Thread Tools
Old 30th September 2008, 21:50   #1 (permalink)
svsantosh's Avatar
Question Pio 3050UB (2 RCA) + JBL 4Ch GT5-A604 = HOW to GET A SubWoofer "DILEMMA"
The car :
http://www.team-bhp.com/forum/test-d...000-kms-8.html (Booked Indigo CS Dicor. EDIT : Now TDi Running Report (Updated to 10000 Kms))
Brief History:
1) Indigo CS TDI
2) current setup : (Done @ Anwar/Thouqeer AutoFusion's Blore)
-----ICE Setup-----
HU - Pioneer 3050UB
Amp - JBL 4Ch - GT5-A604
Front - JBL Compo - GTO507C
Rear - JBL CoAxials- 6*9 937's
Scoshe EFX wiring
3. Budget: MAX 5K :(
4. SELF DRIVING
5. Music preferences -- No Pref
6. Ready to sacrifice your boot space/modify door panels? : Boot space - not much (little is ok)
---------------------My Query------------------
1) Since i have a Pio 3050UB with "ONLY" 2 RCA out which is linked to a JBL GT5-A604 4Ch - I do not have any more RCA outs to power a MONO(no money to buy one too) -- Suggest a best way to drive a 3050 + GT5-A604 + Compo's front + 6*9's rear + "NEW YET TO BUY" 8" Sub (Polk MOMO mostly)
1) What is the best solution to fit a tiny (8" Polk is the only sub avbl i guess) Subwoofer in this current setup. I am totally lost after 2 days 'searching' in 'tbhp' (of course).
2) I wanted to save space so searched for 'woofer in rear MDF plank' and DID NOT find much info.
3) Dont want 'SWSW' - I use my boot most of the days. So dont want to damage the sub.
4) I dont want 'loose' (boom boom) bass - looking for more 'hard' (dhak dhak) bass (I guess I want a sealed enclosure over a ported one) (Remember not too loud also, but I want more 'dhak dhak' bass than the current CoAx's)
5) Is any of below possible?
5a) Drive compo's off the HU, just unplug existing wire from AMP and connect to HU
5b) Drive CoAx's from HU - which will mean I have to "PAY" for new (UnCut - no join's!) wiring from CoAx to HU - "WHAT WILL THIS COST ME"
5c) Will the current AMP support the Polk 8"? I really dont want to spend on a new HU or a new Amp/Mono.
Any help is much appreciated.
__________________
Dont wear Helmets & Seatbelts to reach Heaven Faster
You hardly have any time left in this world to be a sinner
svsantosh is offline   Reply With Quote
Old 30th September 2008, 22:10   #2 (permalink)
Sam Kapasi's Avatar
Yes, sealed is what you seek.
a) Yes, possible, not recommended
b) Yes possible, recommended. Wiring from Coax to HU should cost you 100 to 200 rupees.
c) Yes it will. It will drive an 8" sub in a sealed box with ease.
__________________
Live the YetiLife®
Old 30th September 2008, 22:23   #3 (permalink)
svsantosh's Avatar
Respected Sam, (really mean it)
a) Yes, possible, not recommended - guessing bcoz Compos sound better from Amp rather than a HU?
b) Yes possible, recommended. Wiring from Coax to HU should cost you 100 to 200 rupees. - i was afraid much more - then i am ok with it, what do I loose wrt SQ?
c) Yes it will. It will drive an 8" sub in a sealed box with ease.- throw some light on wiring connctions please? just plug the +ve and -ve of the SUB to a +ve/-Ve of the GT5A604? You dont expect any power load issues from a 8incher to a GT5?
- And i just noticed 6 options on the Polk site.
8" Subwoofers : Speakers & Systems : Polk Audio
Which one fits my budget? Sub + box + wiring? Please advise.
__________________
Old 30th September 2008, 22:45   #4 (permalink)
Sam Kapasi's Avatar
Yes and because the music will sound better if the front soundstage is crisp, loud and clear.
You will not lose any sound quality, the rears will get a bit quieter and will function only as fillers. Perfect if you drive yourself.
Will you be connecting it yourself?
The rear channels of the GT5-A604 will be in bridged mode.
Name:  Image - GT5-A604  (Side View, 01)_jpg.jpg
If you see the picture above, right on top of the 8 speaker terminals you will see Bridged with a + and a - sign. The + and - of your subwoofer will go there, on the lower row. The upper row will drive your components. The rear speaker will be connected to the rear speaker out of the HU.
No there will be NO power load issues. God promise.
Cheers man and enjoy your music
__________________
Live the YetiLife®
Old 30th September 2008, 22:55   #5 (permalink)
svsantosh's Avatar
No Sam, May be Satya(EVO) this time - i have visited Anwar's twice, thought of experiencing satya's magic this time...
