Thread Tools
Old 14th April 2007, 10:57   #5716 (permalink)
navin's Avatar
Originally Posted by s0uljah View Post
as soon as the install was over it is shwoing the problems of Alternator whine and amp clipping. ...It seems the gain is set to hardly 15%. The RCA's are the new MX ones...they cut off half the strands as it was too fat.. this is dangerous right
1. I did not know MX made Auto grade wire. Auto wire needs better insulation becuas ehte environment is more noisy (electrical noise). Change cables and check.
2. If yo connect the speakers in series you willl find the amp has a easier load. It wont be as loud but atleast it will be clean. You'll need to crank the gain up as well.
3. shaving off a few strands is NOT dangerous.
4. LBM is right, that amp is really a sub amp.
__________________
Scixelsyd Etinu
Old 14th April 2007, 11:36   #5717 (permalink)
s0uljah's Avatar
Originally Posted by low_bass_makker View Post
the amps is giving 370 x 2 at 2 ohms....if it giving such power you are bound to blow your speakers if played at high volumes....
Thats the the when he called me I told him its probably not the amp clipping but the speakers will blow first. Anyway today I will meet and witness what is going on then try to troubleshoot one by one based on what you said.
Originally I had planned for stinger/monster but it wasnt in his budget. The MX is supposed to be double shielded cables anyway will ask the guys in the shop to replace
This is what I had suggested in the first place but they have gone and done somethign crazy, not quite sure what!
Will post back what happened. Thanks
__________________
"Its not the size, its the heart, so dont hate... Accelerate !!!"
Old 14th April 2007, 16:39   #5718 (permalink)
been reading the thread for a while now, and have decided on the head unit, the Pio 7950. also looking for a good pair of 6x9 for the rear, i currently have some sony xplod ones but problem is that one of the tweeter cone is ripped, and am not sure getting it repaired will give me the same quality, if it does then well and good.
this is to be installed in a Zen, the older one, will be adding a amp and a sub next month, amp i can get from US as my cousin will be coming next month, so suggest something for about or less than 6K INR and will get a wiring kit as well.
speaking of which is it advisable to get the HU as well from US coz the 7950 wud cost about 12-13k ~ 250$, I read in a similar thread that its not advisable since the FM frequencies are different, is there any way to bypass this? coz i would rather get it something better from US for the same amount if possible than buy it locally..
One more thing i need to ask is where i can check the phone compatibility list for the 7950 via bluetooth, currently own a P800 and wanted to check if both are compatible.
TIA
Rave is offline   Reply With Quote
Old 15th April 2007, 00:00   #5719 (permalink)
s0uljah's Avatar
Talking
for whine try any other RCA....just temp to check that it is not faulty......and the HU ground connection....as it can also be the culprit.....
So the guy came by with the car and the whine disappeared after grounding the HU with some copper wire like in the pic...
Re sound/clipping it was just a bad tuning on the part of the shop guys. Got rid off the +6 Low/Mid/High on the HU as well as Loud
We spent some time fiddling with the HU at high volume while moderating the amp gain till it sounded just right to his tastes. Ran the HPF on the HU at 50 as it suited him.
Iv suggested a 75.4 to him at the time he adds a sub so that the system is more efficient.
__________________
Old 16th April 2007, 12:34   #5720 (permalink)
Default Help on audio system for Wagonr
Just wondering whether U could guide me in selecting an audio system for my Wagon r Vxi with ABS and Air bags (I heard it needs extra precautions in playing with electric connections and install).
Budget is < 20,000 and I am more interested in good rather than loud music. Also would like a USB connection to listen to my collection of MP3s and audio lectures. I am seriouly considering Blaupunkt for HU, Speakers. I am in Lucknow so may not have many choices I guess.
Please advise. Thanks.
Prof is offline   Reply With Quote
Old 16th April 2007, 14:13   #5721 (permalink)
navin's Avatar
Originally Posted by Prof View Post
Just wondering whether U could guide me in selecting an audio system...Budget is < 20,000...
There is a sticky on this subject that might help.
Do you intend to use a sub (and sacrifice boot space)? Do you need the bass.
Do you intend to use the stock locations for the speakers? I understand that the Wagon R front stock locations are in the dash.
edit...
I thought about this a bit and figured that if you can get door speakers then a HU (8-9K), 5-6" coax door speakers (4K) and a pair of 6x9s (5K) on a MDF rear deck (1K) can suffice.
__________________
Scixelsyd Etinu
Old 16th April 2007, 22:48   #5722 (permalink)
s0uljah's Avatar
I think the deh-p5950 is a great option for the tight budgets as it comes with necessary functions and 3 outs. Grey prices are quoting approx 7k
__________________
Old 17th April 2007, 06:21   #5723 (permalink)
mithun's Avatar
A HU dealer told me that Pioneer 3950(cost :Rs.4900) which is having a sub output will produce more quality sound without the need of any subwoofers/amplifiers using the coaxial speakers than the entry level Pio MP3 Player(cost :Rs.4700).
He told me that one of the reasons for the better output is the presence of the sub out !!!
Is that a stupid statement OR Is there any truth in that since he told me that there is an internal difference among the HU's ?
PS : I didn't argue with that guy because I was in a hurry.....
