installer typically understands it. very dumb i must say. you have to look for 3 pins. one for left one is right and one ground. generally its the last three. if you can post us a pic of the manual showing the pin config sheet we could help better. |
| | #14 (permalink) |
| It is either the pin pair 8,9 (Phone Audio +, -; the shield of the cable should be connected to pin 5 but strangely it is marked NU here) or 11,12 (maybe not, since it is marked Remote; please check description in manual) in the remote connector #2. The ACP + and - is for the steering wheel remote, and AVC is the input to automatically control volume based on speed. This one does not have the CD changer interface (remote connector #1), where one can use pin pair 5, 11 (R) and 6, 12 (R) as AUX-IN.
| | #15 (permalink) |
| BHPian Join Date: Aug 2008 Location: Mumbai
| You can also get a fabricated casing for Double din players.The one which i got for my accord or like the 1 Dinu has got for his civic.
__________________ "..Attitude is a little thing that makes a big difference" |
| Thread Tools | |
Similar Threads | ||||
| Ford Mondeo XR-5 Turbo & Ford Mondeo Reviewed | Brosreview | Test-Drives & Initial Ownership Reports | 8 | 27th September 2008 04:02 |
| Ford planning to re-launch Ford Mondeo in India | navdeep | The Indian Car Scene!! | 38 | 19th August 2008 04:19 |
| Connecting iPod to Accord HU | adya33 | Ask the Gurus | 4 | 12th June 2008 13:03 |
| Modded Red Ford Mondeo! + KS Motorsports Turbo/NOS Mondeo | Gordon | Modifications & Accessories | 82 | 19th October 2006 22:34 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
