Closed Thread
Thread Tools
Old 18th November 2005, 18:56   #1 (permalink)
Aroongupta's Avatar
Default Best Audio Option in 30K
Sirs,
I am buying either of the two - Chevy Optra 1.6 or a Safari Dicor Lx within teh next 10 days. I am a naive as far as Music system installations in a car go. Would you please advise what is the best possible system with a ange of 25-35K I can get installed. Please take into considerations that teh chevy comes with 4 pre installed speakers and a stereo system, which I believe are of no use. Will I need to replace everything - the music system as well as all 4 speakers or the front two can stay? Please also advise what will be teh best setup for teh safari keeping in mind that it does not come with a back tray.
thanks
Aroongupta is offline
Old 18th November 2005, 19:16   #2 (permalink)
mclaren1885's Avatar
Infractions: 0/1 (10)
well aroon..it would best if you first decide on which car you want to buy and then try to choose the system accordingly once your decision is made..every car has its own unique features and reproduces sound differently..so one cannot expect the same system to sound good in all the cars..
anyways just for the basic knowledge :
1. you will need a good HU preferably alpine/pioneer/sony with 3 preouts..
2. component speakers at the front for optimal front soundstage..
3. rear speakers where its best to use 6.5'' coaxials and not the oval also called 6x9's if your interested in a sub too..these rear speakers are to be used only as fillers against the normal misconception that all the sound should come from the rear..
4. a good 4channel amplifier to connect these speakers and the sub too..
5. and obvioiusly a subwoofer to produce your lows..
well there are umpty number of brands in the market,any brand is available in india as of now..you name it and we have it..so choosing the best among them in the budget constraints that one has is the task..for this it is very important to know which car that u have finalized on and also the kind of music you listen to..hope that helps..feel free to ask and im sure all the guys here will be glad to render help..
PS : 30k is quite a good amount to get a good sounding setup..
mclaren1885 is offline
Old 18th November 2005, 19:22   #3 (permalink)
Aroongupta's Avatar
Yeah, I guess you are right. I will get back to you guys with my queries once I buy the car. I won't mind extending my budget even higher but this time I want a great sounding system. Hope with support from here, I will be able to work it out.
Thanks for now for the initial info. Pretty useful. Thanks.
Old 18th November 2005, 19:26   #4 (permalink)
navin's Avatar
Aroon. for the optra with 30K I would look at 10K for the HU, 10K for front and rear speakers and about 10K for a sub and 4 ch. amp. using the HU to power the rears. this config has been advised for many a sedan. the Dicor is another vehicle. for one, it would need more sub power as it has a larger cabin.
navin is offline
Old 18th November 2005, 19:35   #5 (permalink)
well as a matter of fact let me answer ur question put forth in the 1st post..for a starters avoid the factory audio setup..try to get some cash discounts on them if possible..ICE is best done as an aftermarket..
for the chevy :
as far as my knowledge goes all the 4 doors of the optra can accomodate 6.5'' speakers(thought would love the gurus to confirm on this)..so the best setuo would be :
1. alpine 9833 HU (production is stopped but available in the market) or pioneer P1Y HU..this should cost you around 13k..
2. get good 6.5'' components for the front door pads from a good speaker manufacturing company(not necessarily sony and pioneer to be the best choices)..the popular brands we recommend are alpine,hertz(from my personal experience),JBL,blaupunkt..well we have other brands too like RF,LA,MBQ,boston,soundstream et all..these component speakers will give u the best soundstage..these will cost u around 7k..
3. get good 6.5'' coaxials for the rear doors..remember these are to be used only as fillers and not in a way such that they overpower the fronts..it would be better to keep the fronts and the rears preferably from the same series and the same company..these will cost u roughly around 4k..
4. a good 4-ch amp to run the speakers..however u can use the amp of the HU to run the rear speakers and use the 4 ch amp to connect the fronts and the sub..amps preferred are the alpine amps (though a bit expensive),blaupunkts at a fair price,but taking the steal at the price will be the pioneer 6100 amp at 7k is great VFM..u can get a sony 504 too for 4k..
