Thread Tools
Old 3rd November 2009, 12:01   #721 (permalink)
SPARKled's Avatar
I have a 4th gen Ipod U2 special edition 20GB model which is included as a model compatible with the DXZ785USB. Still I am getting an Error2. Any ideas?
__________________
Best Regards,
SPARKled
In My Garage:
Chevy Spark LS with |Clarion DXZ785USB|DLS C36|GZIA 4100|Bull Audio SW-12|
SPARKled is offline   Reply With Quote
Old 3rd November 2009, 12:46   #722 (permalink)
Technocrat's Avatar
Well the manual says this for the various error codes,
Check the Files types that you are using in your iPod
__________________
The Holy Trinity: Traction, Torque and Tarmac
Old 3rd November 2009, 12:50   #723 (permalink)
SPARKled's Avatar
They are all mp3 files. Looked up on other car audio sites and found out tha like older generation Ipods are a lottery with this HU and you are better off with a newer ipod to be surely compatible.
__________________
Best Regards,
SPARKled
In My Garage:
Old 3rd November 2009, 13:46   #724 (permalink)
Technocrat's Avatar
Why dont you try putting in MP3 files which are encoded differently or may be a WMA & confirm if its the file format or the iPod.
__________________
Old 3rd November 2009, 14:56   #725 (permalink)
Originally Posted by nishantgandhi View Post
I am a bit confused here. How can iPod be used to play lossless on the 785? AFAIK, the 785 connects to an iPod using a standard USB cable (to which you would connect a flash disk /external HDDas well). So it would be using the HU's DAC na?
As per what I have understood so far about USB connection to this HU, it has 3 modes-
1. USB mode- It connects to a flash or HDD drive using standard USB protocol (apparently referred as "USB mass storage"). HU handles everything from file-system operations, accessing files and decoding them. Can not play any lossless format in this mode.
2. USB-MTP- Similar to normal USB mode but file-system operations are handled by the connected device, not HU. However still can not play lossless because decoding is done by HU itself. For a big collection, it may provide faster access as compared to normal mode.
3. USB-Ipod- In this mode it digitally communicates with Ipod using it's custom protocol over USB link. I "guess" apple could be doing decoding in this mode and sending final audio data to HU (it is reasonable to assume that it can not have analog connection through USB!). I am also making a basic assumption here that Ipod should be able to be operated as usual while connected to HU. Given that it can play apple lossless when not connected, that functionality should be preserved even after connecting it to HU.
Or are you planning to connect your iPod through AUX / iPod adapter (if such a thing exists)?
No, that would defeat the purpose of having USB-Ipod feature itself.
Secondly, if you connect your iPod to the 785, do you browse the songs/playlists/folders on the iPod or the HU?
HU support many browsing options like composers, playlists, artists etc. in "Ipod menu" mode. I don't think it will support text based search directly from HU (how do you type in the first place?). However, as I mentioned above I hope Ipod itself should be fully functional in case I want to do text based search directly from Ipod, rather than though HU. BTW, HU displays title information as sent by Ipod.
Disclaimer - I have never tried iPod with this HU so hence the nOOb question.
...and I am even bigger noob, I have never used Ipod itself, no question of Ipod in cotext of 785! Let me confirm all the speculations after a few days of REAL use.
BTW, "all seats" option not only disables TA but speaker gains as well (in case you have changed them). Unlike Ipod, this feedback is based on actual use.
santosh.s is offline   Reply With Quote
Old 3rd November 2009, 15:06   #726 (permalink)
You running active, mate?
greenh0rn is offline   Reply With Quote
Old 3rd November 2009, 15:11   #727 (permalink)
No, I am using passive crossover of component set. But I have set gains on both sub and component amps to the lowest position and use HU gain to keep required relative difference between components and the sub. So, like most common setups, sub to components is "active" and within components it is "passive" mid to tweeter crossover.
Old 3rd November 2009, 15:25   #728 (permalink)
I am running it under 3 way active mode, but haven't faced this issue after putting the 'all seat' option on/off.
