Thread Tools
Old 12th May 2008, 13:16   #8071 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Originally Posted by mohang_j View Post
Navinji, I have gto506 components, can i make an active crossover with band pass between 100Hz to 5kHz for the woofer and high pass from 5kHz+ for tweeters, want to avoid woofer playing kHz+ music.
Doing "active crossover" is a non-trivial task, involving one amplifier for each driver - mid-bass and high (and mid, if one wants a 3-way active) . The frequency band that one wants to allow through each driver is set either at the HU (then the HU must have separate outputs for each f band) or at the amp (then the amp must support 'band-pass'). For 2-way components, you will need a 4-ch amp.
You have 2 courses of action:
1. Get the cross-over as a spare (maybe a pair) from JBL
2. Make a new pair of cross-overs - search for XO or Crossover related threads for the values to use (I think 5KHz in too high - should be preferably 4Khz) (you may get ready-made crossovers at SP Road, at Globe or such shops)
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
DerAlte is online now   Reply With Quote
Old 12th May 2008, 14:25   #8072 (permalink)
DerAlte,
Thanks for the immidiate repply
I already have a subwoofer+amp and i can go for Sony or any other cheap Amp and i have seen people
Its a discontinued product and even if available it will cost more.
will consider that
Instead i can make my own.
mohang_j is offline   Reply With Quote
Old 12th May 2008, 14:35   #8073 (permalink)
redfire's Avatar
(I assume the sub phase has already been set appropriately so that it is blending in with the mid-bass in front)
Then sit back and enjoy the music - forget about lows, mids and highs!
Many thanks DA for your valuable inputs. Going to car with laptop, fav CD and my tool kit . Will be baselining the levels as you recommended and will start from there. Do you think all the adjustments in he HU should be put to flat? I know and do the same with home audio (in fact the home audio components I use has no complicated things like this), but can we do some tweeks in car as the environment is totally different? What are Band-frequency-Q factor things? How to fiddle with them safely if needed? What about the LPF / HPF in HU and Loudness?
__________________
jay
Most automobiles problems are caused by the loose nut that connects the steering to the saddle
redfire is offline   Reply With Quote
Old 12th May 2008, 14:47   #8074 (permalink)
Bass&Trouble's Avatar
(brought components from Manson but he has misplaced one of the crossovers and the crossover just has one 3.3mfd capacitor and an inductor - don't know the value need to check.Now i have to make passive or active crossover my own.)
I havent explored the JBL crossover but is it a 1st order or 2nd order? You can check this by seeing the PCB tracks - is the inductor in series with the woofer's path?
Now if it indeed is, then it means that the tweeter section is first order. I do not recommend you lowering the crossover frequency for the tweeter. You could blow it with less than rated power. Unless you go one step further and design a 2nd order section for the tweeter.
You also cannot just lower the cut off of the woofer by using a different value inductor. You will have a hole in the response. Best POA would be point (1.) as under.
__________________
Operator! Give me the number for 911!
Old 12th May 2008, 15:18   #8075 (permalink)
greenhorn's Avatar
if you change the inductor , all it needs is a corresponding change in the capacitor in the HPF right ?
I've actually toyed with the idea of using a 6" comp, changing the HPF and LPF values , and then adding a 4" in the dash as a mid range to compensate
__________________
2007 Indica DLG
My next Truck will be a Safari!
greenhorn is online now   Reply With Quote
Old 12th May 2008, 18:07   #8076 (permalink)
Team-BHP Moderator
DerAlte's Avatar
...Instead i can make my own.
Brilliant! All the best - we will be waiting to hear the results.
Since you are up to creating your own, perhaps a good starting point would be to reverse-engineer the lone remaining JBL XO. If you can trace out the circuit and values, @bass&trouble will be able to help you make the right one.
__________________
Old 13th May 2008, 09:43   #8077 (permalink)
can somebody help me calculating number of turns & wire gauge for the inductor value.
Old 13th May 2008, 09:53   #8078 (permalink)
cooldude1988765's Avatar
Most of you will laugh at my query but i really need this clarified.
I have a wagon r and wanted to know if the sound stage would be improved if i get the rear 6 x 9 installed in a box under the front seats. As most of you know the wagon R has a very small front speaker provision and i cant spend too much on front components either.
I drive most of the time and no one ever sits at the back.
__________________
He who has the last laugh ...
is the slowest to understand !!!
cooldude1988765 is offline   Reply With Quote
Old 13th May 2008, 09:59   #8079 (permalink)
greenhorn's Avatar
I dont think the soundstage will improve , but if you install it in the back, your low frequency response will improve
And i dont think you can put 6x9's in the front.
actually , front components of a series usually cost about the same as the 6x9's
__________________
2007 Indica DLG
Old 13th May 2008, 09:59   #8080 (permalink)
If no one sits at back better go for 4 inch components, 6x9 under seat will give you only bass since mid and high frequencies are directional.
Old 13th May 2008, 10:07   #8081 (permalink)
I already have the 6x9s installed at the back. looking more for the mids than the bass. I am already satisfied with the bass from my sub woofer in the boot.
The only reason why I am thinking of this is because i turn of my front speakers because they sound crappy and the sound (from the 6x9s) feels like it is playing from a distance.
__________________
Old 13th May 2008, 10:22   #8082 (permalink)
greenhorn's Avatar
maybe you could add an extra tweeter
__________________
2007 Indica DLG
Old 13th May 2008, 10:37   #8083 (permalink)
Tweeter for mids ???
__________________
Old 13th May 2008, 11:02   #8084 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Desired inductance value (based on the circuit calculation) and Wire gauge (based on what you can get; should be able to take the desired steady state current) should be the starting point.
Then you can use an online coil designer like this one to find out the number of turns and layers.
__________________
Old 13th May 2008, 11:41   #8085 (permalink)
Team-BHP Moderator
DerAlte's Avatar
I already have the 6x9s installed at the back. looking more for the mids than the bass. I am already satisfied with the bass from my sub woofer in the boot. ...
What speakers do you have in front currently? I guess this is in the stock location on the upper surface of the dash near the A-pillars.
The sound-stage is basically because of the directionality (what our ears perceive) of mid and high frequencies. The stock location in the Wagon-R is not bad, but you need decent speakers there to get a good sound-stage.
Getting the ovals below the front seats would aggravate the problems, not solve it. Perhaps you could try changing the polarity of the ovals (in the current location) and see if it improves the situation for you.
Putting tweeters might be a simple incremental solution to improve the sound-stage. Ultimately you have to think of getting a decent set of components (4" from Illusion, Blaupunkt, JBL or such).
__________________
Thread Tools
The "Used Car Price Check" Thread numerouno What Car? 292 2nd July 2008 16:56
sub enclosure advice from audio gurus clipto333 Ask the Gurus 22 4th January 2007 10:29
The Official "Your Car" Pics Thread v12 Modifications & Accessories 478 16th December 2005 15:00
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425
