Old 25th October 2009, 14:15   #1
Thanked: 16 Times
Default ICEing the Punto
You guys been helping me out on a lot of things and when it came to iceing my punto, I thought to myself "Where else".
I have a 1.3 MJD EP Punto. I want to keep the HU stock, mostly because of the Blue and Me. And underneath is what my ICE guy said I would need. Could you guys please tell me if I am on the right track. As for the music, I listen to most stuff ranging from Indian Instrumental to Hip hop. I would like some clean music and not too much treble, but definitely some bass.
I can up the budget to about 80K if requred.
1 No High-Low Input - 2500
1 No Pyle Crossover PLX R8 - 4800
1 No DLS CA 51 Amp - 24000
1 set Morel 6 ½ “ Comp - 9500
1 set Mtx 6 ½” Co-axial - 4000
1 No Sub Auditor - 7900
1 No Sub Encloser - 2500
5 Sets RC Cable Stinger - 5000
Woofer Wire - 500
Wooter (D) Pin - 650
Speaker Wire - 600
Speaker Ring - 750
Door Pad Dharmacoal - 450
Main Wires & Fuse - 2500
Labour - 1200
Total Amount 66850
Thanks a ton in advance.
Note from Team BHP support: Please do not use an external editor - font & color tags are not processed while displaying and reduce readability of the post
ronin is offline   Reply With Quote
Old 25th October 2009, 16:29   #2
DerAlte's Avatar
Thanked: 958 Times
1. What is the 'Pyle crossover' for? The components come with cross-overs by default
2. Which sub is that? Not very well known, so double check, since is not quite cheap according to your list
3. (The word is Thermocol, not Dharmacoal) Why would you use Thermocol in the doorpad? If you don't want to spend on conventional damping sheets, use Closed-cell foam
4. Your selection sounds good but we hope you have auditioned the components, the coax and the sub called "Auditor", as well as other brands
DerAlte is online now   Reply With Quote
Old 25th October 2009, 17:20   #3
pranava999's Avatar
Thanked: 13 Times
Please do try and update us with WIP pics once the equipment is finalised and the install begins.
Sounds like the sub is more popular in the home theatre set-up rather than car audio. That is if he was referring to the Sonus Faber range.
First time I have come across using thermocol for damping.
pranava999 is offline   Reply With Quote
Old 25th October 2009, 18:09   #4
panky12345's Avatar
Thanked: 31 Times
Ridicoulosly expensive accesories.. Speaker rings/Woofer wire, Pin etc.
Old 25th October 2009, 19:54   #5
DerAlte's Avatar
Thanked: 958 Times
Originally Posted by pranava999 View Post
... First time I have come across using thermocol for damping.
Thermocol can be used if judiciously placed - needs to be jammed / pressed in between 2 surfaces to damp out vibrations in either. One normally uses it in hatch or boot lid only, but some installers do it in door pads also.
2 major disadvantages:
* Deteriorates over time (crumbles when the plasticiser evaporates) so one is left with a pile of small white balls that float around everywhere inside
* Won't work if glued to one surface only - too less dense to achieve effective surface damping
Old 25th October 2009, 19:59   #6
Thanked: 16 Times
It was actually a quote given to me by my audio guy and i just cut and paste it here.
I hadnt specifically asked for thermocol.Once you guys help me figure this setup out, then I am going for it the very next day.
According to the audio dude, The crossover is a seperate set and is to be used to cut the bass from the speakers and supply it to the sub.Also it has a gain control for the sub, which can fit inside and you could play around with the level of bass.
I am informed it is a brand from FOCAL.
Again, I hadnt specified anything to this guy except some clean sound. This is what he recommended. I just need good damping. Please suggest the right material for it.
Frankly I havent yet listened to any of them. And I know I am supposed to too. But since the gurus have listened to tons of them, I would be quite happy to go with your experience. Also I am open to any changes that has to be made in my list.
Old 25th October 2009, 20:04   #7
pranava999's Avatar
Thanked: 13 Times
Thank you sir. As usual some pearls of wisdom
Old 25th October 2009, 20:29   #8
abhibh's Avatar
Thanked: 25 Times
AFAIK Auditor is a brand of Focal-JMlab
Old 21st June 2012, 00:57   #9
autotranny's Avatar
Thanked: 26 Times
Default Re: ICEing the Punto
Rebin, just noticed this post now. Did you finally get this ICE done ?
Btw, Dharmacoal was hillarious !
autotranny is offline   Reply With Quote
Old 23rd June 2012, 08:17   #10
Thanked: 16 Times
ACtually I did set it up. But most or none of the main list came in. Used a Bit One so I didnt have to change my HU. Audison components and coaxial for the speakers and audison amps too. HAvent really fixed up the sub yet. I have an MTX one.
Grande Punto Facelift: From baby Maserati to Punto Evo EDIT: Punto 'My Life' on pg.7 sushanthr77 The International Automotive Scene 167 25th November 2011 11:02
ICEing the Punto Emotion pack .anshuman Ask the Gurus 46 10th October 2011 12:46
Re-Iceing my Estilo,Need Help!! adishenoy Ask the Gurus 36 1st December 2009 23:27
ICEing up the wagon! pranava999 Sound Off and Show Off 42 24th October 2009 22:22
ICEing my i10 AKi10 Ask the Gurus 19 7th July 2009 02:07
