Thread Tools
Old 29th August 2005, 00:26   #706 (permalink)
navin's Avatar
the KCA420I is for Ipods only. it is also one the reasons i chose the ipod over the iriver. i wanted to see the ID3 tags on the Hu display and control the ipod from the HU. I still have not found the KCA 420i in India however. I need 2. one for each HU/car.
Old 29th August 2005, 10:58   #707 (permalink)
k_ajay's Avatar
Originally Posted by aseem
Hi Ajay and All, I feel so dissapointed. Having gone for Sony 8800 for 14k, I just found out that a shop in JC road bangalore is selling Alpine 9830 for 12.5k with bill and warranty. Ajay if you have not already bought the system than buy it from JC road car market after the Lal Bagh road. This is not fair, as the Sony sound sucks in front of an Alpine :(
Aseem, mere bhai.... Late ho gaya.... I went to B'lore yest, got the 9833 from Pritam[JBL Showroom] and i'm back home now..... I didn't have access to a comp and aaab, late ho gaya.... but its alright.... I still feel i've gotten a decent deal..... at 19k with Bill and Alpine warranty....
__________________
"If you don't follow your dreams, you might as well be a vegetable" - Burt Monro
k_ajay is online now   Reply With Quote
Old 29th August 2005, 12:02   #708 (permalink)
Did you enquire if he was giving the 9830 with bill and warranty for 15k? The reason I ask is that we are getting it without bill and warranty, and Navin the shop owner had called Pritam, and Pritam told him that they were not giving 9830 at 15k with bill.
aseem is offline   Reply With Quote
Old 29th August 2005, 12:04   #709 (permalink)
navin's Avatar
ajay, there is always be a better deal just after you buy your gadget. such is life. my family got 5 ipods in a week from the same store in Heera Panna with prices raning from 22k to 20.5K and now the prices is sub 20K.
Old 29th August 2005, 12:12   #710 (permalink)
Sam Kapasi's Avatar
Originally Posted by pingmepal
Fiat Petra 1.6 ELX Petrol version (I could have entered simple Petra, but this board requires minimum of 20 characters :-))
Then 426e is not the correct size for a petra. 426 is a 4" you need a 5.25" for the petra. You need 526e
__________________
Live the YetiLife®
Old 29th August 2005, 12:25   #711 (permalink)
Sam Kapasi's Avatar
. I am concerned about the GTO 636 in the rear. Going through their specs I found:
Manufacturer JBL
Model GTO626
Size (inches) 6 1/2
Type 2-Way Speaker
Price $99.95 pair
Sensitivity 90 dB
Frequency Response 55-21,000 Hz
Recommended RMS Power 60W
Peak Power Handling 180W
Impedance 4 ohms
That their RMS is 60W, so will they be able to handle 67W. The salesperson discouraged me to bridge 2 channels in parallel and two to the tube. He recommended just going with 2 channnels dedicated to the components, and other two channels bridged to the tube. He said that the GTO 636 if amped, will spoil the whole sound of the system... please shed your DIVINE light on this.
The specs you have are of the 626 not the 636. And the 636 work fine with an amp.
__________________
Live the YetiLife®
Old 29th August 2005, 12:29   #712 (permalink)
Sam Kapasi's Avatar
Originally Posted by moodswings
Sam please help me on this........Does anyone know whether the Alpine I-POD interface unit KCA 420I willl work for a Creative Nomad Jukebox-40GB which is a similar kind of a MP3 Player. I require this info. urjently so, please let me know if anyone has any idea..........its urgent because i have asked my brother in Canada to get me the KCA-420I
I dont think the i-pod interface will function properly on a product of any other brand. I dont think so
__________________
Live the YetiLife®
Old 29th August 2005, 12:40   #713 (permalink)
navin's Avatar
ref: post 706. A friend of mine in Europe tried to interface the 420 with an Iriver and it did not work. the 420 according to alpine is for ipods only pref. 4G ipods. actually according to alpine germany the decks made for the ipod are the 9851 and 9853 with glide touch.
