Go Back   Team-BHP > Under the Hood > Team-BHP Directory > Bangalore
Old 8th April 2015, 19:06   #556
sbalagru6's Avatar
Thanked: 65 Times
Default Re: Wheel Alignment/Balancing : Madhus Enterprises (Langford rd, Bangalore)
Bought a used Fiesta a month back, the car pull towards left and if you leave the steering it will turn slightly towards left.
As per the previous owner, he changed the tyres a year back (Still all the tyres looks new). Also during recent service he has done wheel alignment as well.
Fixed an appointment last Wednesday and went to Madhu's. Nikhil was not around and folks their attended promptly, told them the problem. They said wheel alignment should fix the issue and got the same done.
After that I could not check it properly in city traffic, even though i felt the pull. Weekend while driving to Chennai noticed the pull still there, and I have to put in lot of effort to keep the steering straight.
Guess I have to go there again and get it checked
sbalagru6 is offline   Reply With Quote
Old 9th April 2015, 11:10   #557
glenmz's Avatar
Thanked: 276 Times
Needs manual adjustment. Alignment for my Fiesta usually takes a second trip to the alignment center almost every time.
glenmz is offline   (1) Thanks Reply With Quote
Old 25th April 2015, 17:18   #558
satan's_valet's Avatar
Thanked: 181 Times
Visited Madhus today for the 10k wheel alignment and balancing. Despite the weekend rush, I was attended to immediately. Spoke for a while with Mr.Gopal and while the work was being carried on. I was in and out in 30 minutes. Kudos to the entire team.
P.S. - Madhus now offer A/C services as well. Saw a brochure for gas filling and coolant check. Sorry I forgot to take a pic.
satan's_valet is offline   (1) Thanks Reply With Quote
Old 4th May 2015, 16:03   #559
sbalagru6's Avatar
Thanked: 65 Times
Went again last Wednesday and told them the issue. They suggested me to go for road force wheel balancing along with tyre rotation. Done the same and guess what??! The left pull is still there .
Not sure what else to be done
Old 4th May 2015, 16:11   #560
arunphilip's Avatar
Thanked: 4,818 Times
Since wheel alignment has not addressed the issue, I suggest you get the suspension checked at from Ford - its possible that the track/tie rods have been bent due to some impact on the wheel. Or else, some other part of the suspension components.
arunphilip is offline   Reply With Quote
Old 4th May 2015, 16:26   #561
glenmz's Avatar
Thanked: 276 Times
Not sure how wheel balancing can fix the side pull. Try swapping the right and left front tyres. Did they try to perform alignment manually?
Old 4th May 2015, 16:52   #562
sbalagru6's Avatar
Thanked: 65 Times
They have done wheel balancing using the road force equipment. And as suggested by the equipment itself, they swapped the tyres as below,
Front Left -> Front Right
Front Right -> Back Left
Back Left -> Back Right
Back Right -> Front Left
Old 4th May 2015, 17:13   #563
glenmz's Avatar
Thanked: 276 Times
Ok. maybe you should pay Ford service a visit to get this checked.
glenmz is offline   Reply With Quote
Old 23rd June 2015, 18:10   #564
Thanked: 1,289 Times
At 40k kms, the Goodyear NCT5 on my Baleno had lived its life. Visited Madhus and replaced with Michelin Energy XM2. This was after much deliberation with my colleagues at workplace who were against such a premium tyre.
Initial impression of the XM2 are fantastic. The ride now glides, with low noise in the cabin and a supple ride.
Was in and out in 45 minutes flat with some good job by the technicians. One worry is the changing alignment values. The values seems to drift a bit on the higher side everytime I take for alignment. However the tyre seems to be having a normal wear pattern. Can someone tell me if this is normal.
unk9ja is online now   Reply With Quote
Old 8th July 2015, 16:44   #565
Nikhilb2008's Avatar
Thanked: 6,637 Times
If you tell me specifically which alignment value is drifting to the higher side I can help you out.
But values changing is quite normal. That is the reason alignment is recommended every 5000 kms.
