Thread Tools
Old 22nd July 2005, 19:33   #166 (permalink)
navin advani and sam kapasi in 1 thread - my god...is this a auto forum or was i wrong? i joined team-bhp to get away from audio. but there's just no escaping this damn thing!!!
in any case, have fun - welcome to 2 guys whom i know well - sure you'll remember me too. anyways - can u believe, this is probably the longest thread in any of the team-bhp forum threads...and it's on audio - somebody get me outta here...
__________________
to see the world in a grain of sand and heaven in a wild flower...hold infinity in the palm of your hand and eternity for an hour.
cream is offline   Reply With Quote
Old 22nd July 2005, 20:15   #167 (permalink)
navin's Avatar
sure let us know were you wanna go :-) what about this place?
http://www.vexrobotics.com/
Old 22nd July 2005, 22:32   #168 (permalink)
hey, i'm a simple man - still trying to figure out the basics...
__________________
Old 23rd July 2005, 00:27   #169 (permalink)
Vivekphadnis's Avatar
Hi Sam, so Singapore is wet. Picked up anything from there?
I too think the buzzing is a simple case of grounding. It happens to me while building amps at home, this ground loop thing.
Vivekphadnis is offline   Reply With Quote
Old 23rd July 2005, 03:02   #170 (permalink)
Revvmaster's Avatar
Hey Sam/Navin, needed some help with my Wagon-R.
3 months back i installed a JVC XC838 with Soomuku 4 inchers in the enclosures on the dashboard and CS 3360 JBLs on a rear tray fixed to the hatch. Since i just went thru the thread and saw that you were against something of this sort on a Wagon-R, i can't help but agree.
The mid-range volume is actually sounding jarring. And it isn't because of the speakers, but the whole rear MDF vibrating. Even the rear windscreen and hatch judder when my volume is between 18 and 25 (max possible is 48), especially when i listen to some trance and techno music. And its quite loud, drowning the music in the process.
I showed it to my fitter, but he also said that no sound deadening material is possible between the tray and the body which i found a bit hard to fathom. Is there any solution for this problem? I don't want to fit boxes since they eat up space and rear parcel trays will only compound the problem further. What is the solution... help!!
Revv
Revvmaster is offline   Reply With Quote
Old 23rd July 2005, 10:04   #171 (permalink)
navin's Avatar
i have not seen a wagon R maybe Sam has. try this.
what i am visualizing is this. the parcel tray is vibrating as it is not tightly clamped against the rear hatch and/or the sides.
that some rubber strip and run it around the edge of the parcel tray. depending onteh thinckness of the strip you might need to add several layers to get a tight fit.
I dont think this calls for sound deadning material what you need to assure is that the MDF panel is not loose. If the panel is tight and you still have judder (shudder?) you might some frequncies in your music that has the same natual resonance of the rear glass (only the front glass can technically be called a windscreen). If this is case your only sensible option is to turn it down.
Old 23rd July 2005, 11:02   #172 (permalink)
That is exactly the reason I don't believe in parcel trays. If the thing is not fitted properly, the whole thing will create a racket.
I am not sure how this is fitted. But if the parcel tray is in physical contact with the hatch/glass, then the vibration of the tray might be getting transferred to the hatch. My friend had a parcel tray which was not fitted properly. He put his 6x9s in a box and it's smooth sailing all along.
Old 23rd July 2005, 12:16   #173 (permalink)
Sam Kapasi's Avatar
Originally Posted by Ajay
Sam,
Any alternative to the Boss equalizer? and Is it a bad idea to have put the sub on the rear tray?
Appreciate your thoughts.
Hey Ajay,
Primarily, the fewer components you have before your amplifier, the better it is. Equalisers were created to, well equalise, but somewhere along the way, they started doing quite the opposite. Navin will tell you why in great detail I suspect.
In particular, that eq you have offers unnatural boost to the lows and highs. While this may sound exciting to some, it can only create listening fatigue. I NEVER recommend an eq in the car, bad idea. Always better to use the milder and better sound eq settings provided in all good head units.
__________________
Live the YetiLife®
Old 23rd July 2005, 12:19   #174 (permalink)
Sam Kapasi's Avatar
Originally Posted by navin
a-ha my guess is the voice coil of the woofer has gotten mis-aligned or you got dust between the voice coil and magnet. Either way I fear you'd have to get the woofer repaired son. The good guys I knew in this area are dead or retired. Sam can you help?
