| LinkBack | Thread Tools | Search this Thread |
| | #5836 |
| Team-BHP Support ![]() Join Date: Feb 2004 Location: New York
Thanked: 928 Times
| Comps??? Its a 4" speaker in Alto's stock location |
| | #5837 |
| Distinguished - BHPian ![]() | |
| | #5838 | |
| BHPian Join Date: May 2006 Location: Ramanathapuram
Thanked: 52 Times
| Quote:
Navin, can you suggest me good rear speakers for my HU (pioneer DEH-2950MP) ? when i inquired in a shop, they say its no use going for speakers like JBL P552 or Pioneer E1396. and they said even if i do go for it, i have to get an amp. please advise. | |
| | #5839 |
| | #5840 | |
Thanked: 52 Times
| Quote:
HU - Pioneer DEH 2950MP Front Speakers - Pioneer TS-G1011R No amps and no subs need help to decide about rear speakers Budget - Around Rs 5000 I am also planning to install a 60 litre LPG gas Tank in the boot, so not much space there. Now please suggest me a good rear speaker. both make and model. ![]() | |
| | #5841 |
| Team-BHP Support ![]() | With your combination harshavarthan within 5K I guess the JBL GTO937 will be the best bet. These are 6X9 ovals. there are 2 ways to install this in the santro. place them in boxes fixed to the side wall of the boot. that way you still have space to put the lpg tank below the speakers. the other way is to place them on a mdf parcel shelf at the rear. this will also allow you to place the tank but if you have any bags which are tall they will not fit above the tank. |
| | #5842 | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
Thanked: 1,111 Times
| Quote:
Now about the "clipping". that happens becuase your front speakers cant handle the bass (not the power). So any amp with a HPF will work. Why even a simple passive bass blocker (just a couple of capacitors) will work too. You can DIY you own bass blockers for under Rs. 100. | |
| | #5843 |
| Senior - BHPian | the next question will be how to make them.... ![]() use the required capacitor for the required cut-off freq..... like for a 100 hz cut off use a 400 MFD capacitor....if the electrolyte model is used....connect two 200 MFD with there negative ends and connect it between the speaker and the amp.... |
| | #5844 |
Thanked: 928 Times
| Thanks Guys ![]() @Sam: Thanks for the advise but am afraid the 552 doesn't come with HPF My HU has HPF at 50,80 & 125Hz But using it from HU will put the HPF for rears as well right? Btw am currently running HPF at 125hz @Navin: Thanks, any reason why you suggest another 554 when I already have a 554 which is a 4 channel amp? As about building myself a bass blocker hehe am not so electronically litrate. @LBM: Thanks for the diagram although beling not so technical I cant understand much of it :|Btw if I take the diagram once posted by Sam & again here by LBM to an electronics shop guy will he be able to make it? Also will just putting this bass blocker eliminate the need for amp ? |
| | #5845 | |
| Quote:
the 554 is only 2K more than the 552 and will match your existing 554 besides you can bridge the 554 to give your front speakers some real power. | |
| | #5846 |
| Senior - BHPian | here is the picture again hope you can understand this one clearly.... ![]() |
| | #5847 |
| BHPian Join Date: Nov 2006 Location: New Delhi
| Hi, I have a Sony CDX-GT460U HU. I want to know about Carphone and if my HU is compatible with it. While on my recent trip to UK, I found my uncle using his mobile phone and the callers voice was coming through the car speakers. Also, the music got to mute whenever he was making a call. When I asked him, he said it was fitted as an OEM in his Merc. Do we get such utilities in India, without a Bluetooth enabled HU. [COLOR=#606420][/COLOR] |
| | #5848 |
| | #5849 | |
| Quote:
for more info on new products and HUs see http://www.team-bhp.com/forum/produc...-2007-a-8.html (New ICE products for 2007.) | |
| | #5850 |
| Senior - BHPian | |
Similar Threads | ||||
| OE Replacement - Navigation System for Cruze "Mega Audio" | lawyer | Sound Off and Show Off | 36 | 15th September 2012 11:43 |
| "Kicker" audio setup in my Hyundai Sonata | Frankenstein | Sound Off and Show Off | 9 | 4th March 2011 13:35 |
| Car audio losing sound at low rpms! EDIT : Solved by "The Steg" | GTO | Ask the Gurus | 162 | 23rd November 2010 17:27 |
| sub enclosure advice from audio gurus | clipto333 | Ask the Gurus | 22 | 4th January 2007 10:29 |
