Go Back   Team-BHP > Under the Hood > Team-BHP Directory > Bangalore
Old 13th June 2010, 12:25   #1
kri$hna's Avatar
Thanked: 29 Times
Default LPG Specialist : Mr. Pandian (Bangalore)
I have been to Peekayam Gas Works, which belongs to Mr. Pandian. I would like to share my experience of getting my LPG works done there with him.
first off, the place is not on the main road, neither is it easy to access. But Pandian guides well for us to reach there without any hiccups. I was very much impressed with the kind of equipment he has and the knowledge of what he does.
He has a stoichiometric analyzer for tuning openloop and lambda based LPG units, he uses this to analyse the emission, rich/lean mixture lever etc. usually the LPG guys try to achieve a setting by tuning the idling of a car. This guy does it with numbers. He is pretty professional at any install/repair. I have seen the level of detail in his work, and simply astonished.My palio LPG kit was installed in hyd and then I visited Mr. pandian to get a good tune up done. He checked the wiring and it was pretty bad. Immediately he started with rerouting all the wiring and it must be seen to be appreciated !! a group of 4 wires are spliced, connected to sensors and then again sleeved together using a heat resistant sleeve to prevent shorting/melting of wires. Pretty systematic, he uses black for earth, red for 12v, brown for sensor and so on. No change watsoever!!
I am currently getting my baleno rewired and will post a few pics of work in progress soon. He also installs sequential kits ranging from 35 to 45K, and has a laptop to tune these kits.
will be posting more information and pics of his work. I just wanted to let people know, theres this guy, in HSR layout, who does a very good install/repair of any LPG kit ( i have seen him work on openloop till sequential), speaks flawless english, understands our requirements, tries to repair if anything can be repaired ! He even repairs my palio's ROM sensor, when concorde gave me the only option of replacing it.
I hope this info helps people using LPG as a fuel, and also prospective users of LPG. I will put some pics later.
Mr. Pandian's Mobile Num: 09448133918. Peekayam Gas Works, Hosapalya, HSR Layour.
Directions: Coming from BTM Layout, after crossing Silk Board, Take the 3rd Right on ORR (opp to Reliance Auto Zone), Reach the dead end, Take Left & ask for Ujala Factory. Take the right near Ujala Factory main entrance & look for Mother Theresa School, take the right turn after Mother Theresa School and look for Peekayam Gas works on your right. You can call Pandian for directions while you are HSR Layout.
kri$hna is offline   (3) Thanks Reply With Quote
Old 13th June 2010, 17:14   #2
Thanked: 103,353 Times
Hi Kri$hna, great recommendation. I've taken the liberty of moving your thread to the Directory.
Please share full contact details (phone, address) so that other members / guests can benefit from your submission. Thanks
Old 14th June 2010, 10:56   #3
kri$hna's Avatar
Thanked: 29 Times
Originally Posted by kri$hna View Post
I have been to Peekayam Gas Works, which belongs to Mr. Pandian. I would like to share my experience of getting my LPG works done there with him....
..I am currently getting my baleno rewired and will post a few pics of work in progress soon. He also installs sequential kits ranging from 35 to 45K, and has a laptop to tune these kits.
will be posting more information and pics of his work....
Here are the pics of my Baleno LPG Kit rewiring & closed loop control installation.
The pics show him making the clamp & filing it all by himself, and installing the kit.
The stepper motor position was set and after taking a drive, he was not satisfied with the response and now the stepper motor has been moved closer to the gas mixer (round venturi near air filter). The stepper motor should be as close to the mixer as possible and many installers dont take note of this fact. After this change, he could make my unit run leaner and thus get more average and drive-ability from the same system . This closed loop kit from Tartarini can be tuned by a laptop, it has an ECM in which we get to see all the readings of rpm, gas flow, step position etc which can be tuned !!