Is the pic of my AMP's model? Never noticed those!! I am guessing the opposite (other) side will retain the current connections? 2+2 RCA cable input from HU.
Oh and yes - any ideas for SUB placement? Boot it is, but what about the MDF plank, should I cut a square in the center for the bass to flow in(close the hole with a net cloth?)
__________________
Old 30th September 2008, 23:00   #6 (permalink)
Sam Kapasi's Avatar
Cool, he will know exactly what to do.;
Yes, that is your amplifier. Yes the other side will retain the connections, however the LPF of the rear channel will be switched on and will be set between 80 to 120 Hz, depending on Satya.
No no. Just put it in the boot. Bass travels.
__________________
Live the YetiLife®
Old 30th September 2008, 23:26   #7 (permalink)
speedzak's Avatar
Location: Delhi. Travelling as usual! Mumbai was great.
Infractions: 0/1 (4)
Man! If Satya is doing this, he knows what to do as Sam said. Don't bheja fry too much about connections and all here. If you have understood what Sam has explained, then good. If not, then Satya will give you a good on spot explanation of how it's all done.
As you expect lots of dhak dhak bass, I expect you want some on the chest, powerful bass. Ain't it?
I'd recommend you to listen to a ported box and a sealed box before you choose your's.
Why an 8" sub?
It would cost more in some cases. I don't know about Polks. Keeping the dhak dhak thingy in mind, I'd say you check out some 12" ones too. Won't make a big difference in the box size if made correctly.
__________________
A very big THANK YOU, Bombay!
Will miss you guys! :(
speedzak is online now   Reply With Quote
Old 1st October 2008, 11:31   #8 (permalink)
svsantosh's Avatar
>Why an 8" sub?
I was thinking space
Ahem... will the current amp support it? I was under the impression the sub's need more powerful and consistent power.
And the price?? Will I stay under the 5K budget (i am looking only for a marginal increase in bass)
what are the current prices of a 8" (only polk makes them) and a 10-12" (decent brand) + boxes for both of them?
__________________
Old 3rd October 2008, 19:11   #9 (permalink)
svsantosh's Avatar
Sam, others -- help required
I was just seeing through JBL and Polk Audio sites and noticed both have a 8" option. Sam - Is this available in India? "GTO 804" - single Voice.
I also noticed Polk having the following.
db804
db804DVC
db840
db840DVC
MM2084
MM2084DVC
What is DVC - Dual voice coil? i suppose, and its difference with others?
Sam, back to you - will the GT5604 Amp support 2 Compos @ front and a 8" SEALED DVC sub at the rear? (937's from HU as you directed me to...)
Satya, thanks for giving me the directions. I will try to find a time to see you ASAP.
__________________
Old 3rd October 2008, 21:26   #10 (permalink)
Sam Kapasi's Avatar
As they say in certain parts of the world, hallihallo!
Nope. That model is US only. Everywhere else, size does matter.
Sam, back to you
Yes Sir!
Yes. But I'd much rather you just bought a 4ohm Single voice coil.
Jai Hind!
__________________
Live the YetiLife®
Old 3rd October 2008, 21:39   #11 (permalink)
Magma's Avatar
DVC is dual voice coils(i.e the sub has 2 coils)
SVC is single voice coil
DVC subs give flexibility in connection because the coils can be connected in parallel or series to present differnt loads to the amp
E.G two coils of 4 ohms wired in series present 8 ohms and wired in parallel present a 2 ohm load
however since you have already chosen an amplifier which i think is 4 channel and is probably not stable at 2 ohms SAM has rightly adviced you to get a SVC sub
Vande Materam
__________________
An expert is someone who takes a subject you understand and makes it sound confusing.
Magma is offline   Reply With Quote
Old 4th October 2008, 09:41   #12 (permalink)
svsantosh's Avatar
vanakkam & namaskara (I belong to both TN and KA)
Done - no more arguments from my side...
Originally Posted by Magma View Post
...and is probably not stable at 2 ohms SAM has rightly adviced you to get a SVC sub
yes - thx for 'confusing' a commerce guy (kidding), but i will stick to a SVC
Jai Hind!
Vande Materam
Satyameva Jayate
(I had to say something)!!
__________________
Thread Tools
JBL GT5-500C, is this component speaker a 4" or 5.25" ? vishnuvijay Ask the Gurus 23 14th June 2008 12:15
JBL T696 GTi Series 6"x9" Co-Axial speakers ddd08 Ask the Gurus 9 9th April 2008 20:54
Help me choosing enclosure for GT5 12" Subwoofer venki7744 Ask the Gurus 7 25th March 2008 11:50
Help Needed : JBL 1000 10" subwoofer in a tube AshOnTheRocks Ask the Gurus 10 10th April 2007 12:41
HU Query for JBL speakers was "Polk MOMO vs db Compos" hyper-VTEC Product Discussions 43 13th December 2006 15:03
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
