| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #7936 (permalink) | |
| BHPian | Quote:
@SAM sir, I agree with you but sir there is no data slip or anything as such. i think its the HU that reads the buffers from the usb and the cd differently. Can someone please confirm with pioneer hows the conversion and why there is a difference?
__________________ " I dont Drive Fast , I Fly Slowly " | |
| | #7937 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
2. every input source is processed differently. Tuner, USB, CD, why if you had a turntable you'd need a RIAA processor. This processing might be the reason. 3. my guesstimate it that since USB was "invented" by computer companies like Compaq, DEC, IBM, Intel, MS, NEC, and Nortel they wanted to reduce any aliasing errors so rollled of the HF as it was an easy solution. Data would nto care if the HF was there. Now you are using a data protocol to transfer music but the chips in the HU does not know that. They still believe that they are part of a data network. This is one reason why I wonder 8702.3 (ethernet was not used). Ethernet can handle gigabits today (and could handle 10Mbps at the time USB was invented - '94-95) 4 of the 8 wires on the RJ45 sockets were not being used anyway; they could have been used for power. Hey RCA beat out DIN and XLR so go figure.
__________________ Scixelsyd Etinu | |
| | #7938 (permalink) | ||
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Quote:
Both the sources work asynchronous with the CODEC (the chip that decodes the mp3 stream; not the HU) and that is why the buffers! This is an OO system and the CODEC reads from the buffer, and reads either buffer the same way (Oy, CODEC is a preprogrammed chip, not a human; since pins are limited, the read bus is the same for both the sources). Quote:
If the buffers are not replenished on time (BUFFER UNDDERRUN), or NOT READ on time (BUFFER OVERRUN), bits of music passages go missing - resulting in the 'skips'. Underrun can happen when the CD is scratched or there is too much noise affecting the USB transmission (too many retries). Overrun can happen only if the mp3 file (correctly read off the source) has too many encoding errors in it, and the CODEC, instead of getting enough time to read the buffer, spends more time in trying to decode the stream. If the decoded output from the CODEC does not contain enough of high frequencies, it is not the fault of the CODEC - but of the encoding of the file ("ripping").
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! Last edited by DerAlte : 19th April 2008 at 12:45. | ||
| | #7939 (permalink) | |
| Quote:
Still I do believe that given that USB was developed by computer companies they might have tripped over the handling of frequencies over 10Khz.
__________________ Scixelsyd Etinu Last edited by navin : 19th April 2008 at 12:58. | |
| | #7940 (permalink) |
| Senior - BHPian | What is good single/double din DVD HU to get? Budget for HU 10-15K, gray market. i do not want one with a screen upfront as it would distract the person driving, going to get a roof mounted 10" lcd for the rear view. Have my gto 506 components from the honda for the front, and will be choosing between the 607c and the illusion electra speakers for the rear. Would be getting a JBL 604 amp for the speakers. The setup is for an Innova. manson.
__________________ Robin |
| | #7941 (permalink) |
| BHPian Join Date: Feb 2008 Location: Pune
| If at all you have a doubt that USB is the cause of sound quality replinishing there is another way you can compare. Why not check it in your computer or say a laptop. Connect your earphones or say any external source of Music system to your computer but make sure its of good quality. Play the CD first and compare the same song by playing it from the USB stick in your PC. If you find any difference then probably there is a difference in SQ in playing from USB stick and you need not worry about thinking there is a problem with the HU. But if you find there is no difference then need to think why there is a difference when it comes to HU. Note - Please make sure that it would be difficult to find a difference with earphones. But if you have a 3 way or a 2 way Speaker Music system connect that to your laptop or computer and then testify it and u will easily make out as u did in the car.
__________________ _________________________ Swift DDIS ABS Silky Silver__ Achtung Baby__ My Thread - swift diesel steers towards the left |
| | #7942 (permalink) | |
| BHPian Join Date: Feb 2008 Location: Chennai
| Quote:
__________________ Anyone driving slower than you is an idiot, and anyone going faster than you is a maniac. ~Author Unknown | |
| | #7943 (permalink) | |
| Quote:
Like I said, I know almost nothing about USB. So everything I state is assumption.
| | #7945 (permalink) |
| Senior - BHPian | There are a few similar posts to my query, but couldn't really find an answer to it. The lights in my Lancer (headlights, fog lights, dashboard) flicker when I play a song with heavy bass in it. The flickering goes away if I reduce the subwoofer level through my HU. The setup is as follows: Alpine CDE 9881 HU JBL GTO 75.4 amp JBL GT4-12 sub in a sealed box Illusion Electra EL 6.1 front component spkrs Pioneer TS-A6982S coaxials rear fills The amp runs the front comps and the sub (bridged), while the rear fills are run off the HU. - I am using a Stinger SWK8RS amp wiring kit, which includes a Stinger Pro Series 8 Gauge power wire. - The battery is a new Bosch Silver The headlights sort of "keep to the beat" of the songs when the sub is set on high. Is there any setting on the amp that can help eliminate this? Else, what could be the resolution? |
| | #7947 (permalink) | |
| Senior - BHPian | Quote:
Apart from the disturbance factor, is there any potential risk in cases like mine? Finally, could you suggest a good 1F cap... brands/prices? Thanks. | |
| | #7948 (permalink) |
| BHPian | is there any way to directly add a capacitor on the alternator coil which supplies current to the sparkplugs? i remeber one installer telling me that if i want to get rid of the alternator whine add capacitor to the coil and earth the other end of capacitor to the body. i am totally clueless about this. secondly i have heard about whines only in pio hu's. why not alpines or blaus ?
| | #7950 (permalink) | |
| Senior - BHPian Join Date: Mar 2006 Location: Delhi. Travelling as usual! Mumbai was great.
Infractions: 0/1 (4) | Quote:
The whine isn't mostly due to HU. The wiring happens to be a big culprit in most cases.
__________________ A very big THANK YOU, Bombay! Will miss you guys! :( | |
| Thread Tools | |
Similar Threads | ||||
| "Car"natic (Fusion and Traditional) Thread | indianterrain | Shifting gears | 0 | 8th October 2008 00:13 |
| sub enclosure advice from audio gurus | clipto333 | Ask the Gurus | 22 | 4th January 2007 11:29 |
| The Official "Your Car" Pics Thread | v12 | Modifications & Accessories | 478 | 16th December 2005 16:00 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
