| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #7396 (permalink) |
| Newbie Join Date: Dec 2007 Location: Mumbai
| Hi all, After a lot of reading and help from the gurus, i finally ICED up my new optra magnum. Here are the details: AMPLIFIERS: 1) Earthquake T2000W/4 4 channel amp Max Power output: 2000 Watts RMS Power 4-Ohm Bridged: 2 x 300 RMS Power 2-Ohm Stereo: 4 x 150 RMS Power 4-ohm stereo: 4 x 100 Damping Factor: >800 Cross over slopes: 24dB/OCT THD: >0.005 SNR: 90dB Class: A/B 2) JBL GTO301.1 II 300-Watt Mono Subwoofer Amplifier Front Door Components KICKER AUDIO DS- 600.2 Woofer Size : 6" (160mm) Tweeter Size : .75" (20mm) Dome Material : Titanium Rated Impedance : 4Ohms Max Power : 120W RMS Power : 60W Sensitivity 90dB Effective Frequency Range : 43-20kHz High Pass : 12dB/4000Hz Low Pass : 12dB/4000Hz High Frequency Output Attenuation, dB : 0,3&6 Rear Door Components MTX AUDIO Thunder Dome-Axial TDX5202 5-1/4” Coaxial Cone Polypropylene Tweeter 20mm Soft Dome Pivoting Tweeter Yes Impedance 4 Ω Frequency Response 55Hz-20kHz Power (RMS) 45 Peak Music Power 90 Sensitivity @ 2.83V 92dB SUBWOOFER Kicker TCVT12-2 Car Audio 12" Shallow Enclosure Box • Width (inches) 21-3/4 • Height (inches) 13-7/16 • Depth (inches) 7-1/8 • Second Depth (inches) 3-15/16 • Connector Type Spring posts • Frequency Response 25-350 Hz • Power Range (Watts RMS) 50-400 • Maximum Wattage 800 • Sensitivity 98 dB • Impedance 2 ohms HEAD UNIT JVC KW-AVX800 Power Output:200W Max. (MOSFET 50W X 4), 20W X 4 RMS 7" Wide Touch-Screen Monitor Rear USB Port for Video and Audio playback from Flash Memory Drives, Digital AUdio Players and Portable HDD Devices up to 10 GB Capacity Ready for Bluetooth® Wireless Technology Built-In SD Card Slot GIGA MP3 Multi 7-Band iEQ/High Pass Filter Ready for iPod* In Conjunction with KS-PD100 SAT Radio Ready* MP3/WMA/WAV/CD/CD-R/CD-RW Compatible with ID3/WMA Tag DivX Ultra® Certified JPEG Display DVD-R/-RW,+R/+RW/Multi-Border Compatible Built-In 5.1 Channel Decoding Front/Rear/Sub/Center/Video Outputs AV Input Terminals Shock Proof Memory WallPaper Setting Amp Defeat Motorized Faceplate Steering Wheel Remote Ready* HS-IV Tuner Telephone Muting *Requires additional Accessories The above system ROCKS!!! Apart from this I got the teflon coating done, V-KOOL sunfilm, Reverse parking sensors with voice guide, Rear View Camera fitted to the registration plate which activates as I shift into reverse gear. Im quite happy with the installation. Total cost is about Rs. 75000/- Will try and post pics soon Cheers SUNNY |
| | #7397 (permalink) | |
| BHPian Join Date: Oct 2007 Location: Kolkata
| Quote:
| | #7398 (permalink) | |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| Quote:
Meanwhile any specific suggestion towards AMP and Sub? How to wire it, config: Front Comp + Rear Ovals + 8" sub ? Should i change the wiring also? right now the OE (inbuilt) wiring is used for the 4 speakers. Anyway i have to do an upgrade might as well do it proper. I will have to wait till new year for changes since the weekends are booked till then.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin | |
| | #7399 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
for a swift your best option would be to consider a spare wheel sub.
__________________ Scixelsyd Etinu | |
| | #7400 (permalink) |
| and sad. how much should be the min outer ring dia for a 8" ?Wheel well here i come, let me see if ulta position of tyre can be done, again hope i dont have to remove the clamp, which i really want to avoid
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin Last edited by Jaggu : 11th December 2007 at 15:32. |
| | #7402 (permalink) | |
| Quote:
Old Pioneer KEH P705 (HU) Very Old Pioneer CDX P1220S (12 CD changer) Rear 6x9 (Oval) GTO 937 * 2 Front Component GTO 607 C * 2 http://www.team-bhp.com/forum/long-t...tml#post414012 (The DIESEL experience! Swift VDi) I might change the HU and CD changer for a better HU also. Looking at the MDF board i feel i have around 3.5" to spare compared to the 6*9 speakers, so am wondering if the 8" will squeeze in. As another option i was thinking if a bass tube (even a custom one) which is placed vertical on one of the sides maybe a good idea? Is there any rule for mounting bass tube? Bump on the previous question of wiring configuration, as well as to retain the existing wiring or rewire completely?
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin Last edited by Jaggu : 11th December 2007 at 16:00. Reason: base .. bass | |
| | #7403 (permalink) |
| Team-BHP Support ![]() | How much of Base are you really looking at ? I mean if you dont want to go to sub level freuencies then get any of the current generation of Pio HUs as they allow the rear speakers to be used as small subs i.e. only lower frequencies are passed to rear & they are controlled similarly like a Sub(i.e. all the setting available for sub can be used.) I am suggesting this becasue I suggested this to a few of my friends & they seemed to be happy with the outcome since they didnot want loud thumps & also didnt want to go for amp & sub. The 6X9s produce some really nice base if used properly. As for wiring, better wiring never hurts. A friend changed to Monster cables & the results were noticeable & he doesnt even have an amp.
__________________ The Holy Trinity: Traction, Torque and Tarmac Last edited by Technocrat : 11th December 2007 at 16:13. |
| | #7404 (permalink) |
| i think my unit also has the function that you have mentioned, i think its Front image enhancing (FIE) function you are referring to. That is fine but it spoils the sound staging is what i felt. After this install in swift i really didnt try it though, let me give it another try today. ![]()
| | #7405 (permalink) |
| Team-BHP Support ![]() | Yes FIE was in Casssete Players(Had this in My dad's Car too) & in few CD playesr as well but the way it is done in new Ones is much easier & more effective as in they have HPF & LPF controls with gains settings Anyways try it out & let us know :-)
__________________ The Holy Trinity: Traction, Torque and Tarmac |
| | #7406 (permalink) |
| My player has this as well as the new ones (CD/MP3) have the FIE settings along with HPF & LPF.
| | #7408 (permalink) | ||
| Quote:
As far sa you HU and cd changer go the selection is vast and I think you know engouh to choose what you want Right? Quote:
Is this true? Is Jaggu slowly turning into LBM? :-)
__________________ Scixelsyd Etinu | ||
| Thread Tools | |
Similar Threads | ||||
| "Car"natic (Fusion and Traditional) Thread | indianterrain | Shifting gears | 0 | 8th October 2008 00:13 |
| sub enclosure advice from audio gurus | clipto333 | Ask the Gurus | 22 | 4th January 2007 11:29 |
| The Official "Your Car" Pics Thread | v12 | Modifications & Accessories | 478 | 16th December 2005 16:00 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417
