Thread Tools
Old 7th July 2007, 18:47   #6451 (permalink)
Sam Kapasi's Avatar
Originally Posted by nitrous View Post
Does that mean that there won't be any significant difference between the OE Ford Speakers and the 507Cs?
Oh there will be a huge difference lol, don't worry.
__________________
Live the YetiLife®
Old 7th July 2007, 18:50   #6452 (permalink)
speedzak's Avatar
Location: Delhi. Travelling as usual! Mumbai was great.
Infractions: 0/1 (4)
Ofcourse Rey!
How can you ask a question like that?
__________________
A very big THANK YOU, Bombay!
Will miss you guys! :(
speedzak is online now   Reply With Quote
Old 7th July 2007, 18:58   #6453 (permalink)
nitrous's Avatar
Cool!
So 507C,it is!
__________________
2004 2005 2006 2007 2008 - 5 consecutive titles.
Arguably,the best the sport has ever seen!
Old 7th July 2007, 19:22   #6454 (permalink)
clipto333's Avatar
hi navinji,
since you do fibre glass work yourself, i thought i would ask some questions and get some advice.
can you give me some tips on FG. would like to know what ratio you use for the resin and hardener. also would like to know from what kind of store i can get the FG raw material and wht do the stores call the raw fibre mat, in their terminology. i want to do some FG work on my car(little work for a start).
would be thankful if you could answer my queries and point me towards some FG sites on the net.
thanks in advance.
clip
clipto333 is offline   Reply With Quote
Old 9th July 2007, 14:47   #6455 (permalink)
navin's Avatar
the fiberglass mat is bought by my company in 100 meter rolls I just cut what I need for my use. From what my colleague who handles inventory tlls me what i take is less than what we waste in scrap so I dont pay for the fiberglass mat.
The resin is bught from jewel polymers. it is first mxed with throughly mixed with an acclerator (in this case the acclerator is also suppkied by jewel) 1% v/v and just before pouring is mixed with catalyst also supplied by Jewel in 1% v/v.
Jewel recommends 1.5% but i find that that hardens too fast and I dont get enought time to spread the resin properly over the mat.
hope that helps.
__________________
Scixelsyd Etinu
Old 9th July 2007, 17:39   #6456 (permalink)
clipto333's Avatar
hope that helps.
hi navinji,
good for you i can use as much paper and corrugated board as i want but i guess thats not stiff enough(im a manufacturer of corrugated boxes) ;-) .
ok ill try the combination once i get my hands on the FG raw material. i guess it isnt available here in my city so now my plans for delhi are firming up.
i have to get some other stuff as well(true rms DMM, LCR meter, Caps etc and FG). sam you mentioned bhagirath palace for the electronic and electrical stuff right?? any other place if i dont get the above stuff from there?
thanks
clip
Old 9th July 2007, 19:06   #6457 (permalink)
DerAlte's Avatar
hi navinji,
thanks
clip
You need to go to Lajpatrai Market, which is right opposite the Red Fort bus stop (south/west-bound buses). You have to go in past the Band shops (like Hindu Jia Band, who will play the compulsory Delhi version of Tequila) into the corridors inside. (Bhagirat Place, where you get electrical fittings like lamp shades etc. is further down the Chandni Chowk road behind the movie theater on the right - I forget the name).
[OT: there used to be a legendary joint called Omji Cafe in LR Market, who would serve up the meanest piping hot Channa Bhatura anywhere in Delhi. Don't know if it still exists - if it does, give it a try]
An alternate place to do a search for the meters et al would be Nehru Place in South Delhi (near Kalkaji) - you could ask the computer parts shops and they would be able to guide you, if *they* don't have it.
Navin-ji, since "Jewel" might be marketing only locally in Mumbai area, what is it that we should be asking for? Or rather, if we hear it, for what should we say "No, not that. I want ..."? I don't think I will be understood if I say "diglycidol ether of bisphenyl A, with polyamine hardener"
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 10th July 2007, 00:31   #6458 (permalink)
Wimwian's Avatar
Originally Posted by Sam Kapasi View Post
Hi JPL,
I hope you are well.