Invinsible is offline   Reply With Quote
Old 3rd November 2009, 15:43   #729 (permalink)
Bass&Trouble's Avatar
Which menu are we referring to as "speaker gains"? Does it come up when the 785 is used in "Normal", i.e. front + rear + sub mode?
__________________
Losers Commute. We Ride.
Old 3rd November 2009, 16:33   #730 (permalink)
B&T, we are referring to setting called "Speaker Gain" under the menu which shows up upon long press of "sound" button (next to ISR button). It is only available in 2-way or 3-way modes, not when it is set to "Normal". (I am using 3-way mode, too)
PS. To be more clear, refer to page number 21 of the manual. It has a range of 0 to -20 dB for each channel.
Old 3rd November 2009, 17:16   #731 (permalink)
Understood. That's what I was thinking. It does not show up in normal mode, and I have never used the 785 in 2/ 3-way mode and thus I have never seen it.
__________________
Old 3rd November 2009, 18:17   #732 (permalink)
yogi1771's Avatar
One query will a Ipod with Rockbox firmware work with Ipod ready H.U's.
yogi1771 is offline   Reply With Quote
Old 4th November 2009, 12:43   #733 (permalink)
What's your feedback on this HU, Ajay? (Asking since you get to hear so many different HUs)
Old 4th November 2009, 16:02   #734 (permalink)
Update on Ipod connectivity:
It was difficult to get time to try it out (had received it towards the end of a week long vacation, should have got it in the beginning instead). However, my patience ran out and I did some basic testing yesterday/today.
The bad first- my basic assumption turned out to be wrong. Whenever Ipod is connected to HU, normal controls are seized, only song information and playing status is displayed on it's screen. Just like when it is connected to a PC, only communication possible is through itunes software in this mode. So one can not use text search while it is connected, and (as expected) it is not possible through HU either.
The good part-
1. HU detected the Ipod and seems to play audio files flawlessly. When connected, it can only be operated through HU controls. (This is the latest classic-160GB model manufactured in October 09).
2. HU supprts a major subset of browsing options available in Ipod itself. As mentioned in the manual, you can browse by "Composers" , "Playlists", "Artists", "Albums", "Songs" and "Genres".
3. Up-Down keys on the HU replace Ipod's "click wheel" during browsing. It is easier as compared to normal folder browsing. You can scroll fast in a list by pressing and holding up-down keys, NO need to press them repeatedly! Based on some earlier comments, for normal folder browsing that may not be the case.
4. Ipod's text search CAN be used, though in a round about way- you have to disconnect it first, do whatever search you want and start playing the shortlisted songs list. Then connect it back, it plays only from that list! HU is enough to do basic control actions thereafter, like repeat/random, previous/next song etc.
5. You CAN play apple lossless through Ipod, as expected. So, I hope other lossless formats (wav and aiff) should also be usable.
Old 4th November 2009, 17:56   #735 (permalink)
It's a nice head unit. And its an absolute steal for those that are managing to land these at Rs. 7k odd. It's really feature packed, what with TA, active mode etc.
The sound quality is also fairly good. Not as good as most of the Alpines, but still better than most other gear that we can buy locally. I installed a few of the new Kenwoods recently, and I think this sounds nearly as good.
I hate the looks, controls and the display, and the fact that any of the DSP settings cannot be saved as presets.
__________________
Thread Tools
Illusion Electra 4.1 in Alto - Upgraded with Clarion DXZ 785 USB HU + 6.5 mid bass Technocrat Sound Off and Show Off 110 11th September 2009 14:34
ICE installation - Clarion DXZ785 + CDT + Kenwood santosh.s Sound Off and Show Off 70 27th July 2009 23:37
clarion or alpine? kapilsharma80 Ask the Gurus 14 7th July 2008 09:54
Clarion vs Kenwood: Help needed with ICE jonnyonline Product Discussions 8 29th December 2007 15:56
Alpine CDA-9883 or Clarion DXZ575USB gopz Ask the Gurus 19 8th December 2007 09:41
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
