| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #691 (permalink) | |
| BHPian Join Date: Mar 2005 Location: Navi Mumbai
| Quote:
Thanx a lot all. Sam, Already Spoke to BM in VAshi .He currentely does not have 636e in stock. I have requested him to get them so I can go and hear them. It looks like mostly I will do the install myself. First will have alook at the car setup ( after I take a delivery). Somehow I am more comfortable with that idea. The last guy i Used to change my front speakers has just used a shorted fuse and put some wire around it. I found this out when the cabin light started doing disco randomly.
__________________ It is never too late.- get your safety options right | |
| | #692 (permalink) | |
| BHPian Join Date: Jul 2005 Location: Delhi
| Quote:
| | #693 (permalink) |
| Hi Sam, still considering between CS 50.4 amplifier and the Sony 504Z. Of course it all boils down to money, but willing to spend that extra buck to get the sound after already being heavily invested. Doing some research on the 50.4 and found that its RMS is 67 Watts. Now I have components in front which can handle this output. But I am concerned about the GTO 636 in the rear. Going through their specs I found: Manufacturer JBL Model GTO626 Size (inches) 6 1/2 Type 2-Way Speaker Price $99.95 pair Sensitivity 90 dB Frequency Response 55-21,000 Hz Recommended RMS Power 60W Peak Power Handling 180W Impedance 4 ohms That their RMS is 60W, so will they be able to handle 67W. The salesperson discouraged me to bridge 2 channels in parallel and two to the tube. He recommended just going with 2 channnels dedicated to the components, and other two channels bridged to the tube. He said that the GTO 636 if amped, will spoil the whole sound of the system... please shed your DIVINE light on this. |
| | #694 (permalink) | |
| Quote:
Hi, Aseem, First of All are these 626 or 636 U are refrring to second is it thye same setup where u want to run your rear speakers and woofer in parallel. U can easily run the rears in my opinion for following reasons 1. It is unlikely you will max out the power to rear all the time unless u feed a monoaural sound continuously to it. It that sound level you will not only be able to handle it forget about the speaker 2. It is unlikely that U will be running the system on peak power , unles u like to park the car in open spaces and party with the car system on 3. All manufacturers provide design tolerances to accomodate safty marging when publishing the specs so I think 10 % reserve is easily available and lastly I think withy gain control you can limit the sound going to the back assuming u are uisng them only for fill ( may be Navin can comment on this) SAM your views on this please?
| | #695 (permalink) |
| BHPian Join Date: Jun 2005 Location: Bangalore
| Nothing will happen if the amp is feeding more power to the speakers. But if the speaker is higher rated and you are increasing the volume to push the speakers hard, there will be trouble. As long as the amplifier can handle the impedance of the speakers it will be okay. Go strictly by the recommended speaker impedances. It does not matter if you connect a hundred speakers but the impedance should be the recommended one. Of course, you cannot connect a hundred speakers. In technical terms, gain is the ratio of output to input voltage or current. When you talk about the voltage gain of an amp, you are talking about how much the input signal is amplified. This is a rough explanation. If the amp has more gain, there is more amplification.
__________________ Thank God for DIY audio. |
| | #696 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
DIN, XLR, etc... now occupy niche markets. For those of us like Vivek we would prefer if XLR (pref. balanced) was the standard but like i said before you cant always get what you want but it if try sometimes you get what you need. Monster in a Marketing phenomenon sort of like Silly Putty and the Pet Rock. Belden makes beautiful cable and is often cheaper than Monster. For those (like my sister's hubby) who roll their own cable Belden is God. That is was available in India was a pleseant shock to me. Thanks Sam. | |
| | #697 (permalink) | |
| Quote:
| | #698 (permalink) |
| Aseem a 9830 for 12.5K this will kill all HUs in the price bracket. All you guys are worrying about the electrical/thernal limitations of speakers (60W, 100W etc..) when it is the physical limitations that are often the real limiting factor in a speaker's SPL capability. Both the 626 and 636 have 6" woofers right? Assuming the Xmax (linear one way) is about 5mm you will run into physical limitions in a car somewhere in the area of 10-20W at 50Hz. Now dont get worried. At 10W a 90db/1W/1m speaker will be producing 100db/1m. That might not part your hair but will drown out all external noises including maybe your own car's horn. So as long as the amp is putting out more than 40W rms (0.01%, 20-20k) clean you can run most commonly available 6" speakers. for larger drivers you need more power but that is a different thread. |
| | #699 (permalink) |
| BHPian Join Date: Aug 2005 Location: Gurgaon
| I bought a Alpine Cda-9851 from JC Road in Bangalore for 15K and the guy there suggested to put Boston Comps. which costed around 5k. I went and saw his Boston Equipment Fitted car(A Accent). He had a set of Comps in the front, co-axials at the back and 2 - 2000 Watt Woofers driven by independent Amps. and to drive the Comps and Coax's he had a separate Amp. Believe me the Sound was just Awesome.
__________________ <[quote]Chance always favours the prepared mind> |
| | #701 (permalink) |
| BHPian | how would the performance of the Boston Components be in the rear..just being connected to the Sony 5510X.. Here are the specs of the Sony 5510X : CDX-F5510X * S-MOSFET Output Power: 52Wx4 * FM18/AM12 * New Drive-S Deck * CD-R/RW Playback * Pre Out: Front + Rear/Sub Switchable * EQ3 (3-Band Equalizer/7 Modes) * Bass/Treble (Low/Mid/High) * Low Pass Filter * Attrac3plus Dont remember the Model # of the Boston Comps...was told that it would cost around 5k..
__________________ kya !! sab theek hai ??? |
| | #703 (permalink) |
| Does anyone know whether the Alpine I-POD interface unit KCA 420I willl work for a Creative Nomad Jukebox-40GB which is a similar kind of a MP3 Player. I require this info. urjently so, please let me know if anyone has any idea.
| | #704 (permalink) |
| Sam please help me on this........Does anyone know whether the Alpine I-POD interface unit KCA 420I willl work for a Creative Nomad Jukebox-40GB which is a similar kind of a MP3 Player. I require this info. urjently so, please let me know if anyone has any idea..........its urgent because i have asked my brother in Canada to get me the KCA-420I |
| | #705 (permalink) | |
| Senior - BHPian | Quote:
.. I am planning to call them up sometime next week.
__________________ "As long as there are short, balding, middle-aged men, there will always be a market for the Porsche 911." - A BMW Owner. :) | |
| Thread Tools | |
Similar Threads | ||||
| "Car"natic (Fusion and Traditional) Thread | indianterrain | Shifting gears | 0 | 8th October 2008 00:13 |
| sub enclosure advice from audio gurus | clipto333 | Ask the Gurus | 22 | 4th January 2007 11:29 |
| The Official "Your Car" Pics Thread | v12 | Modifications & Accessories | 478 | 16th December 2005 16:00 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
They also do home audio/home theatre and sell monster cable etc
