Thread Tools
Old 20th March 2009, 15:45   #1 (permalink)
zacs's Avatar
Default Locked Headunit - KENWOOD
Hi All, I am facing a problem with my head unit in belano. The head unit is a kenwood make. It was all working well and good. But when i did the gas conversion, the battery has been removed and the head unit got locked. I have tried the default password, but didnt work. I really dont remember setting a password for it. Is there any way i can unlock it?
zacs is offline   Reply With Quote
Old 20th March 2009, 17:10   #2 (permalink)
shuvc's Avatar
Sigh !
Same thing happened to my stock Kenwood HU. It was removed to test another HU. When it was re-installed we discovered it was locked. This is apparently a security feature. If I recall correctly (this happened in 2007), the FM still plays, but CD's cannot be played unless it's unlocked.
The dealership where the install was taking place, called up Kenwood service. They said, the passcode must have been provided in a small barcode-type sticker along with the HU manual provided by Maruti. I'm sure I did not receive any such passcode. Maruti dealership had no clue. Was forced to buy a new HU.
There must be some way for Kenwood to dig up the code based on the serial number? I never followed up though.
What default code did you try to use?
__________________
PIGZILNKILJBSCOMB
Old 20th March 2009, 18:37   #3 (permalink)
zacs's Avatar
i dont remember the default code. It was given by one of my friend who works in MAS which was of no use. You were lucky that your FM worked. In my case the head unit is good for nothing as of now. Is it possible to decode it? I dont want to go for a new one unless and otherwise there is no other go. The model no: is KDC-MP 5029V.
Old 20th March 2009, 19:30   #4 (permalink)
phamilyman's Avatar
That is completely weird. Do other HUs have the same issue? If so, Kenwood should be a nono for all of us. Who bothers with HU passwords, anyways?
Old 20th March 2009, 20:19   #5 (permalink)
abhinav.gupta88's Avatar
Locked HU.
Damn thats sad.
I wouldn't prefer a HU with password which autolocks if battery is removed or something.
__________________
vRs(q)® | ECLIPSE CD7200 MKII | Illusion Carbon ND-6 | Harman/Kardon CA470 | Harman/Kardon CA1500M | Stereo Integrity MAG D2 V4
abhinav.gupta88 is online now   Reply With Quote
Old 20th March 2009, 22:14   #6 (permalink)
stefanm's Avatar
You can try one thing, put your head unit in a deep freezer, for 30mins to 1hour, this sometimes unlocks head unit codes and allows you to enter a new code, it doesn't always work but definatly worth a try. I had done this a few years ago on a blaupunkt h/u.
Good luck, if that fails try google maybe an alternative solution could be found.
stefanm is offline   Reply With Quote
Old 21st March 2009, 08:43   #7 (permalink)
zacs's Avatar
stefanm, even i have heard of freezing the HU will unlock the code. But didnt belive coz it sounded that way. Now if the only option left out is to change the HU, then I think its worth a try. BTW what was the result in your case?
Old 21st March 2009, 12:33   #8 (permalink)
stefanm's Avatar
It worked for me, but make sure you keep it well sealed in a couple of plastic bags to avoid moisture, once removed from the freezer( i would recommend 1 hour) leave in for a time to get to room temperature, then give it a try.
Old 21st March 2009, 13:14   #9 (permalink)
zacs's Avatar
will do it tomorrow. Will update on it. Thanks
Old 21st March 2009, 13:54   #10 (permalink)
karankapoor's Avatar
never heard that putting it in a deep freezer can help sounds petty weird and i am surprised that it worked for you (stefen),i hope this will works for zacs also.
__________________
P80RSII l ID Chameleon's l Genesis Dual Mono l ID Max l Genesis Dual Mono EXtreme l Kicker l Connection Audison l Dynamat
karankapoor is offline   Reply With Quote
Old 21st March 2009, 14:01   #11 (permalink)
My guess it that freezing may be erasing some data stored on permanent memories (flash), not so sure. But if that is true, it may clear some other data/settings as well, other than password thingy!
santosh.s is offline   Reply With Quote
Old 21st March 2009, 14:19   #12 (permalink)
@zacs you can try this Security unlock code KENWOOD most models - FixYa
don't know whether this will work or not but found it so.
__________________
Old 22nd March 2009, 15:28   #13 (permalink)
zacs's Avatar
thanks karan for the web link. Hope it works for me. Let me try out this and hence the freezing part is kept on hold. thanks once again
Old 22nd March 2009, 22:43   #14 (permalink)
ankit_chd's Avatar
Shocking , never heard any such thing ever . Though i would never try such thing ever .
ankit_chd is online now   Reply With Quote
Old 23rd March 2009, 00:57   #15 (permalink)
JPL
Seems like breaking the ICE!
JPL is offline   Reply With Quote
Thread Tools
Ever locked the cars with Keys inside? Surprise Shifting gears 154 16th October 2009 17:05
Help - Kenwood KDC - 4028 - locked pin code madan80 Ask the Gurus 12 13th July 2008 13:29
Safari 2.2 Ad - Why/how is the front wheel locked? Venkatesh.C Technical Stuff 38 26th October 2007 13:53
Locked the keys in the car bruce Technical Stuff 40 24th October 2005 02:18
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
