Go Back   Team-BHP > Under the Hood > Team-BHP Directory > Bangalore
Old 18th November 2012, 09:08   #106
Thanked: 85 Times
Default Re: Places to fill Nitrogen in Bangalore
Second Nitrogen filling place in Kammanahalli, ORR.
Indian Oil Pump opposite to McDonalads.
Costs 20 rs per tyre first time. 10 rs per tyre afterwards.
Apparently no freebies with fuel.
pradyblr is offline   (1) Thanks Reply With Quote
Old 2nd February 2013, 21:52   #107
condor's Avatar
Thanked: 4,908 Times
Switched to Nitrogen on both - the Ikon and the Sumo. IOC bunk on RV Road (between South End circle and Lal Bagh west gate).
It did make a difference, and I am happy I switched from regular air.
And I was one of the sceptics who used to think that since air is already 78% Nitrogen, what difference can another 15% make ?
condor is online now   (2) Thanks Reply With Quote
Old 7th April 2013, 22:25   #108
Thanked: 13 Times
Had been to a neighborhood bunk for air fill. Since normal air wasn't available, switched to nitrogen. Paid 60 bucks for 5 tyres. Before the fill-up price mentioned was 20 rs per tyre, but ended up with 12 per tyre.
Me-hul is offline   Reply With Quote
Old 27th April 2013, 11:16   #109
Thanked: 85 Times
Third Nitrogen filling center in Kammanahalli.
On the 80 ft road next to cosmopolitan club. Refill charge 10 rs per tyre.
Meanwhile Indian Oil pump has started offering free refill if you fill fuel for 1000 rupees or more.
pradyblr is offline   Reply With Quote
Old 7th July 2013, 17:00   #110
shinuak's Avatar
Thanked: 72 Times
1. Jai Hanuman IOCL fuel station, next to Manyata tech park. Rs 10/tyre
2. IOCL fuel station on the right side after kodigehalli signal on BIAL road when you go towards airport (dont remember the name). Rs 10/Tyre
3. Fuel station in kasturba road, which has the McD and Cherry Tyre agencies.
4. HP petrol pump near to kodigehalli signal on the left when you go towards airport. Here it used to be Rs. 5/ tyre, but the pump is closed temporarily now, hope they re-open soon
5. Viswas , MASS. You don't need to drive inside, the nitro pump is very near to the entrance gate. Rs 10/ tyre
6. MRF tyre dealer next to Viswas, same rate
7. Mobile Tyre tech , Kammanahalli he charged Rs 30/tyre. Everything including tyres are costlier than dealers elsewhere, so I don't prefer much.
8. PitStop kammanahalli, newly opened and hence no idea about the rates.
9. Tyre Empire, near Whitefield. Don't know the current rates
10. IOC pump near to ITC gardenia, free if you fill fuel for Rs 1000/-
My experience with nitrogen have been very good so far since i the pressure drop is very minimal and only over a longer period of time. I believe nitro keeps the tyres cooler when driven at high speeds consistently. For small punctures as well the pressure drop will be very slow and gradual. I am using nitrogen from the past 3 years
shinuak is offline   (1) Thanks Reply With Quote
Old 16th December 2013, 10:47   #111
B103's Avatar
Thanked: 200 Times
I've a question. I switched to Nitrogen 3 years back in my Honda City. I used to top-up Nitrogen only once in 6 months since then.
Is 6 months too long or is it risky? How frequently are others in the forum topping-up nitrogen?
B103 is offline   Reply With Quote
Old 17th December 2013, 18:03   #112
B103's Avatar
Thanked: 200 Times
I found the answer to my question today. My understanding is that you need to top up at least once in 3 months. I did the last top up at the time of the regular service which was 5 months back. Did the top up today -- tyres had a pressure of 27 PSI only which is low. Topped it up to 33 PSI. At 27 PSI, tyres won't look deflated, neither can you press it and understand much.
