Thread Tools
Old 9th January 2006, 10:26   #46 (permalink)
aalaap's Avatar
The simplest way to get good sound is to use FreeRIP MP3 (a freeware CD to MP3 converter) and convert sound to either ..
1) 128 - if you want good sound but as much more on one CD as possible
2) 160 - if you want a good balance between quality and file size
3) 192 - if you want great quality.
Bitrates above these (like 256 and 320) will sound just like 192 in most car setups unless you have some ultra high end setup.
Variable bitrate is another option .. you can try a VBR setting between 128-192, which will also give you great results.
A word of caution - don't re-encode (or transcode) MP3 to a lower/higher bitrate MP3. You will only lose quality in the process, unless its s 320/256kbit MP3 that you are trying to convert to 160 or 192, in which case its actually ok.
If you're looking for an encoder with lots of options and also support for about 50 audio formats (gasp!), search for GX Transcoder. FreeRIP MP3 comes with lame built-in so you don't need to worry about quality.
- Aalaap
www.aalaap.com
aalaap is offline   Reply With Quote
Old 12th January 2006, 17:49   #47 (permalink)
rsjaurr's Avatar
Trabscoding is not advisable but abt audio cd [wav]which has been copied from another copied cd without ripping to hard disk [or even if ripped to HD using some software but at default BIT RATE,can we encode this cd with, ofcourse better ouput?
rsjaurr is offline   Reply With Quote
Old 12th January 2006, 20:00   #48 (permalink)
Team-BHP Moderator
navin's Avatar
Doc, TBHP does not promote or condone piracy. I do have copies of CDs however they were made when the orignal showed signs of decomposing as some CDs are wont to do.
Rippping the copy of the CD is almost the same as ripping the original CD. I say almost as I do see some errors from the anti aliasing filters and jitter compound on copies but to be honest cant really define them consistently.
Making copies of CDs is best done using a CD recorder (I use a Marantz machine) and from the coax output of the CD player.
So what you really are ripping is a CDA file. I have not compared the output of my Maratz recoder to a good (Plextor) computer based CD Writer so i cant say if those CDs are equally good.
I have ripped about 305 artists, 696 albums and 8354 songs and this occupies all but 50MB of my 55.7GB ipod.
Old 12th January 2006, 20:29   #49 (permalink)
rsjaurr's Avatar
no..navin...even i dont like that but why i asked this as my sis-in-law has some collection of cd's and i wanted her to send me their copies and then i wud encode these to mp3 myself just for car system.
i cant tell her to do encoding for me.Its very time consuming especially for her as she is doing her MD there.I usually send her copies of my hindi and punjabi music cd's.
Now i wont call it piracy as we r sharing music within a family,though some may not agree with me.
For me piracy is if somebody is trying to get some financial benefit by selling copied cd from original/copied cd.Here we r not looking for any such thing.
Probably i could not put my question right way.Sorry for that.
And even i am not going to use those pirated,cheap 20/rs mp3 on my such a nice system.It will sound like sony!!!!
Old 12th January 2006, 21:43   #50 (permalink)
Team-BHP Moderator
navin's Avatar
Well Doc, technically what you are doing is considered piracy. Even if you are not gaining financially from it. The record and software companies see this is a potential loss of income.
What i discussing earlier is that when you are encoding from a CD remember the copy can never be as good as the orignal (unless you have enough equipment to upsample and remaster) so it is best to have the orignal. However use CDA copies made by a good home CD recorder (in my case marantz) I have not noticed any difference in the MP3 made from the copy v/s an MP made from the orignal CD. As mentioed earlier and on other threads I use VBR (APX in EAC/Lame with Accuraterip and Wavegain).
that reminds me did i not promise to send you my Lame settings. i forgot. buzz me tom. and i wil dig them up.
Old 12th January 2006, 22:32   #51 (permalink)
rsjaurr's Avatar
U had said APX (alt present extreme) with wavegain and a few other flags will do one better
in reply to my post about --alt preset extreme and i asked for these flags or settings,whatever?
And here when we r discussing this piracy issue,just now i got to know i cant get those cd as my she had virus in her laptop and repair guy accidently removed dvd writer and hasn't been put back so far.So there is no time left as my FIL is leaving tomorrow early morning.
Old 13th January 2006, 09:37   #52 (permalink)
Team-BHP Moderator
navin's Avatar
you still can take out her hard disk and connect it to your PC as a slave or use a PC-PC LAN wire (not the standard RJ57 but 2 wires are reversed) and or use a switch to connect the 2 PCs.
