Old 11th July 2007, 13:18   #6511
Bass&Trouble's Avatar
Thanked: 45 Times
Originally Posted by low_bass_makker View Post
Why you can get hold of Ajay for the Steg and for the Sub I am going to change them as soon as I get the one I am searching for....
In case you didnt yet get the drift, he wants your Steg and sub for free. Exactly why he's better off hounding you for it.
Old 11th July 2007, 13:18   #6512
nitrous's Avatar
Thanked: 143 Times
Originally Posted by navin
do you get no bass? did you check the phase of the speakers. if they are out of phase the bass will cancel.
Bass is there.But,the thump isn't.
Am i expecting too much from the 5.25" drivers??
Old 11th July 2007, 16:08   #6513
navin's Avatar
Thanked: 1,111 Times
thump at low-moderate levels is possible. but thump as in "12" Pio in free air" thump just wont happen.
what you can get albeit at low levels from a good 5" woofer is well defined midbass.
Old 11th July 2007, 19:30   #6514
moralfibre's Avatar
Thanked: 1,353 Times
Originally Posted by Sam Kapasi View Post
This MF is looking for a way to adjust his active crossover. No relation to the EQ.
Sameer! thanks for the detailed explanation.
Dekh LBM, Ajay understands quicker than thou .
Old 12th July 2007, 00:43   #6515
razor4077's Avatar
Thanked: 35 Times
Guys,
Need to decide on what front components to get for my Lancer. Had pretty much decided on JBL GTO607c's, but found them a tad bright (i.e, high on treble) in a friend's car. Even after fiddling with the eq. settings on the HU, it remained a bit much for me.
What other options do I have in that range? Comps that are not as bright, but have a comparable overall quality as the JBLs?
Hertz, Pioneer, Kicker....?
Any suggestions will be appreciated. Need to make up my mind asap.
Thx!
razor4077 is offline   Reply With Quote
Old 12th July 2007, 00:56   #6516
iraghava's Avatar
Thanked: 75 Times
They are a little more expensive but why don't you try Infinity's & see if you like them?
Old 12th July 2007, 01:01   #6517
Thanked: 216 Times
you can also try the illusion audio components they are also good. I have heard them in Mugen_Power Innova install and they were not bright. but I would comment them as smooth.
Old 12th July 2007, 01:17   #6518
razor4077's Avatar
Thanked: 35 Times
@l_b_m: getting them in cal will be a problem. also, how much would they cost? i'm talking about the model in a similar range to the 607c.
@ishan: i did listen to an infinity setup, but that seemed a little bright too (not sure what the eq. settings were though). read on some sites that they are pretty bright. have u heard them?
How about DLS components? Are they good (SQ, brightness etc)? Any ideas about the cost and model no. of comparable products?
Old 12th July 2007, 10:15   #6519
Dhar's's Avatar
Gurus,
I have a pair of Infinity Kappa 42.7i (2 ohm rated), Pioneer TS-A6991 (4 ohm rated I think). Can i connect these to JBL CS60.4 amp? Please advice.
Found this Power series loaded enclosure in web site. Thought I'll share with you.
Êîðïóñíîé ñàáâóôåð P-1220BR
Dhar's is offline   Reply With Quote
Old 12th July 2007, 10:19   #6520
Sam Kapasi's Avatar
Thanked: 970 Times
Hi Dhar,
Yes you can. No problem.
Old 12th July 2007, 10:36   #6521
Dhar's's Avatar
Thanks Samji.
The JBL P1220BR is available in India? Just curious.
I think it has option for neon tubes inside.
Old 12th July 2007, 10:45   #6522
moralfibre's Avatar
Illusion has launched a new series named the Electra Series and I heard them in Bass&Trouble's car. For Rs. 6,490/- they outclass many speakers at twice the price. The 6x9's sound as subs and cost Rs. 5250/-. The 12" DVC sub at Rs. 5,250/- is an absolute steal when it offers 400W rms! PM Bass&Trouble for more info. I have heard this setup run on a very very basic amplifier from Ground Zero and it sounded perfect for my listening tastes.
Which series did you hear? The 2007 series are less bright than the eariler ones.
Old 12th July 2007, 10:53   #6523
Thanked: 216 Times
the Illusion audio comparable to JBL 607 is for 6.4k that is Electra series very good component kit.
About the DLS , I happened to listen to there classic range and it was a very bad experience , yes guys the classic range of DLS is not liked by me as the tweeter was very bright even more than the JBL 607 , but the rest of the things were good. ok mids and good midbass.
Old 12th July 2007, 11:28   #6524
Dhar's's Avatar
The Ex series in Electra says 'reverse magnet technology'.
Any idea what does that mean?
Old 12th July 2007, 11:41   #6525
Thanked: 45 Times
Here is a link that shows the 'reverse magnet' based speaker in three views.
diyAudio Forums - illusion audio nd-12 and infinity beta 300
It is a unique driver design, where the magnet is a neo magnet (hence much smaller than a comparable ferrite magnet), and mounted on the front of the speaker rather than behind to reduce the mounting depth to nearly half. There are other speakers that use this design, and more that will use it in the future, besides Illusion Audio.
Currently, the Lucent and Carbon series use such an arrangement for all speakers and subs, with the exception of the compression horn, of course. The EX series is not productionized. The EL series is the ferrite motor equivalent of the Lucent series.
OE Replacement - Navigation System for Cruze "Mega Audio" lawyer Sound Off and Show Off 36 15th September 2012 11:43
"Kicker" audio setup in my Hyundai Sonata Frankenstein Sound Off and Show Off 9 4th March 2011 13:35
Car audio losing sound at low rpms! EDIT : Solved by "The Steg" GTO Ask the Gurus 162 23rd November 2010 17:27
sub enclosure advice from audio gurus clipto333 Ask the Gurus 22 4th January 2007 10:29