LPG Specialist : Mr. Pandian (Bangalore)-20100612-16.43.43.jpg
LPG Specialist : Mr. Pandian (Bangalore)-20100612-16.43.59.jpg
LPG Specialist : Mr. Pandian (Bangalore)-20100612-16.44.18.jpg
LPG Specialist : Mr. Pandian (Bangalore)-20100612-16.44.35.jpg
LPG Specialist : Mr. Pandian (Bangalore)-20100612-17.23.01.jpg
LPG Specialist : Mr. Pandian (Bangalore)-20100613-14.07.25.jpg
LPG Specialist : Mr. Pandian (Bangalore)-20100613-14.08.07.jpg
kri$hna is offline   Reply With Quote
Old 15th June 2010, 18:33   #4
Good one. I would appreciate if you can drop the his contact numbers in the post.
Fordy is offline   Reply With Quote
Old 18th June 2010, 09:18   #5
kri$hna's Avatar
Thanked: 29 Times
For Sequential LPG Kits, Pandian has two options, 1 from EuropeGas costing 35,000/- & another from BRC costing 45,000/-. I might someday go for this
Note to MODS: I am not able to edit the first post, if possible, add the contact number in the title/first post .
Old 14th December 2010, 12:41   #6
funkykar's Avatar
Thanked: 1,740 Times
Default Re: LPG Specialist : Mr. Pandian (Bangalore)
Does he work on old cars too? I have a Lavota kit installed on my 118 NE and want it to be tuned to perfection to get the ideal power and FE.
EDIT: Oops! Saw the contact number and called him. He does work on old cars. I plan to visit this weekend.
funkykar is offline   Reply With Quote
Old 14th December 2010, 21:47   #7
kri$hna's Avatar
Thanked: 29 Times
Good going ! Say my Hello to him
If it is an open loop lovato kit, then i presume he will use a stoichiometric analyzer to check the lambda or something !
Old 14th December 2010, 22:17   #8
funkykar's Avatar
Sure thanks!
I dont know what type of LPG system my NE has. All I know is it is a carburetted car and I have installed every single component of LPG original. Let us see how my car fares after visiting him.
Old 15th December 2010, 09:54   #9
Thanked: 40 Times
This is nice & useful piece of information about this guy in HSR layout. There was always a shortage of proper technical guys in this area.
However, i feel that his kit costs are high. One get a better price, if we approach a direct importer of the LPG kits.
nandans2005 is offline   Reply With Quote
Old 18th December 2010, 12:04   #10
kri$hna's Avatar
Thanked: 29 Times
Yes. That is true and holds good not only for lpg kits but for any goods you purchase. What you are paying more here is for installation.. tuning & service back up whenever you require.
I have got the sequential kit BRC installed in my Baleno & believe me or not, I have been to him atleast 10 times to achieve the proper tuning for performance & mileage. He was patient and all the time encouraged me to be satisfied first and then pay him.
I have now shifted base to Hyderabad and i still haven't found such a technically sound installer here to get my baleno tuned to same levels.
Old 7th April 2011, 12:04   #11
jeeva's Avatar
Thanked: 558 Times
I had been to this place a couple of days back to tune the open loop system on the Ikon. It used to flutter around and idling used to be horrible.
I had been to several places before and all of them were like nothing much can be done with the open loop system on the Ikon. Though, Pandian too started off on the same note, he said he will do some trial and error and try to solve the issue, but did not promise anything. Finally, he changed the mixer to the one he uses for the sequential system and after a couple of tune ups and trials, the car runs super smooth on LPG.
Cars come from all over the south for LPG conversions to him. When I was there, an Esteem came in from Suraksha (Maruti ASC) for some LPG related work. Moreover he has a neat and a systematic workplace, which speaks a lot.
I found him to be honest and quite a knowledgeable guy. He knows his stuff.
Highly recommendable place for LPG related work in Bangalore.
EDIT: Somebody was talking about importing the kits directly from the manufacturer. Pandian used to be the Karnataka distributor for Tartarini kits, not sure if he still is.
jeeva is online now   (3) Thanks Reply With Quote
Looking for a Suzuki Shogun Mechanic / specialist in Bangalore sfilinto Motorbikes 6 17th October 2014 17:28
pkm.pandian, Bangalore pkm.pandian Introduce yourself 1 15th October 2010 11:38
Any specialist painters in Delhi? barcode Technical Stuff 15 3rd May 2009 15:38
Trauma Care / Accident Specialist given2fly Shifting gears 2 15th January 2008 00:37
Modification Specialist for Tata Sierra. gemithomas Modifications & Accessories 5 19th June 2007 17:22