--present extreme --id3v2-only --pad-id3v2 --ignore-tag-errors --scale %x --ta "%a" --tn "%n" --tt "%t" --ty "&y" --tg "%m" %s %d
my file path is
C:\Music\MP3\%a\%g\%n - %t
Old 13th January 2006, 16:27   #53 (permalink)
rsjaurr's Avatar
well....she is in USA.
my file path is
Thanx...i will use this setting now.
Old 16th July 2006, 18:15   #54 (permalink)
rsjaurr's Avatar
well..........lets discuss this topic bit more.I dont want my original CD's to get damaged quite early costing as much as 500 per cd.
Right now i rip my cd's using microsoft's WMP v10 to WMA(VBR from 240-355kbps) which uses about 105 to 155 MB per CD.
So each file is about 15MB and CD's sound quality is quite good.[Better than recorded at 128kbps].
I also use EAC with razor but have not much idea how to configure EAC.I did read one article but it dint help me much.
I know EAC is reputed to be the best but it doesn't give file names in ouput directory which WMP v10 gives while ripping to WMA or MP3 format.
And i dont want to type file name individually.
I dont want to have 4-5 folders per cd keeping cd or near cd sound quality.
I hope i am not missing some setting.
Old 16th July 2006, 20:54   #55 (permalink)
condor's Avatar
I have been using CDex for a long time to rip my CD's, and I find this to be good. I have not compared it with other util's, but this has worked for me.
http://sourceforge.net/projects/cdexos/
There was a point abt using CD-RW's in this thread - pls note that CD-RW's are more susceptible to fail than CD-R's. With the cost of CD-R's being so low, it makes more sense to burn to CD-R's than CD-RW's.
Old 16th July 2006, 22:49   #56 (permalink)
Team-BHP Moderator
navin's Avatar
http://sourceforge.net/projects/cdexos/.
CDex is fine too. EAC just offers a lot of support from a large user base. Sorta like Linux.
__________________
Scixelsyd Etinu
Old 16th July 2006, 23:25   #57 (permalink)
Tool's Avatar
here is what i would suggest...
use exact audio copy to rip the music off the audio cd.. save the files as .wav on your hard drive.. next.. use this programe called Audio Catalyst.
its is the best and fastest converter to mp3 formats..only encode at 320 Kbps.. always.. with the cost of a cd at 10 Rs or less.. there is no excuse left to have the mp3's at anything below 320 kbps.
Audio Catalyst is very very good.. and the MPEG 3 encoder was writtien by Xing. the same guys who had a part in founding the MPEG standard. they have now been bought by Real Networks.. of real player fame so trust me .. you cant go wrong.. use this to convert in VBR or constant 320.. It has Brilliant sound quality.. this i can vouch for.. find very negligible differences even on studio monitors... hope this helped...
link for audio catalyst is below
http://www.real.com/accessories/?prod=audiocatalyst
Link for Exact Audio Copy
http://www.exactaudiocopy.de
Booom
__________________
Why Drink And Drive When You Can Smoke And Fly ??.
Front Wheel Drive Is The Work Of Satan !!!
Tool is offline   Reply With Quote
Old 17th July 2006, 12:15   #58 (permalink)
Autophile's Avatar
Hey Tool...posting in a MP3 bit rate thread with Manley's Voxbox in you avatar ... cool
Autophile is offline   Reply With Quote
Old 17th July 2006, 15:27   #59 (permalink)
Team-BHP Moderator
navin's Avatar
EAC might not be the best but it has a lot of support (see hydrogenaudio.org for example).
if you are using LAME with EAC you can use the settings I mentioned below. Yuo should get rips with the following format ...\Artist\Album\Song.mp3
__________________
Scixelsyd Etinu
Old 17th July 2006, 16:12   #60 (permalink)
rsjaurr's Avatar
Can all these sofwares write the file name [as in original cd] to output file [mp3 or wma] as well?
I know EAC doesn't do it but WMPv10 does it very well though on some occasions it just refuses to rip whole cd at one go and i have to repeat it many times for whole cd to be ripped.
So thats my main problem o/w i cant find any difference in audio quality of original cd and ripped to wma format.
@Tool-:audio catalyst is not a freeware and it costs about $29 and they ask about ur billing address/credit card no. etc before u can download it.
@navin-:I tried file name suggested by u but without much help.
Thread Tools
Pioneer Car stereos & accessories Beeman Product Discussions 119 30th November 2007 09:26
Best CDs abhibh Gadgets, Computers & Software 11 15th September 2006 11:38
Writing Cds..... panky12345 Shifting gears 7 4th May 2006 01:02
Security for your Car Stereos mithun Ask the Gurus 26 17th April 2006 23:41
Rally fb@w - Write Up rahulmd Shifting gears 13 25th March 2005 16:50
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