Old 29th August 2005, 12:42   #714 (permalink)
navin's Avatar
i really wish i could upgrade the 9830 and 9833 to the 9855 but the numbers are just not worth it. resale on 1 year old 9830 and 9833 is not much.
The 9855 is really the technical equivalent of the 9833/9830 as it has 4V pre out. dont know why alpine killed the 4V pre out in lesser models. even the 9830 has 4 v out.
BTW the 9855 retails for $400-450 in the US.
The 9830 sells for about $250 there is Rs. 12.5K in Bangalore. so local prices are fair.
Old 29th August 2005, 12:54   #715 (permalink)
Hi Sam, Welcome Back. We missed you soo much here. Below is the spec for GTO 636:
Features:
  • Oversized Plus One Woofer Cone
  • High-Roll Butyl Rubber Surround
  • 1" Edge-Driven Kaladex Tweeter
  • 1/2" Kaladex Supertweeter
  • Intermount III System for Easy 6 3/4" and 7" Fitment
  • Mounting Hardware and Grilles Included
3-Way Speaker Specifications
Sensitivity: 90 dB
Frequency Response: 55-21,000 Hz
Recommended RMS Power: 60W
Peak Power Handling: 180W
Impedance: 4 ohms
Also below are the specs of CS 50.4 JBL amplifier:
Features
High Output PWM MOSFET Power Supply
Gold-Plated Speaker & Power Connectors
Streamlined, Black Casing with Silver Accent Corner Pieces
Variable Low-Pass and High-Pass Crossovers (32-320 Hz)
12 dB / Octave Crossover Slopes
Variable 6 dB Bass Boost
RCA Line-Level Inputs
Preamp Outputs
Fully CEA-2006 Compliant Power Ratings
Multi-Channel Amp Specifications
Amplifier Type: Multi-Channel
RMS Power @ 4 Ohms: 67W x 4
THD at 4-Ohm RMS Power: <1 %
Bridged RMS Power @ 4 Ohms: 143W x 2
Speaker Level Inputs: Yes
Preamp Outputs: No
Built-In Crossovers: HP/LP
Bass Boost: 0 - 6 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: 86 dB
Fuse Rating: n/a
Below for Sony 504 Z:
Amplifier Type Multi Channels
RMS Power at 2 Ohms 60 W x 4
RMS Power at 4 Ohms 50 W x 4
Bridgable Not Bridgable
Performance
Frequency Response 5 Hz - 50000 Hz
Signal to Noise Ratio 100 dB
THD at Rated RMS Power .01 %
Crossover / Equalizer
Bass Boost Without Bass Boost
Other Features
Input Voltage 10.5 volt
MOSFET Circuitry Yes
3 Way Ready No
Dimensions
Width 13.88 in.
Depth 9.25 in.
Height 2.25 in.
Miscellaneous
Product ID 22571974
I am getting the Sony for 4k and the JBL for 7k. I have the following questions.
1) Now that I already have a Sony HU and 606E components in front and GTO 636 in the rear. I am getting slightly harsher music than I am used too. I am ok with it, and in time will love to enjoy it. My criteria of songs is Eminem, 50 cent, etc. However I want to maximize my remaining system and sound. The shop owner who was selling JBL amp discouraged me to use 2 channel for the JBL amp in parallel for four speakers, rather insisted that I just amplify the components and use the other two channels in the bridged mode for the tube. He said that GTO 636 if amped will distort the music. Now I will take Sam's word for this not his. As for me Sam you are the one So what do you suggest? The RMS of the JBL amp is 67 watts as opposed to Sonys 60 W, and 636 have mean handling RMS of 60 watts? So will this mean that Sony is more ideal for the 636 setup than the JBL?
