| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Planning to upgrade the company fitted audio setup in the sail. I already have a Sony HU.. its a CDX 5500. Requirement is to have a crispy clear music. Not much interested in bass, don’t have enough space for them too. Budget is 20k max. Also i want minimum amount of cutting and drilling to be done. So I am planning to use the OEM fitment size as much as possible. After doing some search decided on amp: 4 channel XM-504z Rear: xs-gt6937x (3-way) Front: xs-hf 600g/500g (Component) All Sony... Need suggestion on the setup. Is this good or can be done in any better way? My main problem is fitting this 3-way speaker in rear. With boot space at premium, (some times to keep a large suitcase have to remove the parcel tray) can I also use a component in the rear? If so, then will there be any driver left for the low end bass at all? Had some good feedback about the pioneer from some of my friends. Any suggestion for equivalent of pioneer or any other brand? Thanks, GK |
| | #2 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| the cheapest option is to upgrade the speakers in the front door. if you intend to use the parcel tray, the parcel tray of the sail is a light flexible fiber one. i would suggest replacing this with a MDF one. however the MDF is heavy and the hydraulic hatch will have trouble lifting this tray so you might have to resort to lifting the parcel tray by hand if you need access to the bags in the back. you can see how this will work for you by disconnecting the rubber bands that lift your existing parcel tray. there is an alternate to this but i wont suggest it right now. it is diffcult to say the least and involves fiberglass moulding. once you got the parcel tray sorted out this is what i would suggest. 2 6" woofers in th parcel tray. this wont give you a ton of bass but will supplement the front door and tiny rear pod speakers and 4-5" components in the rear pods. the reason i recomend components in the rear pods is that the pod location is such that if you were to add co ax drivers there the HF of these drivers would be damped. as too the brands i leave this you as this is a matter of taste. one word of caution the sony 504 amp is quite a sharp/harsh amp and you should try reversing the phase of the tweeters in your component speakers. it might just tame it. |
| | #3 (permalink) | ||||
| BHPian | Quote:
| | #4 (permalink) | |
| Quote:
2. yes many. alpine, blaupunkt, jbl, polk, vifa, focal, audax and more. my wife's sail has vifa (4 of them powered by a blaupunkt velocity). 3. the rear pods are the existing locations. 4. a coax driver is one that has the tweeter in the center of the woofer like the sony 6x9 you were considering. a componenet system is a 3 pc system a woofer, tweeter and passive crossover. hope this helps. | |
| | #5 (permalink) |
| one more trick..... if you are getting component speakers. if you can pry open the crossover easily (careful not to break the box it will loose it's ari tight seal) get 2 polyester/polystyrene 0.1mfd or 0.22mfd (uf) / 400V caps (CTR makes them) from lamington road. they are yellow in colour. looked like they care covered in yellow plasticy paper. locate the series capacitor of the tweeter XO. solder the CTR caps in parallel with the exisitng series cap. reason: most XOs use bipolar caps (usually 2 of them in series to make them non polar). these bipolar caps while they do fthe job of filtering well are not as good as polyester caps. however polyester caps of the value they need are expensive. so by using a small value polyester cap you are bypassing the bipolar caps in the critical range. |
| | #6 (permalink) | |
| BHPian | Quote:
I was going thru the velocity broucher too... how much do they cost??? | |
| | #7 (permalink) |
| HU: Alpine 9830 (robbed from my Octavia which was upgraded to a 9833) Amps: Velocity and GTA 450 Speakers: Vifa 5" and 1" tweeter in the front, Vifa 4" and 1" tweeter in the rear pods, 4 modified 6" Vifa woofers in a custom deck. Rear Deck: Original sail deck reinforced with resin bonded fiberglass and damped with lead strips. I modified the deck so that it is light enough to be lifted by the hydraulics (you have to changed the rubber straps that hold the deck to the hatch as well) but stiff enough not to flex or "dance" too much. There is still some work left on it. Crossovers are home made using CTR polyester caps and ferrrite core inductors (air core inductors were too large). XO's one finalised are sealed in epoxy (araldite). For XO boxes I used the boxes you get for visiting cards. Wires are custom made by my brother in law (in singapore) cant divluge the details. As far as the cost of this is concerned i tend to get all mixed up. I am constantly mixing and matching components that we bought for one car with another (not only mine and my wife's, but also my mom's car, my 2 brother in laws cars, and my nephew's car). After a while I cant keep the numbers straight. Somehow I cant stop tinkering. I am fortunate my family tolerates this. :-) |
| | #8 (permalink) |
| BHPian Join Date: Nov 2004 Location: New Delhi
| as a sony fanatic myself, i also leaned towards sony during the installation of my car audio setup at first, until i later realised that sony aint no big in car audio. considering ur budget: HU: Blaupunkt Bahamas -- dont remember the model no. Amp: Sony 504 would do -- since u arnt much concerned abt deep bass -- the velocity would crack ur bugdet -- a decent 4 channel would cost u arnd 18k Front Speakers: Pioneer 4-6" -- dont rem the model no. Rear Speakers: Pioneer 6991 -- Highly Recommended!!! PS: Add Subwoofer to your liking... End of Recipee for a nice Car Audio Setup ![]() |
| | #10 (permalink) |
| BHPian | Got the quote from the sundaram guy... pioneer Amp GM 4000 - 6800 rs front pioneer tweeter ts20 - 2450 rs pioneer 5 inch - 1900rs rear 6990 - 3900rs mdf parcel tray - 1300rs boss kit with r.c cable - 1250rs Are these reasonable? Is there room for bargaining here??? |
| | #12 (permalink) |
| BHPian Join Date: Dec 2004 Location: Mumbai
| Hey krish... here's my 2 cents for ur music sys set up... My zen has an all blaupnkt set-up.. had got it done in early 2001... Jackson HU.... boxed rear speakers and 5 inches front speakers... no amps.. no subs.. no nothing.... and believe me... for a cassette player.. the system rocks..... Lately, here's the set up i have gone in for on my baleno... - Alpine - 9826 HU - audio cd and Mp3.... Co-axial, 3 way rear speaker and 6 inches, 3 way speakers in the front doors... Frankly.. i am quite pleased with the entire set up... costed me around 22 grand.... excellent sound quality.... the MX (media expander option) just magnifies the bass... good equalizer setting options... net net.. JHAKAS!! never been really keen on amps and subs .. simply the marginal utility concept for me goes against it..... cheers |
| | #15 (permalink) |
| let me understand this. you got 20K to spend on amps and speakers in a Sail. htis is what i would do in order of importance. 1. upgrade fronts to good components. Alpine, JBL or Blaupunkt 2. get a bass tube for the trunk 3. get a 4 channel amp 4. upgrade rear speakers all 4 would cost you more than 20K though. just the 1st 2 would make a big difference. |
| Thread Tools | |
Similar Threads | ||||
| Query about car audio system selection | patkim | Ask the Gurus | 3 | 6th August 2008 14:07 |
| Audio Query for Zen | vidvai | Ask the Gurus | 14 | 14th August 2007 11:47 |
| Another M800 Audio query | abhibh | Ask the Gurus | 26 | 15th March 2007 16:24 |
| Audio make query | luvjascha | Ask the Gurus | 29 | 2nd August 2006 03:41 |
| Audio set-up query | luvjascha | Ask the Gurus | 13 | 26th July 2006 13:20 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
