Old 5th April 2010, 00:53   #10096
yes navin sir there is a pair of rca outs.
will do that tomorrow and post the results.thanks for indulging me .this seems to be step by step guide for a noob like me
rupinder is offline   Reply With Quote
Old 5th April 2010, 09:37   #10097
navin's Avatar
Thanked: 1,133 Times
step by step is the way most of us figure out what is not working correctly. As a doc you too must be following the same analytical policy.
Old 8th April 2010, 00:58   #10098
nisarg86's Avatar
Hey guys. need help on tuning my friend's ICE.
Car : i10
HU : JVC KD R616
Front Compo : Infinity Reference REF6030CS
Amp. : JBL GTO 1004E
Sub. : JBL GT5-S12 1200W
Wiring Kit : Scosche E2 1000 W Amplifier Wiring Kit
Enclosure for SUB. : Sealed.
Damping : Local 500rs. wala. dont know what they call. but he said local manufactured.
As some of you know the ICE scenario in ahmedabad is sux. Dealer insisted us on some Vibe speakers and sub setup. but we didn't agree and gone with JBL. Installation was also not upto the mark. many times i have to show him my ICE. Like placing Amp. , wiring,mounting tweeter etc.
On Amp. we have bridged the channel # 3&4 to SUB. 1&2 driving front Infinity.
Installer straight away set the gain and HPF setting without playing any track. Like he thinks that all the AMPs should be set to default value. After setting up gain on amp. he fiddled with HU's HPF. and set it to 100. and said your system is ready. I thought i will set the gain and hpf setting with the help of you guys. so we simply went away from there.
Now my friend is complaining that on 30-40 volume Sub is not at all loud. he wants to have thump at lower volume. I said OK. we can work on that by setting up gain and HPF settings on all 4 channels from scratch. I read the Gain Settings Simplified thread. and will follow the Frank's guide for Gain.
But i completely clueless on HU part. as i don't have in my car. So what should be the settings on HU part ?
So need help on that part.
nisarg86 is offline   Reply With Quote
Old 8th April 2010, 11:19   #10099
navin's Avatar
Dont mix HU and amp settings. If you do yo have to do so carefully. AMp settings are nice becuase you dont loose them when the car goes for servicing, HU setting are easier to set as you can listen while you set.
So first keep the amp on flat/all-pass and only use the HU. Once you have what you like on the H, translate them to the amp and keep the HU on flat/all-pass.
Once you get the hang of simple settings you willl leanr that you can mix Hu and amp setting but do so carefully. You can really mess up phase resonse if you dont.
Old 8th April 2010, 14:32   #10100
nisarg86's Avatar
Thanx a lot sir. I didnt know that one can mix HU and AMP settings. will update you on it.
Old 8th April 2010, 23:39   #10101
Hi Guys,
I'm planning to install 2 subwoofers (most probably Pioneer 1400W Dual-Voice Coil Type) on my swift, I need ur help for choosing a mono Amp. Please suggest a good amp in the budget 15K, and let me know ur opinion about Boss Amplifiers
jins is offline   Reply With Quote
Old 12th April 2010, 13:40   #10102
Manu Krishna's Avatar
I have a JVC AVX-826, 2 basic JBL speakers on the front and at the rear of my Scorpio. Output is satisfactory. For a change I had plugged in a JBL tube sub-woofer to the right rear output instead of the normal speaker and the output was outstanding. Will this affect the IC based HU? Is it a must to power a sub with a mono amp? If "yes" which is the best mono amp that costs around INR 10K?
Manu Krishna is offline   Reply With Quote
Old 12th April 2010, 14:57   #10103
so gurus i am back
got a kenwood 7043 installed as i needed a bluetooth system .now it has three pair of rca outs .what happened triple trouble ,triple noise.
now i disconnected the second amp,removed its earth .and disconnected the rca.noise still there.
then removed the subwoff rca .the noise decreased but still present.
now i had an el cheapo boss rca .i removed the front rca provided by jbl and connected the boss rca to the front out of hu and the front input of amp. no noise .the front comp playing ok without noise .the boss rca have a plastic grips instead of the metallic ones in the jbl rca's.now waiting for the gurus to guide me
then connected the jbl rca to the sub out of hu and rear in of amp noise is loud .
so deduced that the subout give more noise than front out
Old 19th April 2010, 11:49   #10104
praful's Avatar
Thanked: 100 Times
Anyone good/bad reviews for the Pioneer 7150 HU?
I'm almost decided on going for this, as it meets most of requirements.
praful is offline   Reply With Quote
Old 20th April 2010, 21:48   #10105
pras.oct25's Avatar
I have got polk db 691 speakers in the rear, and a pio 5150 head unit for my verna. I have plans of picking up a gt5 amp and front components. I do not like my music bright, but I do tend to listen to it at high volume often.
I am still unsure about whether I will pick up a sub woofer now or later (for now assume I dont pick it up), but I wanted opinions for the front components. I will be choosing between polk or hertz energy and if someone can rate this in order of increasing brightness for me it would be great:
1) Hertz energy with amplification
2) Polk with amplification
3) Hertz without amplification
4) Polk without amplification
If someone can clarify this for me, would be a great help.
pras.oct25 is offline   Reply With Quote
Old 21st April 2010, 21:18   #10106
pras.oct25's Avatar
Can someone reply to my previous post?
Old 22nd April 2010, 09:59   #10107
DerAlte's Avatar
Thanked: 1,036 Times
@pras.oct25, it is better that you listen to these (and of course other brands and models) and decide for yourself which is brighter. What may not be bright for others may be bright for you, and vice versa. The best would be to check out installations of Team BHP members in Chennai - it would give you a very good idea how different brands sound actually in a car.
Old 22nd April 2010, 10:42   #10108
navin's Avatar
Both Polk and Hertz are known to very bright.
If you want laid back think Infinity, DLS, Illusion, etc.. I found these too bright too. In the case of Inifnity I reworked the XO, in the case of Illusion we tricked the Alpine 650 to roll the hf off a bit.
Old 22nd April 2010, 19:58   #10109
pras.oct25's Avatar
Thanks for the replies guys.
I have heard polk in front with amplification. It was extremely bright at first. A lot of experimenting and tuning eventually managed to bring down the brightness level to a minimum.
The question is, are components as effective without amplification?
Old 23rd April 2010, 09:25   #10110
bottle's Avatar
Thanked: 101 Times
I found the bass better controlled with an amp. Would have asked you to check out the Blau TH series as well but not sure if they are still available
bottle is online now   Reply With Quote
OE Replacement - Navigation System for Cruze "Mega Audio" lawyer Sound Off and Show Off 36 15th September 2012 11:43
"Kicker" audio setup in my Hyundai Sonata Frankenstein Sound Off and Show Off 9 4th March 2011 13:35
Car audio losing sound at low rpms! EDIT : Solved by "The Steg" GTO Ask the Gurus 162 23rd November 2010 17:27
sub enclosure advice from audio gurus clipto333 Ask the Gurus 22 4th January 2007 10:29