For the front (If I remember correctly, you have a santro) 427. No enclosure for the 4" speaker, can be used for mids and highs only.
On the CS60.4 front channel:
Bass Boost off.
HPF on.
HPF frequency - 120Hz-150Hz.
Level, about a little over half (Change as per taste later)
Blaupunkt Ovals in the rear
CS60.4 rear channel
Bass Boost off
HPF on
HPF frequency at 70-90Hz
Gain at a little under half. (Change as per taste later)
GTO1204 Bass-Reflex Box
connected to CS300.1
Bass Boost off
LPF is always on in monoblock, so no need for LPF HPF setting
LPF set at 80Hz
Gain: Keep at half and change later after you playback.
Nothing I say is writ, as this will depend on your taste. But this will serve as a basic guide.
Sorry If I sound like a moron, but I have some basic questions.
I have a 60.4 which drives JBL607c in the front and JBL637 in the rear... if I want the front compos to produce more bass, which setting do I tamper with first? should I still keep HPF on? currently HPF is on, BB is off, gain is a tad less than half and I have no idea what the frequency setting is... how much can I safely increase the gain without compromising speaker health? Also Sam has mentioned keeping the front frequency at 120-150, can this be reduced to say 80 or so for components?
tia
Wimwian is offline   Reply With Quote
Old 10th July 2007, 10:33   #6459 (permalink)
navin's Avatar
i just asked for polyester resin (bakelite hylam makes the same stuff but Jewel is cheaper). jewel is based in the mumbai area, a village/town called palghar but Der Alta you are right the technical term is bisphenyl something. I'll have to read the details from their packaging so that I get it correct.
__________________
Scixelsyd Etinu
Old 10th July 2007, 12:06   #6460 (permalink)
nitrous's Avatar
Gurus,
I got the 507C components fixed in my ikon.
They're being powered by the HU.The front and rear signals from the HU are bridged to adequately power the components.
About my experience, I love the difference in treble which is more than i expected.
The bass is lesser than I expected.I like tight bass which i feel rather than hear.The woofer is sounding like a hollow drum which i dont prefer.
I'd like to know if im expecting too much from the 5.25" component woofer.
Thanks in advance.
__________________
Old 10th July 2007, 12:10   #6461 (permalink)
vid6639's Avatar
Gurus,
Thanks in advance.
You cannot bridge the front and rear of the HU. it is not at all advisable as the HU internal amp is not designed to be bridged. This may damage your HU.
__________________
\ / ][ |) `/ [_] "!"
vid6639 is offline   Reply With Quote
Old 10th July 2007, 12:19   #6462 (permalink)
nitrous's Avatar
Yikes!
The installer said he's never done this before.But, i made him do it anyway!
Can i get a second,third and fourth opinion??
__________________
Old 10th July 2007, 12:22   #6463 (permalink)
navin's Avatar
Modern HU amps are not designed to be bridged. I am surprsied that the HU did not blow already.
I am sure Sam, LBM, Gunbir, B&T, Der Alte and other gurus will chip in soon.
__________________
Scixelsyd Etinu
Old 10th July 2007, 12:46   #6464 (permalink)
Sam Kapasi's Avatar
tia
Nothing moronic about your question. The simplest way to increase the bass from your components is to lower the frequency of the HPF. Going to 75-80 is OK.
__________________
Live the YetiLife®
Old 10th July 2007, 12:46   #6465 (permalink)
nitrous's Avatar
Ok, ill remove the bridge asap.
Thanks,gurujis!
About my other query?
__________________
Thread Tools
"Car"natic (Fusion and Traditional) Thread indianterrain Shifting gears 0 8th October 2008 00:13
sub enclosure advice from audio gurus clipto333 Ask the Gurus 22 4th January 2007 11:29
The Official "Your Car" Pics Thread v12 Modifications & Accessories 478 16th December 2005 16:00
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444
