Old 28th December 2009, 13:36   #9841
Bass&Trouble's Avatar
Thanked: 45 Times
6x9s are designed to work in free air. But they won't have too much trouble working out of doors. You could remove the mid/ tweeter and use them as powerful midbasses, but the problem is that the good 6x9s are quite deep.
Old 28th December 2009, 13:55   #9842
greenhorn's Avatar
Thanked: 266 Times
My 6x9's were fitted to the hatch door, and worked quite fine, and sounded less boomy than when they were in the parcel tray
Old 28th December 2009, 14:00   #9843
Technocrat's Avatar
Thanked: 933 Times
Thanks Ajay, could they be directly used by taking the mid bass connection from the XO?
Also wouldn't an entry level 6X9 like Pioneer, JBL be better than the mid bass of entry level Comps like JBL & Illusion(EL series)?
I agree with the depth issue.
Old 28th December 2009, 15:18   #9844
Thanked: 45 Times
Yes, that would be the way to do it. I just meant that it would still be better to snip off or de-solder the leads running to the coaxially mounted mids/ tweets of the 6x9.
More Bass-Mids - Yes. Better Bass-Mids - Not necessarily. If you are taking this much trouble, aim at a nicer 6x9 than the Pioneer.
Old 28th December 2009, 15:30   #9845
nitrous's Avatar
Thanked: 143 Times
I've always felt the JBL GTO series 6x9s are pretty good at mids.
Old 28th December 2009, 16:21   #9846
rbp
Thanked: 77 Times
Guys can I add the following to the i20 without changing the HU?
1) An Amp.
2) Infinity kappa series comps.
rbp is offline   Reply With Quote
Old 28th December 2009, 16:23   #9847
Originally Posted by binz View Post
Hey, help please!
Which is a better choice SQ wise:
Blaupunkt bahamas mp46 or a pio p1y ..
Dont know about the Bahamas but p1y is a piece of crap
Old 28th December 2009, 16:34   #9848
greenhorn's Avatar
Thanked: 266 Times
first time I heard that opinion, especially if you have the 937/947 in mind
Old 28th December 2009, 19:52   #9849
Technocrat's Avatar
Thanked: 933 Times
Thanks Ajay, no I am not looking forward to do this, this was for knowledge sake
Old 29th December 2009, 10:26   #9850
rbp
Thanked: 77 Times
Guys,
Has any one here heard music from Apple Hi-Fi? it is warm and has a nice feel to it, may be I cannot describe it properly. I want speakers that sound like the apple hi-fi. Any suggestions please.
Yesterday had been to JBL showroom near lavelle road, he did not have the infinity kappa series for demo. Any place where I can sample multiple brands?
Thanks!
Old 29th December 2009, 10:39   #9851
Thanked: 63 Times
Hi Guys,
I want to replace stock speakers of my ANHC with better once. I dont want to go for subs, just want to replace speakers on the doors. Can you please suggest which combination will be the best. Would i need a amplifier for the same? would like to go for good quality once like JBL, polk., please suggest me models which i can go for.
shamanth is offline   Reply With Quote
Old 30th December 2009, 13:16   #9852
Eddy's Avatar
Thanked: 672 Times
My colleague has an after market double din HU installed in his Innova. Every two months or so, the HU stops working. But as soon as you pull it out and then put it back, it works normally for the next two months when the cycle repeats.
Problem ?
Solution ?
Eddy is offline   Reply With Quote
Old 30th December 2009, 15:49   #9853
Originally Posted by Eddy View Post
Problem ?
Loose power connector or a cut in cable
Solution ?
Open it once, check the connector and cable thoroughly and fix whatever needs to be fixed
greenh0rn is offline   Reply With Quote
Old 2nd January 2010, 11:48   #9854
rbp
Thanked: 77 Times
Any idea on the prices of the following
Harmon Kardon Amp CA470
Hertz HSK 165 comp speakers
Hertz HCX 690 co-axial speakers
The car lounge guy is quoting the following
Harmon Kardon Amp CA470 -- 17.5K [MRP 25K] 30% discount
Hertz HSK 165 -- 19.5K [MRP 26K]
Hertz HCX 690 co-axials -- NA
Quote from TMC electronics
Harmon Kardon Amp CA470 -- 22.5K [MRP 25K] 30% discount
Hertz HSK 165 -- 23K [MRP 26K]
Hertz HCX 690 co-axials -- 10% discount [MRP 15K I guess dont recall exactly]
Is there any other place where I can check the pricing.
Old 2nd January 2010, 18:43   #9855
nura's Avatar
My installer says he can create pre-amp outs in a HU which doesn't have any (e.g. the Fiesta OEM HU). I will not need a line output converter or an amp which accepts speaker-level inputs after that.
Is this really possible?
nura is offline   Reply With Quote
OE Replacement - Navigation System for Cruze "Mega Audio" lawyer Sound Off and Show Off 36 15th September 2012 11:43
"Kicker" audio setup in my Hyundai Sonata Frankenstein Sound Off and Show Off 9 4th March 2011 13:35
Car audio losing sound at low rpms! EDIT : Solved by "The Steg" GTO Ask the Gurus 162 23rd November 2010 17:27
sub enclosure advice from audio gurus clipto333 Ask the Gurus 22 4th January 2007 10:29