2) You had suggested that I should not use the CS 50.4 for the tube/woofer as its not designed to run them, however power wise, it is giving more output than the Sony in bridged mode? So even though CS 50.4 is not designed for woofer/tubes, but given the specs it will drive the woofer/tube better than the Sony 504Z in question here?
Sam you are the undisputed Audio Guru here. Any information that you will share with your deciple will go down till his grave. Looking forward for your answer
Old 29th August 2005, 13:03   #716 (permalink)
Sam Kapasi's Avatar
Aseem ya, what is this guru disciple stuff. Chill, we are all friends here.
As you can imagine, I've seen those specs often before. I never recommend a CS50.4 to run subs. It sounds great, but unlike cheaper amps, all JBL CS50.4 have clip-limiters built in. Now as Vivek and Navin have rightly pointed out, very often, more power is never an issue. However when a lesser powered amp is over driven, it creates clipping. Some of us cannot recognise this clip. When the CS50.4 clips, it reduces power, or sometimes goes off. The cheaper sony will play regardless, clip and all.
There is no doubt that the JBL amp is better, i'm not that biased. However if you need to overdrive an amp, even a little, the JBL will not co-operate with you. That is why i just find it safer to suggest that the 50.4 is no good for a sub.
I recommend the 75.4 for that.
I repeat that the 636 sounds nice on any amp. Like Navin said, it is a 6" woofer and will sound better on any amp.
__________________
Live the YetiLife®
Old 29th August 2005, 13:07   #717 (permalink)
Vivekphadnis's Avatar
Sam, Navin, this is what I found. I ripped apart (and successfully put back ) all the plastic panels below the AC switches and the ignition. I found 12.23 V on a thick white wire with a green stripe (and black) soldered on the ignition switch. I removed the harness on the autocop and found that it had 12V between the pure red wire and the black wire.
Yesterday, I checked out my friend's Wagon R. The guy who fitted it seemed to have connected the battery of the HU to some thin wire he has found on one harness just behind the place where you fit the HU. I found the ground and the ignition but this battery wire is eluding me. Please understand that I am very keen on doing this myself not to save a trip to the electrician or save a couple of hundred rupees but just for the thrill of doing it myself. DIY spirit you see
__________________
Thank God for DIY audio.
Vivekphadnis is offline   Reply With Quote
Old 29th August 2005, 13:11   #718 (permalink)
moodswings's Avatar
Thanks Navin and Sam......I will ask my cousin not to get it...
__________________
<[quote]Chance always favours the prepared mind>
moodswings is offline   Reply With Quote
Old 29th August 2005, 13:15   #719 (permalink)
navin's Avatar
aseem, see post 697 and 698 regarding power handling of speakers.
Old 29th August 2005, 13:24   #720 (permalink)
navin's Avatar
Vivek, the last time in installed a system was in 1996 so i cant help oyu here. my back wont let me get into all those contorted postions anymore.
Aseem, it is great that you put all that info on this thread but seriously it is information overload. You have to discern what information is nesscary and what is not. I know you have the knowledge to do that. To run all your speakers without straining your amps it is recomended that the loads not be below 4 ohms in stereo mode and 8 ohms in bridge mode.
some amps can handle 2 ohms loads without complain and other can but with some restrcitions but it still nicer on the amps if they are run as said above.
If I were you and wanted most bank for the buck I'd get teh 50.4 or 340 for the 4 speakers and run the sub of 502. total will be 9.5-10K (7K for the 50.4 and 2.5-3K for 502). too rich. get the 504 and 502 for 6.5K. still too rich get the 504 and add another amp later.
Thread Tools
"Car"natic (Fusion and Traditional) Thread indianterrain Shifting gears 0 8th October 2008 00:13
sub enclosure advice from audio gurus clipto333 Ask the Gurus 22 4th January 2007 11:29
The Official "Your Car" Pics Thread v12 Modifications & Accessories 478 16th December 2005 16:00
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