Nikhilb2008 is online now   (1) Thanks Reply With Quote
Old 17th July 2015, 18:40   #566
Thanked: 41 Times
The stock Goodyear NT5s on my Jetta developed a sidewall bubble on a second tyre as well and i decided to replace them. Visited Madhu's and picked up 2 Michelin Primacy 3STs and have had them fitted for the front while i continue to run the stock shoes in the rear.
The service was excellent and cordial with fast turnaround. Had a wheel alignment and balancing done as well and the RoadForce data was an absolute shock as the car went through the whole 'alignment' process at the VW service centre just a week back! There were reds all over the chart and the service associate told me that the alignment was very bad prior to their work!
Anyway, was impressed with the service and if they maintain their high standards are assured of a customer for life.
RoadTrippin is offline   (1) Thanks Reply With Quote
Old 18th July 2015, 10:32   #567
Was just going through the forum yesterday and found this. Now according to this, new tyres should be on the rear according to the theory. Even Michelin have advised this.
http://www.team-bhp.com/forum/tyre-a...ront-rear.html (Where to Install a New Pair of Tyres? Front or rear?)
unk9ja is online now   (1) Thanks Reply With Quote
Old 30th July 2015, 13:18   #568
vraghuz's Avatar
Thanked: 23 Times
Nikhil,
I had changed my Scorp tyres at your place to Michelins, we also had a nice chat at that time, i recommended your place to one of my friends in the Scorpio group , he called up your office today at around 10.45am to enquire about pricing and availability ,got a shocker when the guy who took the phone just told the price and banged the phone down.
He got upset and gave some peace of mind to me as well to recommend this place and went to somewhere else and bought the tyres. i hope you can ask your staff to be a little more polite to anyone who calls for any enquires.
Regds
Raghu
vraghuz is offline   (1) Thanks Reply With Quote
Old 31st July 2015, 12:09   #569
sdp1975's Avatar
Thanked: 972 Times
Had a good experience at Madhus today. My 195/60/R15 ZLOs on the Punto - purchased again from Madhus about 2.5 years ago - had little tread left in them. Used for about 39K, having faced some punctures recently, and with some upcoming long drives planned, decided to change the tyres. Went for the Continental MC5 tyres as recommended by Nikhil.
Tyre cost : VFM at 5450/- per piece. Other options in the size were Pirelli, Yoko A drives , ZlOs ( 5K) and Michelin 3ST ( 6K ) . Got the road force balancing , and alignment after the fitment. Staff was very courteous and professional, as usual.Total cost for tyres+alignment+balancing was 22550/- , and got 500/- for the buyback of the old tyres, so the 22,050/- was the final damage to pocket.
Initial impressions after driving for about 12km are significant improvements in tyre noise ( only the engine noise is audible ) , and ride comfort.No change in steering feedback. Will be doing a long drive next week, and hopefully other factors like grip, handling will be more evident then.
Wheel Alignment/Balancing : Madhus Enterprises (Langford rd, Bangalore)-img_20150731_095337.jpg
Wheel Alignment/Balancing : Madhus Enterprises (Langford rd, Bangalore)-img_20150731_095423.jpg
Wheel Alignment/Balancing : Madhus Enterprises (Langford rd, Bangalore)-img_20150731_095438.jpg
sdp1975 is online now   (3) Thanks Reply With Quote
Old 6th August 2015, 00:04   #570
condor's Avatar
Thanked: 4,898 Times
Nikhil,
-was at Madhu's today. Rajan did a good job on the WA for the Storme. Thanks to him ! Mr Gopal was supportive as always ..
Alloy wheel repair + Balancing + Alignment : A1 Car Care Centre (Bangalore) J.Ravi Bangalore 23 12th March 2018 13:24
Wheel alignment or wheel balancing?? leodelg Tyre & Alloy wheel Section 27 22nd June 2011 00:44
Breakdown Assistance for 1 year, Wheel Alignment & Wheel Balancing just for Rs 199 Mitsun Soni The Indian Car Scene 11 8th March 2011 11:02
Newbie questions - wheel balancing, wheel alignment. johy Technical Stuff 8 6th December 2006 10:39
