Thread Tools
Old 10th September 2005, 13:01   #1 (permalink)
mclaren1885's Avatar
Default whats the best bitrate to write cds for ur car stereos??
would like to know whats the ideal bitrate to write mp3s or other formats while compiling a cd for our car decks???which bitrate gives the best clarity and good sound effect??guys keep ur views rolling..
__________________
ICNSAFYNCILWU. WMUL. AWLUFAEAE.
Old 10th September 2005, 13:03   #2 (permalink)
Team-BHP Moderator
Rtech's Avatar
I use a minimum of 128. Anyting less than that makes things too harsh or so I've noticed. anything higher than that and I don't find any difference really!
__________________
He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it!
____
Old 10th September 2005, 13:13   #3 (permalink)
well i too use 128kbps to write all my mp3s,but someone was mentioning about writing cds at 320kbps and that it sounds great and all..so though of putting up this thread..
__________________
Old 10th September 2005, 13:17   #4 (permalink)
F50
Team-BHP Moderator
F50's Avatar
320 sounds best!! Many of the songs in my iPod are of 320 they sound great but also eats more space ... so 60gb iPod is next on the card.
__________________
F50
Gaberlunzieman
F50 is offline   Reply With Quote
Old 10th September 2005, 13:50   #5 (permalink)
satan_crazy's Avatar
the ripper i just d/l had an option of 192 and 224 as well (highest was 320; haven't tried this bitrate though) ... the songs sounded a lot better at 224 than at 128 ... but a considerable difference in the space they take up ... 7.5 mb at 224 as compared to 4.2 mb at 128
s
__________________
Lucifer waits for everyone
satan_crazy is offline   Reply With Quote
Old 10th September 2005, 15:25   #6 (permalink)
gunbir's Avatar
Infractions: 0/1 (5)
I have been doing this for a long time now and let me assure you... 320kbps (and above) is the way to go. With Hard drive and optical media becoming so cheap now (and prices still steadily declining) you should try and go with 320kbps. Exact Audio Copy is a nice program that does this very well. Yes, the codec and softwarer you use matters.
Personally, in the last year I have converted to WMA (quality 98) or max bitrate VBR. This yeilds and average 10MB song size BUT... the sound quality difference between MP3 320 and this is quite large. WMA 98 currently has the edge. It comes really close to an Audio CD.
On a good system you can clearly hear the difference. As for the 128 kbps fans, c'mon... you can hear the difference between a 128 mp3 and a 320 mp3 on a cellphones mp3 ringtone.
__________________
Immaculate Alpine 9887 for sale in Classifieds
gunbir is online now   Reply With Quote
Old 10th September 2005, 21:24   #7 (permalink)
cnu
cnu's Avatar
Well, most of my mp3s too are of 128. Its hard to make out the difference between 128 and higher unless you have a good audio setup in your car. If you have a sub, tweets and good speakers, then it has to be atleast 256 for best output.
Here is a link with results of listening tests carried out at various bit rates.
http://www.mp3-tech.org/tests/gb/index.html
cnu is offline   Reply With Quote
Old 10th September 2005, 22:28   #8 (permalink)
binz's Avatar
Dont increase the bitrate of downloaded mp3s as there wont be a significant change but while ripping from an audio cd,keep the bitrate as 320.
Fav softwares are switch(encoding),mp3 stripit!!(ripping)-both can be found on download.com
Old 11th September 2005, 00:13   #9 (permalink)
Team-BHP Moderator
navin's Avatar
I use exact audio copy. but i do things a bi differently. EAC calls a program called WACK. WACK then allows me to call as many encoders as i care to. for example one can rip MP3, AAC, OOG and WavPack all in one go.
For now I rip CDs using only 2 encoders. LAME 3.96.1 APX (the latest stable release is 3.97) and WavPack 4.2. I use WavPak 4.2 (compression ration 2:1) for my MultiMedia PC (2 x 400GB, 2GB RAM, 19" Viewsonic LCD, Altec Lanscing 6021 speakers, etc..) and LAME (compression ratio of 5:1) for my ipod.
Since I use APX which uses VBR the average bit rates I got are about 224 with peak bit rates as high 460. Hydogenaudio.org is a forum dedicated to this.
Old 17th October 2005, 12:05   #10 (permalink)
SoundManiac's Avatar
Default Does a lower bit rate harm the lens/system?
The Pioneer 7750 HU I have gives its recommended bitrate for MP3's as minimum 128 Kbps.
What I wanna know is that -
Will a bit rate lower than 128 harm the Hu/lens/system?Say if the bit rate is just 16kbps(not for music, just some commentaries), then?
I listen to a couple of audio books and stuff some of which are recorded in MP3 bit rate as low as 16kbps! (Its just a commentary or in other words just a person speak with absolutely no music at all in the background, so no issue with audio quality.)
Will playing MP3 cd's recorded in this rate harm my lens/system/HU.
SoundManiac is offline   Reply With Quote
Old 17th October 2005, 12:17   #11 (permalink)
cnu
cnu's Avatar
No. HU/lens has nothing to do with the bit rates. Its just that if the system does not support particular bit rates, then it just wont play.
Old 17th October 2005, 12:25   #12 (permalink)
Oh! That was a fast reply. Thanks da!
And, I'm on way to google to check the specs for bit rate support.
Old 17th October 2005, 12:31   #13 (permalink)
Checked the specs and Pio 7750 plays Mp3's with Bit rates from 8-320 kbps. So chill!!
Loads and loads of the Commentaries that i listen to on the net are available in Mp3 formats in 16 and 32 kbps bit rates - Now, I can here them with peace and importantly without a cassette player in my Car audio setup.
Thanks for your help cnu.
Old 17th October 2005, 14:36   #14 (permalink)
Team-BHP Moderator
navin's Avatar
for those of you who really want to sink you teeth into MP3s bit rates and media players of all types I's suggest looking at www.hydrogenaudio.org.
Old 18th October 2005, 10:26   #15 (permalink)
Vivekphadnis's Avatar
I use audiograbber with the LAME external encoder. I encode my mp3s in 192Kbps and I think it sounds great.
__________________
Thank God for DIY audio.
Vivekphadnis is offline   Reply With Quote
Thread Tools
Pioneer Car stereos & accessories Beeman Product Discussions 119 30th November 2007 09:26
Best CDs abhibh Gadgets, Computers & Software 11 15th September 2006 11:38
Writing Cds..... panky12345 Shifting gears 7 4th May 2006 01:02
Security for your Car Stereos mithun Ask the Gurus 26 17th April 2006 23:41
Rally fb@w - Write Up rahulmd Shifting gears 13 25th March 2005 16:50
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425