5. as far as the sub goes u can get a sub and use a sealed enclosure for it to achieve tight and punchy bass or else get a tube sub which will give u more of boom boom..do read around the ICE section and u will find plenty of info on subs and enclosures..this will cost you around 5-8k..
total : 13+7+5+7+8=40 k at the most..hehe i know its way over board ur budget but we tend to go overboard sometimes..actually we can narrow it down to a better price based on ur inputs further and the brand u choose..these prices are just a rough estimate,so dont be hard pressed by them..
for the best setup as of date on a optra i would say it has to be that of Rudra's,but knowing that the setup cost him over a lakh im not surprised..
for the dicor :
points 1,2,3,4, all are the same only differnce being a change in the size of the speakers and the way u mount them..principle is the same basically..as far as the subs are concerned,viewing the fact that u will hardly haves space in the DICOR i would say go with the Image Dynamic subs as they require less of box volumes and are snug fit under the front seats..do wait for the others to chip in..im sure they will give finer details..
Old 18th November 2005, 19:41   #6 (permalink)
well now that aroon has confirmed that he will get back once he has chosen the car is it possible to close this thread temporarily navin..
Old 18th November 2005, 21:58   #7 (permalink)
Awaiting Email Confirmation
original_sin's Avatar
Pioneer 6750 - Rs.7500/-
M.A.Audio Speakers - Rs.3300/- Dual Coil
M.A.Audio Component - Rs.3800/-
VISONIK 250 x 4 - Rs.7250/-
4channel Amp.(US Make)
Subwoofer Twister,JL Audio
bith 1000watts dual channel - Rs.2450/-
dual voice coil
1"inch speaker tray for saloon cars - Rs.450/-
Wires and Ampier clips - Rs.250
Rca Cables Rs.300/-
Fitting -Rs.200/-
Good System in 25k
original_sin is offline
Old 18th November 2005, 23:58   #8 (permalink)
dual voice coil
Rca Cables Rs.300/-
Fitting -Rs.200/-
Good System in 25k
hhmm..M.A.Audio,visonik,twister eh..the only thing missing from that list is M.B.Quart and earthquake..remember these brands guys..im sure JB,JK,sam,navin,v1p3r and me certainly do..
btw whats a dual coil speaker that u have mentioned,is it same like our DVC subs..if yes then how does it tend to be advantageous over the single coil speakers we get in the market..pls explain ..
and the visionk amp gives 250x4 rms..wow im impressed..looks like the cabling is a bit too cheap,which company are they..though i would prefer some better cabling as it plays a very important role..
Old 19th November 2005, 00:06   #9 (permalink)
gunbir's Avatar
Twister Pt II - The Return Of The Mack
__________________
This used to be a Funhouse, but now its full of Evil Clowns
gunbir is offline
Old 19th November 2005, 01:01   #10 (permalink)
v1p3r's Avatar
Is this amplifier packed in a suitcase and cooled using fans?
__________________
"We Could Fly So High
Let Our Spirits Never Die..."
- Michael Joseph Jackson
Rest in peace.
v1p3r is offline
Old 19th November 2005, 01:19   #11 (permalink)
Note from Mods - No personal attacks on people - if you have an issue - take it to the moderators - This is your first warning !
Old 19th November 2005, 10:11   #12 (permalink)
navin's Avatar
Aroon, if you dont mind i will take up mclaren's suggestion of temporairly closingthis thread and will reopen it when yuo decide on your car. meanwhile you can budget you car audio system as 3 approximately equal parts (1 part HU, 1 part front and rear speakers, 1 part sub and amp). This will give youa starting point when you are looking for audio components and can later be fine tuned.
navin is offline
Closed Thread
Thread Tools
Used Bullet for about 30k? shapra Motorbikes 8 3rd July 2009 11:52
Optra Magnum - 1 year, 30k Report arunk Long-Term Ownership Reviews 25 3rd October 2008 18:25
PC under 30k sammyboy Gadgets, Computers & Software 20 28th January 2008 13:13
2005 Zen 30K on the ODO amtak Long-Term Ownership Reviews 3 5th September 2007 16:59
N91 Is out @ 30k + unknown Gadgets, Computers & Software 78 17th May 2006 11:24
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