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 17th April 2007, 14:20   #5724 (permalink)
determinus's Avatar
Originally Posted by mithun View Post
A HU dealer told me that Pioneer 3950(cost :Rs.4900) which is having a sub output will produce more quality sound without the need of any subwoofers/amplifiers using the coaxial speakers... Is there any truth in that since he told me that there is an internal difference among the HU's ?
I think you didnt read the second part of the title of this thread
Anyways, a low end HU hardly makes 12-15w RMS. And the "direct sub drive" option does make some sound. But more quality sound? Depends on what's quality For a purist, when a bridged channel amp of same wattage cannot make "great" sound compared to a mono, how can a puny HU surpass that? It is just a marketing gimmick.
__________________
"Reality continues to ruin my life"
determinus is offline   Reply With Quote
Old 17th April 2007, 14:27   #5725 (permalink)
Bass&Trouble's Avatar
I dont think his question is exactly as you have interpreted it.
The guy selling him the player is saying that the unit with the sub pre-out will sound better than the unit without the pre-out, without asking him to use it. In any case, a pre-out is not the direct sub drive section.
It could be true, but not because of the presence of the pre-out. The unit with the sub out could have additional features like some additional EQs, HPF etc which could help configuring the system as opposed to the base model. But with respect to the transport, output section etc, I doubt there would be any difference. Anyway, since the difference is so little, go for the higher model. Always handy for an upgrade.
__________________
Operator! Give me the number for 911!
Old 17th April 2007, 15:03   #5726 (permalink)
edit...
Thanks buddy for the answer. Clarifications: 1) I couldn't locate the sticky you mentioned. 2) I don't need heavy bass (and hence no sub, I guess..?) 3) I want some product officially available in India. 4) Can I fit these speakers in the front doors? Is it better than in the provided space in Dash of Wagon R? 5) "MDF rear deck?" Are these speaker boxes? Occupying space in the back? U see, I am quite a novice (in this area!) and hence these queries. Thanks again.
regards
Prof
Old 17th April 2007, 16:02   #5727 (permalink)
mobike008's Avatar
What would be the most economic ( pls read without compromising on quality) amp to drive the following:
JBL 1204BR ( 1200 Watts) Subwoofer in an enclosure & JBL 12" bass tube?
I am confused between the above two subs which one to go for? As i like a the bass to sound nice and crisp as well as it should be atleast a little boomy
Can the same amp power both subs?
I am thinking of the following amps that can do the duty for both subs.
Pio 6100/6200
JBL 60.2 ( Is it available?)
Blaupaunkt ( Which 2-channel model would be good?)
__________________
[b][i]The nail that sticks out gets hammered !!!
Old 17th April 2007, 16:18   #5728 (permalink)
hydrashok's Avatar
@mobike008, between the two subs, the 1204BR might sound better to you. It is a ported sub, so it will be between a sealed enclosure and the Tube as far as boominess is concerned. On a line with a sealed box on one end and a bass tube on the other, the 1204BR will be a bit nearer to the sealed in terms of definition and boominess. You might find the Tube a lot boomier than the 1204BR.
All that said, you should listen to both before you make a decision. Since both can be just plugged-in easily for testing once an amp is in place, it would be quite easy to audition both inside your car itself.
The same amp should be ok for either (as both are essentially ported designs). The tube will respond slightly better to the same amp than the 1204BR, I think.
Going for a Pio 6200/6100 is likely to be more VFM as it is a 4-ch amp, and it will cost just 2K to 3K more than the JBL or Blau 2-ch amps.
I think the JBL CS60.2 is available, but I'm not positive. I remember seeing it on rediff.com sometime back.
The Blau GTA275 should be fine for either sub.
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 17th April 2007, 16:47   #5729 (permalink)
mobike008's Avatar
Hydrashok, tks for your prompt response. I agree with you that the same amp would do slightly better duty on tube than on the ported sub.
So i will check with GTA275 for both subs and then decide the sub and amp.
My installer is propogating against pioneer, saying Sir, pio is not what it used to before when i asked him for PIO6100
Since i already have a 4 channel amp driving my rear and front comps, i guess it makes sense to go for a 2 channel or do you suggest i go for the 4 channel pio6100?
Finally, some pricing tips would really help
__________________
Old 17th April 2007, 16:58   #5730 (permalink)
hydrashok's Avatar
You already have a 4-ch amp? Then a 2-ch amp or a mono amp is what you should get now. Don't get a 4-ch amp.
The Blau GTA275 (2-ch) is about 6K.
The JBL CS60.2 is about 6K.
The JBL GTO301.1 (mono amp) is about 12K
The Pio D510 (mono amp) is about 10K
The Sony 552 (2-ch amp) is about 4K (since it is for a sub, and if you're on a real tight budget, you can think of it -- but if you can extend the budget, don't get it).
Else, if you can get a good price for your current 4-channel, sell it/exchange it and get a JBL 75.4 (4-ch amp, 13K). But if you don't get a good price, don't bother with this.
The Pio 6200/6100 sound quite decent for the money spent. Wayyyyyyy better than the Sonys (which are of course priced lower).
__________________
Thread Tools
"Car"natic (Fusion and Traditional) Thread indianterrain Shifting gears 0 8th October 2008 00:13
sub enclosure advice from audio gurus clipto333 Ask the Gurus 22 4th January 2007 11:29
The Official "Your Car" Pics Thread v12 Modifications & Accessories 478 16th December 2005 16:00
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420
