Old 9th February 2007, 16:17   #5341
clipto333's Avatar
At low levels this is ok. Let me tell you a secret.
I set my Amps to HPF at 50Hz. This way when my car comes back from servicing where they have removed the battery and my HU has lost it's settings I am not feeding my front or rear speakers anythig below 50Hz. A minimum level of protection.
now thats a good idea. ill try it out definitely.
thanks
clipto333 is offline   Reply With Quote
Old 10th February 2007, 22:05   #5342
shrayv's Avatar
Default Swift audio trouble
i own a swift vxi.....
i installed jbl front speakers in the door provision.....
the speakers are installed with spacers between the door and speaker to avoid jarring......
every now and then the speaker hits the door pad and its vibrates....recently i got the car checked and the guy told tht water is comin into the speakers and are gonna get spoilt....
is there any alternative....or a solution?
shrayv is offline   Reply With Quote
Old 10th February 2007, 22:28   #5343
Sam Kapasi's Avatar
Thanked: 971 Times
Hello Shrav
What jbl speakers have you fit in the swift? A Standard 6" speaker fits comfortably into the front and rear door and there is no need of any spacers. I suspect a poor install.
Water getting into the door cavity in a swift? Weird. I suggest you take your car to a Maruti service centre, ask them to open out everything, remove all your spacers and fit the 6" speakers into the OE slots. Then check for water leakage.
Old 11th February 2007, 09:36   #5344
shrayv's Avatar
Default RE: Swift problem
i have a 6 and a half inch jbl speaker...so he put a spacer......how can a poor install cos the water problem.....is there any alternative?
Old 11th February 2007, 16:08   #5345
i have 5850 Pio HU + pioneer oval rear speakers + 1000wats 12 " Jbl Bass tube
+ 500 watts sony Xplod 4 channel Amp....
Now i need settings to my Hu & for Amp(LPF/HPF......Speaker & Sub Gains)...plz guide in details for optimum output.....
ASH-WINS is offline   Reply With Quote
Old 11th February 2007, 18:59   #5346
revtech's Avatar
Thanked: 13 Times
for your amp keep your HPF eaither at 63 Hz or 80 Hz what ever soudns better to you.LPF at 80Hz.
set the gain such that at max volume there is little or no distortion from your sub or speakers...thats the most basic way to tune it.
otherwise take it to a professional and they will do it for you.
remember theres no FIXED SETTING for OPTIMUM OUTPUT.it all depends from system to system and varies according to the taste of different people.
revtech is offline   Reply With Quote
Old 12th February 2007, 02:47   #5347
clipto333's Avatar
Hi Sam,
could you or someone let me know the price of infinity comps and what models are available here? the comps im getting here are out of reach cause i dont have kaanoon ke haath.
thanks
clipto
Old 12th February 2007, 15:53   #5348
Default ICE Settings
Thank you u guys for your generous replies....
Now i want to make settings(Gains) such that Vocal & Treble goes to Rear Speakers &&& Bass Goes to SUB....
So for this, in the Amp
Rear speaker(HPF) = 80HZ or 125 Hz? &&
Woofer(LPF) = 80Hz or 125 Hz?....
Basically i want to know at what Hz(LPF & HPF) the Vocals,Trebels goes to Speaker & Bass goes to Woofer?
Plz guide...
Thanks in advace.
Old 12th February 2007, 16:32   #5349
Sam Kapasi's Avatar
Thanked: 971 Times
I would suggest between 80 to 100Hz. Remember that the same frequency for the LPF and HPF for a smooth transition.
Old 12th February 2007, 16:37   #5350
Default Ice Query
Hi Sam thnz for replying so fast.
U said 80 - 100hz
With that did u mean;
AMP SETTINGS.
SPEAKERS-:HPF + 80-100hz
WOOFER-: LPF + 80-100hz
HU SETTINGS:
HPF : 80-100HZ....
Am i right ...please correct me.
Old 12th February 2007, 17:17   #5351
Speakers should play everything above 80Hz. So, HPF should be set at 80hz.
Subwoofer should be set at 80Hz or 63Hz. Depends on your tastes.
Set the gains between 40% to 70%. Wherever you find a sweet spot.
Old 12th February 2007, 17:23   #5352
Sam Kapasi's Avatar
Thanked: 971 Times
I meant to say, keep the LPF of the woofer at anything you like between 80 to 100Hz. Whatever setting you decide on, the same should apply for the HPF on your speaker.
If you set the amplifier, then it's ok if your HU runs flat.
Old 12th February 2007, 22:53   #5353
navin's Avatar
Thanked: 1,111 Times
the only advantage of setting your amp is that every time your car comes back from servicing you dont have to set it again.
Old 12th February 2007, 23:26   #5354
harmon_bro's Avatar
Guys,
Any comments on the Infinity Kappa Subs(with enclosure)? this is priced around Rs.15k. Is the enclosure ported? Hope this one does not give too much of a boom instead of some tight bass.
Any highlights people....
harmon_bro is offline   Reply With Quote
Old 13th February 2007, 08:47   #5355
Epic's Avatar
Thanked: 27 Times
Originally Posted by harmon_bro View Post
Guys,
Hi Harmon,
I have JBL speakers in my car (Swift) and have the Infinity Ref 1200 (Reference Series) bass tube. I had asked the JBL boys for the Kappa but was told that it was discontinued. However, im pretty happy with the Ref 1200. Is it available in Madras? Do compare the two and let me know.
Epic
Epic is online now   Reply With Quote
OE Replacement - Navigation System for Cruze "Mega Audio" lawyer Sound Off and Show Off 36 15th September 2012 11:43
"Kicker" audio setup in my Hyundai Sonata Frankenstein Sound Off and Show Off 9 4th March 2011 13:35
Car audio losing sound at low rpms! EDIT : Solved by "The Steg" GTO Ask the Gurus 162 23rd November 2010 17:27
sub enclosure advice from audio gurus clipto333 Ask the Gurus 22 4th January 2007 10:29
