| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Jun 2005 Location: Bangalore
| So here is the story. There is some kind of crr crr sound from all four speakers when I use the horn. Otherwise there is no such sound. Anybody any ideas? Thanks, Vivek
__________________ Thank God for DIY audio. |
| | #2 (permalink) |
| Senior - BHPian | check the wiring connecting your speakers.. if they are loose then the sound comes.. also are you running any amps.. loose wires connected to amps can also make that kind of sound... or worst the cone of your speaker is torn... get them checked by a professional..
__________________ I accidentally installed the deer whistles on my car backwards. Now everywhere I go, I'm chased by a herd of deer. |
| | #4 (permalink) |
| The noise comes from all four speakers. I checked all the speaker and amp connections. They all seem secure. As I said the noise comes only when I use the horn. If it was a case of loose connection, there would be problems even when I am not using the horn. I am beginning to feel this is some kind of ground problem. The speakers are only about seven months old. I checked all cones and surrounds. There is no sign of damage. Godfather, I don't want to sound rude but I prefer to solve the problem myself in true DIY spirit. This should not be a problem that we cannot sort out, particularly after having installed the system myself. So keep your suggestions coming.
__________________ Thank God for DIY audio. Last edited by Vivekphadnis : 16th January 2006 at 22:26. |
| | #5 (permalink) | |
| Senior - BHPian Join Date: Sep 2005 Location: New Delhi
| Quote:
__________________ Playing in my CD player: Rod Stewart - The Story So Far | |
| | #6 (permalink) |
| BHPian | I too have a similar problem..but same type of sound comes when the volume is low,and I adjust the power external rear view mirrors !!..please advise possibilities..I don't know whether it's also coming from rear components,but front both component speakers emit that sound.. I just got the components fitted in recently,and have original Kicker RCA/Speaker wires.. please suggest possibilities. -sr
__________________ Driven by Dreams ! |
| | #7 (permalink) | |
| Quote:
__________________ Thank God for DIY audio. | |
| | #8 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
your horn relay is the culprit. 1. change horn relay 2. put cap across horn replay 1uf/63VDC will do 3. use an appropriate MOV (trial and error) i had this in my contessa in 1989 but since then not seen this. gotta talk to ACMA. damn shoddy horn! can you find out who made the horn. there will be some specs on the horn or the relay. sorry i did not read the part about the horn earlier. Last edited by navin : 17th January 2006 at 09:50. | |
| | #10 (permalink) |
| BHPian Join Date: Dec 2005 Location: Mumbai
| hey people, i too faced to same problem. 4 days after i got my system installed, i starting getting this strange "errrr errrr" sound from my speakers at low volume (only from the speakers connected to the amp). In my system, this sound was produced due to the leakage of current in the head unit. May be the sound produced in your speakers is due to leakage of current in some other component (amp, headunit, wiring etc..). I got the head unit checked, and the problem was solved by soldering the connectors of the headunit, where the speakers are connected. [SIZE=2][/SIZE] |
| | #11 (permalink) |
| Amit, the sound occurs when only when I use the horn. As I said earlier, if there was some leakage, loose connections or cold solder like you say the noise should be there all the time, don't you think?
| | #12 (permalink) | |
| Quote:
It could be the horn relay. Disconnect the horns and then press the horn button, the relay is still working. If the noise remains, the relay is to blame. If it stops when you disconnect, its the horn. Good cabling has rejection and is less prone to such issues. Usually our dealers just swap the BS interconnect with Audison ones and thats all it takes.
| | #13 (permalink) |
| There are some points here: 1. Let us assume that the horn/relay is faulty, the Maruti service will blame me since the car is still under warranty and I have installed the audio system myself. 2. Will that noise I get in the speakers affect my audio system in any way? I presume it will not. 3. Non audio question: For argument's sake, if I remove the audio system and take the car to the service station, there will be no noise naturally when the speakers/HU/amp are removed. How will I prove that the horn/relay is faulty?
__________________ Thank God for DIY audio. Last edited by Vivekphadnis : 20th January 2006 at 14:37. |
| | #14 (permalink) |
| To add to my post no. 13, the horn is called Padmini and below it says loud. There is some sort of number which says E 11. Looks like some cheap horn. Anyway, I disconnected the horn and there is no noise. So, it is indeed a 'horny' problem.
| Thread Tools | |
Similar Threads | ||||
| Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) | himanshugoswami | Technical Stuff | 14 | 14th May 2008 15:00 |
| hissing noise from speakers when horn is blown | gopz | Ask the Gurus | 7 | 14th June 2007 13:40 |
| Strange noise from Indigo. | sajo | Technical Stuff | 12 | 7th May 2007 11:59 |
| Need some input on reducing rattling noise in the rear due to the oval speakers | partypest | Ask the Gurus | 4 | 5th January 2007 06:49 |
| Strange noise from 800 | DCEite | Technical Stuff | 7 | 5th November 2005 10:33 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
