| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #7801 (permalink) |
| BHPian | ya i have decided to put illusion 6.1 compos. am trying to find sources who can do the door trim cutting, damping and fitting job. then i can use the rear setup just as a filler. well i think you should listen to my new setup and suggest. the GT5-12" sub is a thriller.
__________________ " I dont Drive Fast , I Fly Slowly " |
| | #7802 (permalink) |
| BHPian Join Date: Jan 2008 Location: Mumbai
| For a hatch that is driven 100% by me, what would the gurus suggest as rear speakers? 6x9 (with a decent bass without a sub woofer) or just a sub woofer (e.g. bass tube)? Please note that these are either/or choices for me I mention a bass tube as it somewhat fits the budget vis-a-vis 6x9 in the similar price range (~Rs 5k) My listening preference is not a very boomy or ear drum shattering bass. But just enough to complete the sound stage at the rear, and bring out the lows for listening pleasure. I am not too well versed with technicalities of sub woofer box design. Also, I tend to think of the bass tube as a one-stop-ready made-solution (please correct me if I am wrong). Boot space is somewhat important as I have frequent trips and some luggage space is necessary for me. EDIT: Front stage is components
__________________ If the speed of light is 3x108 m/s, what's the speed of darkness? Last edited by nishantgandhi : 1st April 2008 at 12:59. |
| | #7803 (permalink) |
| BHPian Join Date: Aug 2006 Location: New Delhi
| If 5K is your budget, you can manage a decent sub in that. It will give you a better sound than a boom box, and will also be less clunky (i.e. a sub can be removed much easily or adjusted to fit luggage etc. than a bass tube). As for 6x9 vs. sub, as I told you earlier, please do educate me also once you have an answer! ![]()
__________________ In memoriam: My Signature. Censorship 01 Vebmetal 00 |
| | #7804 (permalink) |
| BHPian | Try decent 6x9s powered by an amp first. If you really miss the sub, you can add that later. I personally have not really needed it so far. I don't like loud bass either. Soft, yet deep (if that means anything at all in audio terms ) and thats served well by the 6x9s.
__________________ Sameer, Bangalore |
| | #7805 (permalink) |
| Senior - BHPian | 1. Cost: Adding a sub will double your cost since it needs an amplifier. 6X9s can be driven off the HU. 2. Boot Space: You will need to compromise the boot space with a sub. Since you say it is a hatch and you require boot space, I would second the opinion of having 6X9s and then thinking about sub if you really want it.
__________________ ... Everything should be made as simple as possible, but not simpler |
| | #7807 (permalink) | |
| Quote:
What I gather from the above mentioned replies is that it cant be an either/or choice. Am I correct in my interpretation? So does this mean that a sub woofer serves as an addition to 6x9s? I thought they could be used as a substitute. i.e. if 6x9s serve the purpose of rear fills only and just to reproduce the lows. Correct me if I am wrong
__________________ If the speed of light is 3x108 m/s, what's the speed of darkness? Last edited by nishantgandhi : 1st April 2008 at 14:48. | |
| | #7808 (permalink) |
| BHPian | I enquired for Pioneer 2950 HU at shop next to Mariyappana palya park, Bangalore (Bangalore west guys would know this shop!, which is on the right side coming from Navrang to Malleshwaram) and he quoted 4K without bill and warranty for this HU. Is this shop reliable to buy? or is their any other shops i can look for buying this HU. I'm in need of a cheap HU which is worth the money! Thanks. Ramki ![]()
__________________ Silky Silver Maruti Suzuki WAGONR 2007 - Done 5K Kms. 2003 TVS Fiero F2 - Done 45K Kms. |
| | #7809 (permalink) |
| I think it's a either / or situation for you since you are planning on getting an amp anyway. So cost wise you don't save anything by going for 6x9s as opposed to going for a sub (btw for your benefit we are leaving bass tubes out of this dscussion). AFAIK the difference is this: 6x9s will give you a wide range of frequencies - from highs to lows. Like your components, but the bass will be a little deeper. A sub on the other hand, will only give you the low end, but a much more thorough range of low frequencies. So it depends what you want to do with your rear fill: Do you want the same sound in the back that you get with components in the front (albeit with better bass), or do you want your ICE to reproduce all the frequencies from the highest to the lowest (meaning you will get a thump). That's the question to answer, and it is totally up to personal preference. There is no right or wrong answer. And as you guesses, some people eliminate this choice by putting both. (You auditioned Ajay's WagonR, right? I think that has both).
| | #7810 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Quote:
Since the shop you buy from will generally not provide A.S.S. of any kind, it really does not matter where you buy from, as long as the price is right. Just make sure you get the whole package (incl. manual, extraction tool, any cables etc. that come in the original box) and not only the HU.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | |
| | #7811 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
2 6x9s will have as much surface area as a single 12" woofer but a 12" woofer is degined to produce deep bass while 6x9 are designed to produce more midbass than deep bass. If you need rear fill get the 6x9; no sub is going to give you rear fill. If you dont need rear fill and are willing to sacrifice boot space get the sub; few good subs will be outdone (in the bass) by a pair of 6x9s.
__________________ Scixelsyd Etinu | |
| | #7812 (permalink) | ||
| Quote:
Just one more query - AFAIK, a component in the front door will be able to produce mid and highs. Will 6x9s produce the remaining part i.e. lows (in order to 'complete' the sound)? From veb's answer, this seems to happen in case of 6x9s.
__________________ If the speed of light is 3x108 m/s, what's the speed of darkness? | ||
| | #7814 (permalink) |
| BHPian Join Date: Nov 2007 Location: mumbai
| Requirement of Bass (Advice to give a freind) Suggestions for SUb 10-12incher which has sealed enclosure volume reqd of only upto 0.75CU ft MAX (need to fit the sub under the car seat!) Amp can supply only upto 200rms- Alternatively Method 2 Is there any possiblilty of fitting a 6*9 on old Santro rear door? Whats advisable method 1 or method 2 regaurds Ali
__________________ An expert is someone who takes a subject you understand and makes it sound confusing. |
| | #7815 (permalink) | |
| Senior - BHPian | Quote:
__________________ tinypic.com/player.php?v=35mo01l&s=4 | |
| Thread Tools | |
Similar Threads | ||||
| "Car"natic (Fusion and Traditional) Thread | indianterrain | Shifting gears | 0 | 8th October 2008 00:13 |
| sub enclosure advice from audio gurus | clipto333 | Ask the Gurus | 22 | 4th January 2007 11:29 |
| The Official "Your Car" Pics Thread | v12 | Modifications & Accessories | 478 | 16th December 2005 16:00 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
