Thread Tools
Old 29th August 2005, 18:20   #781 (permalink)
navin's Avatar
position the sub close to the sub amp and all you need is 1 meter.
Old 29th August 2005, 18:24   #782 (permalink)
k_ajay's Avatar
Navin, just curious. What all do you have on your RS? I know you have the 9833, what else? Mind sharing?
__________________
"If you don't follow your dreams, you might as well be a vegetable" - Burt Monro
k_ajay is online now   Reply With Quote
Old 29th August 2005, 19:46   #783 (permalink)
moodswings's Avatar
Originally Posted by moodswings
Aseem can you calculate for me the total cost of the following parts:
1. Front JBL 6"components.
2. Jbl Co-Axials and oval Kenwood at the back(Which i already have, had cost me 5.5k).
3. One Good Amp. to drive the Components and the rear 4 speakers.
4. I already have a 500W/1000W(dont rem.) its a 12" Pioneer woofer but I will add a bass tube or the 1000W JBL or the 2000W Boston.
5. Again a good amp to drive the woofers and the Bass Tube.
6. Alpine 9833 I have bought for 14K.
7. Belden Wiring all the way.
8. and dont forgett the Kick panels for all 4 doors.
Please check if I am missing anythings.
Mood and this shall not be my state
Is the below costing approxx. Aseem:
Front JBL 6"components-> 5600/-
JBl Co-ax-->>3400/-
two amps-->>15000/-
jbl woofer---->>>7500/-
belden wiring--->2000/-
alpine 9833-->>14000/-
kikpanels---->>5400/-
Total--------->>52,000/-
__________________
<[quote]Chance always favours the prepared mind>
moodswings is offline   Reply With Quote
Old 29th August 2005, 19:52   #784 (permalink)
JBl Co-ax-->>3400/-
two amps-->>15000/-
Dude I am not sure about the kick panels. Check them out. Here is peace of price qoute below:
JBL GTO 636: 3500 (with bill and warranty--- cheaper in gray)
JBL 606E: 5650 (with discount--- MRP 6000---dont know about gray)
JBL CS 50.4: 7000 Rs (To drive the speakers)
Sony 502Z: 2500 (To drive the woofer)
Belden Wiring: Depends, since you have Qualis thus you probably need more wire length.
Alpine 9833: 14000 Rs (gray)
Rest order a Pizza from pizza hutt and get a coke free. Da Da Da Dee Pizzaa ayee free.
aseem is online now   Reply With Quote
Old 29th August 2005, 19:55   #785 (permalink)
moodswings's Avatar
I have a Scorpio n not a Qualis....
__________________
Old 29th August 2005, 20:05   #786 (permalink)
pranil's Avatar
Default Check Voltage
Originally Posted by Vivekphadnis
Sam, Navin, this is what I found. I ripped apart (and successfully put back ) all the plastic panels below the AC switches and the ignition. I found 12.23 V on a thick white wire with a green stripe (and black) soldered on the ignition switch. I removed the harness on the autocop and found that it had 12V between the pure red wire and the black spirit you see
Simple rules to find battery.
1. With your key out the volatge 12 V should still be available.
Normal poinst where this wires will lead to in - Ingnbition switch or emergency blinker push button. Trace it back from there.
Emergency Blinker is your best bet.
__________________
It is never too late.- get your safety options right
pranil is offline   Reply With Quote
Old 29th August 2005, 20:08   #787 (permalink)
navin's Avatar
not much. alpine 6" comps in the front, 4" comps in the rear. 2 small 8" blapupunkt tube subs powered by a home made amp built around hitachi plastic case mosfets putting about 35 w rms per channel x 4 channel - i dont know the bridge power as i have never measured it. the amp runs bridged with 4 channels bridged into 2 for the 2 subs.
the alpine speakers are powered by a alpine 540 amp. i also have a necvox 10 DVD changer and a single necvox hread rest screen for my son's DVDs.
the 2 small subs were becuase the truck still have to have room for all my family incl my sons bike etc.... so it is only the smaller crevasses that have been commisioned for the sub.
I have had more in my single days. a lot more. incl one car that had 3 10" woofers in a tranmission line.
Old 29th August 2005, 20:09   #788 (permalink)
navin's Avatar
BTW my wife is not ignored. her system is a 9830 -> blaupunkt velocity / blaupunkt GTA 450 -> 5" vifa comps in the front, 4" Vifa comps in the rear, 4 6" Vifa woofers on a custom tray (in her Sail).
Old 29th August 2005, 20:15   #789 (permalink)
navin's Avatar
If you had me that question on 26/7 i would have said "a lot of water".
Old 29th August 2005, 20:19   #790 (permalink)
moodswings's Avatar
Got a deal on 9833 with Bill & Warrantty(Read Sam's comments so I insited on that) for 16k
__________________
Old 29th August 2005, 20:25   #791 (permalink)
navin's Avatar
excellent. mood. where did you get that from?
Old 29th August 2005, 20:27   #792 (permalink)
The shop is Add On and its on JC road/Bangalore... The owners name is Navin.
Old 29th August 2005, 20:33   #793 (permalink)
zzzehar's Avatar
Hi Guys
I wanted to know if there is any other alternative to Pioneer 5750 in the Budget of Rs 7000 - Rs 8000? Consider the features and Specs of Pioneer, If there anything other HU that would match the Pioneer 5750 in the same budget? Thank you.
__________________
Hero Jet
Atlas MTB
Hero Honda Splendor 100 CC
Daewoo Matiz
Tata Indica V2 DLS
zzzehar is offline   Reply With Quote
Old 29th August 2005, 20:34   #794 (permalink)
Navin, how much did the Necvox 10 DVD changer cost you and where did you buy it from? Did you buy it from US? The reason I am lil concerned about buying a DVD player from US is that they might not be region free and might not play our DVD's, but want to know from your experience.
Old 29th August 2005, 20:37   #795 (permalink)
navin's Avatar
nah i got it here. at bharat auto. i dont remember what it cost but it was not much. i'd have to check my papers to find that out in any case prices change so fast. no issue with my sons DVDs though finding Nemo and Madagascar et. al work fine so far.
Thread Tools
"Car"natic (Fusion and Traditional) Thread indianterrain Shifting gears 0 8th October 2008 00:13
sub enclosure advice from audio gurus clipto333 Ask the Gurus 22 4th January 2007 11:29
The Official "Your Car" Pics Thread v12 Modifications & Accessories 478 16th December 2005 16:00
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