Struggled to find a nitrogen filling center near by Sarjapur road. I went to 6 places as below before I was successful:
1) IOC petrol pump before Bellandur central -- facility not working
2) Castrol pit stop in Total mall, Sarjapur road -- Closed
3) Castrol pit stop in HSR opp to NIFT -- Closed (Is Tuesday a holiday for Castrol pit stop or did they go bust?)
4) Shop 'Tyre Plus' in 27th Main, HSR -- Not entertaining mere Nitrogen top ups
5) Tyre empire opp to Sun city on Sarjapur rd - ORR jn -- Was told that they don't have the facility. Not sure if they lied !!
6) Yokohoma tyre center in Sarjapur rd -- Could not find it
Spent a couple of liters of petrol searching around and I was getting ready to top up with air. Got to the place ultimately: There is an IOC petrol pump opp to Agara lake. Take the road by the side of it, come straight almost to the end. It is on the left side. Coordinates are: 12.907445, 77.644784 ( You can enter raw co-ordinates in GPS or Google maps and navigate to your destination).
Another place where I was told that you can do top up is the HP petrol pump , Opp to JSS college and BDA complex, HSR. I did not go and check personally about this place.
Old 17th December 2013, 20:35   #113
NPV
NPV's Avatar
Thanked: 5,298 Times
I would suggest checking(better to carry a pressure gauge so you can check it yourself) and refilling once a month, it's a lot safer.
Remember under-inflated tyres can lead to bursts at higher speeds
Also, try to visit the same place that's closer to your home or work place, that way you don't have to go around looking for it.
NPV is offline   Reply With Quote
Old 11th July 2014, 15:51   #114
Is there any bunk near Bannerghatta Rd / Hulimavu ? Preferably IOC ?
abhinavm is offline   Reply With Quote
Old 11th July 2014, 20:23   #115
D4D
D4D's Avatar
Thanked: 327 Times
There's this tyre shop opposite brigade palmsprings. Not too far from Arekere. I don't use nitrogen, but I find his service good.
D4D is offline   Reply With Quote
Old 12th July 2014, 23:17   #116
arun_josie's Avatar
Thanked: 4,968 Times
I am not sure about IOC, but you have a Wheel Alignment/Wheel Balancing shop near gottigere, BG road. One more option is in a tyre shop inside BP near Sagar Apollo - BG road.
If you have a Maruti car then you can try it out at Bimal near Meenakshi temple.
arun_josie is online now   Reply With Quote
Old 13th July 2014, 11:10   #117
Aiel's Avatar
Thanked: 152 Times
I am not aware of any bunk on BG Road that has Nitrogen.
I generally fill up on Nitrogen at the IOC bunk on Kanakpura Road, adjacent to Metro (Near my office).
Aiel is offline   Reply With Quote
Old 13th July 2014, 12:08   #118
Thanks..I went to btm COCO.. 24 hr open and reliable fuel as well
Old 1st August 2014, 09:27   #119
meetbadri's Avatar
Thanked: 77 Times
Bharat Petroleum Petrol Bunk near Naagarabaavi 80 Feet Main Road, NGEF Layout. I have been filling Nitrogen from this place since last 2 years and have not come across any issues so far. He charges Rs. 10 per tyre for complete fill and Rs. 5 for Top-up
meetbadri is offline   Reply With Quote
Old 1st August 2014, 14:37   #120
DieselFan's Avatar
Thanked: 234 Times
Are there any pumps on ORR between Mysore road and Deve gowda petrol pump that offer Nitrogen top ups. What are the charges per tyre?
DieselFan is offline   Reply With Quote
Best places to fill up Boom Shiva Indian Car Dealerships 273 20th July 2012 18:02
Places to refil Nitrogen in Mumbai Zahir Tyre & Alloy wheel Section 24 4th November 2009 09:29
best place to fill up in pune naturaldisaster Route / Travel Queries 4 1st July 2007 18:43
Fill the car with thermocole to trap a thief Ram The International Automotive Scene 15 12th September 2006 16:32
