Go Back   Team-BHP > Under the Hood > Team-BHP Directory > Bangalore
Old 30th April 2009, 23:25   #16
Consolidated List is below:-
1. HP Petrol Center , Next to Golden tower building, Kodihalli (old airport) road, Bangalore. Contact Person:- Vijay
2. Pratham Motors , Outer Ring Road, Landmark :- Opp to Eco space, Bangalore.
3. Madhu's Tyre Center at the corner of Double Road - Mission Road - Lalbagh Road Junction (Under the flyover)
4. Bimal Motors, Mahadevpura, towards Whitefield
5. HP Pump, next to Cosmos mall, Brookefield./Mats Fuel Pump
6. shiva's tyres. On New bel road near ms ramiah college
7. RNS motors (Hosur Rd)
8. Sai Baba Tyres near Wilson garden
9. A1 allignment in Wilson Garden.
10. Tyre Empire opp Sigma Tech Park on Vartur Main Road Whitefield -Rs 50/- per tyre
11. Concorde Motors Mysore Road -Rs 30/- per tyre
12. Sireesh Auto, Hosur Rd, very near to the silk board flyover.
13. Prerana Motors, Old Madras road
14. bimal service center in bannerghatta rd.
gogo_gogo is offline   Reply With Quote
Old 2nd May 2009, 00:16   #17
Nikhilb2008's Avatar
Thanked: 6,637 Times
Originally Posted by geedeesworld View Post
Here's the website link for Madhus: Madhus.com
You can get complete tyre alignment along with Nitrogen top-up done.
While the Madhus name is correct, the shop is wrong.
That Madhus Tyre Centre on JC road doesnt have Nitrogen. The other two shops Madhus Enterprises and Tyre Professionals have Nitrogen inflation.
Madhus.com
Madhus.com
Old 3rd May 2009, 12:11   #18
ashwinurao's Avatar
Super Tyre Tec, J.C. road , B'lore. Although he did charge 50 bucks per tyre.
Another place is Iyengar and Sons, BSK 3rd Stage, 100 feet Ring road. Next to Corporation bank. Charge is 30 bucks per tyre.
ashwinurao is offline   Reply With Quote
Old 4th May 2009, 00:27   #19
Roy.S's Avatar
Thanked: 111 Times
Two more:
1. Coles road service station. 30 Rs per tyre. This is not on Coles Rd but on the way to the airport opposite the Godrej Woodsman property. Its the HP pump on the left (while driving towards BIAL) just before the Sahakar Nagar turn.
2. Shankar Enterprises, the Goodyear Dealer on BEL Rd next to More supermarket and opposite Health & Glow. No idea about the price.
Stopped going to Madhus on double Rd after they left my wheel nuts loose during alignment.
Roy.S is offline   Reply With Quote
Old 5th May 2009, 23:03   #20
There are good number of places where we can get nirtogen filled for tires in bangalore.
But I dont think there will be any such places outside bangalore. In these conditions will it be ok to mix nitrogen with normal gas?
_abhishek is offline   Reply With Quote
Old 6th May 2009, 02:31   #21
ashwinurao's Avatar
Absolutely. But all the advantages or what appeared to be advantages (See this thread : http://www.team-bhp.com/forum/techni...-nitrogen.html (Inflating tyres with dry nitrogen)) would be gone or will reduce depending on the amount of top-up.
Old 6th May 2009, 09:22   #22
Mr.Bangalore's Avatar
Thanked: 43 Times
Originally Posted by Roy.S View Post
Two more:
it is 25 INR per tyre ..
Mr.Bangalore is offline   Reply With Quote
Old 6th May 2009, 09:47   #23
Will there be difference in handling of car or smoothness if we use nitrogen gas?
Old 6th May 2009, 11:31   #24
ashwinurao's Avatar
If you had maintained proper tyre pressure using normal air then there should not be any improvement in handling or ride quality theoretically and any evidence to support it is only anecdotal.
Refer this thread for more info : http://www.team-bhp.com/forum/techni...-nitrogen.html (Inflating tyres with dry nitrogen)
Old 8th May 2009, 01:28   #25
Roy.S's Avatar
Thanked: 111 Times
If you think about it logically, there should not be. However, in the real world scenario there will be a noticeable difference. I attribute this to the fact that the the regular air machines at most pumps are badly maintained and do not necessarily fill the correct psi on each tyre. I have experienced this myself at a Shell pump, no less. On the other hand, a person who is charging you 30Rs per tyre is more likely to maintain his machine. Equal pressure in all tyres makes a big difference.
Pressure loss with nitrogen filled tyres is significantly lower than in those filled with air.
Old 25th September 2009, 20:36   #26
Thanked: 21 Times
I saw it in Bimal motors too.
automobilophile is offline   Reply With Quote
Old 25th September 2009, 22:03   #27
Nitrogen Filling is available at Bimal Service Station behind Leela Palace. They charge Rs.100 for 5 tyres.
sridhar_setty is offline   Reply With Quote
Old 25th September 2009, 22:57   #28
Thanked: 29 Times
Sai Service Station (HP) on Kasturba Road also has facility for nitrogen filling of tyres.
indianrunner is offline   Reply With Quote
Old 25th September 2009, 23:09   #29
Thanked: 197 Times
Thumbs down Nitogen a marketing gimmick
Filling Nitrogen in tyres ? I must say that you already do ,Normal air contains around 80% nitrogen so why bother about filling nitrogen in tyres. It apparently doesn't have any harm apart from the price you pay for it. If it's being offered for free at some filling-station, go ahead and fill it but if it's being sold for even 10 rupees/tyre, I would say, it's not worth the price!
Filling Nitrogen in tyres has NO apparent advantage over normal compressed air! It's a marketing gimmick, ignore it.
Nitrogen proponents say that the nature of the gas means it's less prone to leaking out over time through the pores present in rubber tires. But most air leakage in tires can be traced to poor fit around the rim of the wheel or the valve stem, rather than gas permeating the rubber.
Claims of nitrogen being more friendly to the rubber and wheels is also questionable, since most tires wear out the tread on the outside long before the inner rubber would go bad from exposure to oxygen. The same factors hold true for wheels, many of which are made from alloys, not straight steel. You're far more likely to damage a wheel from hitting a curb than see a wheel go bad from oxidation.
tj123 is offline   Reply With Quote
Old 29th September 2009, 09:46   #30
Sai Iyengar on Bannerghatta road near IIM, he charges 20/tyre. Fully deflate and fill it.
funda2max is offline   Reply With Quote
Best places to fill up Boom Shiva Indian Car Dealerships 273 20th July 2012 18:02
Places to refil Nitrogen in Mumbai Zahir Tyre & Alloy wheel Section 24 4th November 2009 09:29
best place to fill up in pune naturaldisaster Route / Travel Queries 4 1st July 2007 18:43
Fill the car with thermocole to trap a thief Ram The International Automotive Scene 15 12th September 2006 16:32