I can help. Ajay, Please let me know what brand woofer it is and what area of Mumbai you live in. I will suggest a person who will painstakingly open up the woofer and repair it without changing the cone or the spider. However if the voice coil is damaged, my sincere suggestion is to get a new woofer.
__________________
Live the YetiLife®
Old 23rd July 2005, 12:26   #175 (permalink)
Sam Kapasi's Avatar
Buss kya cream
It's just 2 guys doing what they love best. And 1 getting paid for being in audio. heh heh heh. & then ofcourse i pull in the occasional plug for JBL too.
Somehow the team of two just happened. One practical and commercial and the other out and out loony. Mark my words boys, the "Navin and Sam" TV show will be on one day. I can see it now, just like RT sees this thread as the longest Team BHP thread EVER EVER EVER
"N & S - The Audio agony uncles"
__________________
Live the YetiLife®
Old 23rd July 2005, 12:38   #176 (permalink)
Sam Kapasi's Avatar
A pair of Martin Logan Vignettes, a Sony Projector, a really nice toaster
some music and the super duper 12 DVD box set of LOTR & a whole lotta Sh*t for the girlfriend (all the usual, wow so nice stuff) thats all
__________________
Live the YetiLife®
Old 23rd July 2005, 12:52   #177 (permalink)
Sam Kapasi's Avatar
Revv
Hi Revv,
Parcel shelves are stupid. Wagon Rs have wonderful push back seats in the rear, perfect for a snooze or to make out.
Once you fit the parcel shelf in, you cant make out in the rear anymore.
So of course Revv you've done the clever thing and not fit that stupid parcel shelf.
Navin, you've misunderstood he doesnt have a PARCEL shelf, his tray is attached to the hatch! It goes up and down with the hatch rear door.
Revv, this is what you do. Undo the MDF board first, with the speakers etc. Now in the air sandwich between the inner metal panel and outer metal panel, fit some rubber. You know, use an old cut up tyre or those lugs of black rubber used for packing. Navin will tell you where to get exotic materials. Push a few pieces, wedge them in tight. This will greatly reduce the metallic resonance caused inside the hatch door (Which obviously wasn't designed for this). Then take a layer of Heatlon and line the MDF board rear with it. Glue it on with fevicol 989 (AKA jhat-pat)
Fit the board back on. This will definitely improve the ...umm... judder.
__________________
Live the YetiLife®
Old 23rd July 2005, 16:40   #178 (permalink)
srasania's Avatar
Hey wanted to ask something to all you experts - sam,navin,car touch,vivek,and all others..
Well,it might be stupid question..but please forgive me..I really wanna know this -
Everyone knows that sub woofers are fitted in the trunk..and many also fit them in the rear parcel trays..
Ok..now -the question -
I thought for the subwoofer bass sounds to be heard,there shouldn't be any mechanical physical barrier to the flow of the bass sound..well,if we fit in the sub in the trunk in sedans,there are the rear seats,and the woofer is actually totally in the trunk space,while the cabin is with the mids/tweeters speakers..so,how does the subwoofer bass get transmitted to the actual cabin ?!..please excuse me..but I really wanted to ask this question !!..so,if the sub is fitted in the cabin(rear parcel),will the sub sound better?..since it's directly pumpin the bass in the cabin itself?..
I'm sure you experts have an answer to this !..
Thanks guys,
sr
__________________
Driven by Dreams !
srasania is offline   Reply With Quote
Old 23rd July 2005, 22:39   #179 (permalink)
lancer_mania's Avatar
urgent help required i need a setup for the zen and after reading many threads on audio on tbhp i have narrowed down upon this.
rear speaker : pioneer 6990
front speaker : pionner 1610
head unit : not really decided.
so please tell me if this is good enough and the approx proce of each and suggest a good hu but the total should not exceed 11k.
please help.
lancer_mania is offline   Reply With Quote
Old 24th July 2005, 00:18   #180 (permalink)
srasania, Low frequency drivers do not be directed towards the listener. Higher frequencies are directional i.e the tweeter needs to be aimed at the listener.
As for the subs inside the boot, I have hardly seen the insides of sedans. So I dont know. sam, navin, car touch and all others.. over to you guys.
lancer_mania, please, please please don't buy Pioneer speakers. Get yourself Blaupunkt/Alpine/JBL.
Thread Tools
"Car"natic (Fusion and Traditional) Thread indianterrain Shifting gears 0 8th October 2008 00:13
sub enclosure advice from audio gurus clipto333 Ask the Gurus 22 4th January 2007 11:29
The Official "Your Car" Pics Thread v12 Modifications & Accessories 478 16th December 2005 16:00
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
