Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On buying a car
On buying a car Help articles related to buying a car
Thread Tools
Old 14th February 2008, 14:33   #76 (permalink)
I took 3rd and 4th year extended warranty for my Santro last month for Rs. 4600. The price quoted also varies depending on when the extended warranty is taken. Taking it within 90 days of delivery costs the lowest.
murugaveln is offline   Reply With Quote
Old 31st March 2008, 11:50   #77 (permalink)
suman's Avatar
Default Tata Safari extended warranty
As a continuation of the discussions on another thread, I'm sharing details of what is included in the extended warranty on my Tata Safari. There is a general misconception that only items which do not generally fail are covered but I don't think that view is correct.
(Mods, I didn't want to start a separate thread for this, please feel free to move it if so required)
So, Parts Covered in extended warranty (30 months after initial warranty period of 18 months OR 150,000 kms, which ever occurs first) for Safari :
Engine
Cylinder heard, head gasket. oil pump & drive, crankshaft, flywheel & ring gear, timing gears, belts & chains, camshaft, cam follower, valves (excluding burnt & pitted valves), valve gear, pistons, connecting rods, gudgeonpin, distributor drive, inlet & exhaust manifolds, bore\liner, turbo, intercooler units where factory fitted.
Clutch
Clutch pressure plate, clutch disc, release bearing, master & slave cylinder, clutch cable (failure due to worn or burnt clutches are not covered).
Transmission
Internal gears, shafts, syncromesh rings & hub, bushes, selector forks, drive chanins, gear lever & bushes (failure due to worn out or burn out clutches & bands are not covered).
Transfer Case
All internal parts.
Coolant
Radiator, water pump, thermostat, engine oil cooler (failure due to external damage or corrosion is not covered).
Steering system
Rack and pinion, steering box, column, shaft bearings, couplings, power steering pump, pressure pipes, reservoir.
Propshaft
Shaft, universal joints, center bearings.
Final Drive
Crown wheel & pinion, differential gears, hub & hub bearing.
Front wheel drive
Drive shaft & couplings, constant velocity joints, hub, drive flange.
Fuel system
Carberettor, choke unit, fuel pump, injector pump, ECU, cold start valve, pressure damper, auxiliary valve, overrun cutoff valve, deceleration valve, tank sender unit.
Brake system
Servo, master cylinder, wheel cylinder, diesel vacuum pump, callipers, discs (excluding brake pads/liners), drums, handbrake lever & rathchet.
Suspension
Shock absorbers (excluding fluid leakage) bush\mechanical failures, control arms, upper and lower wishbones, springs. Limited to 35,000 kms beyond which deemed to be normal wear & tear.
Casings
Should failure of any of the components covered result in damage to the casings, then they will also be covered & will constitute part of the maximum claim liability.
EMISSION WARRANTY
Exhaust system
EGR valve, EGR Actuation system.
Intake system
Air intake throttle, Air temperature sensor, Air mass flow meter, Oil separator and PVC valve.
Fuel system
Assembly fuel injection pump, Assembly injector.
Cold start system
Glow plug, Fast idle control device.
Evaporative Emission Control
Canister purge valve, Fuel tank cap & relief valve.
Engine management system
Crank angle sensor, Vehicle speed sensor, water temperature sensor.
ELECTRICAL SYSTEM
Starter motor & solenoid, alternator, distributor, coil, wiper & washer motor, window motors, fan motors, switches & instruments.
Air conditioning
Compressor, condensor, evaporator and clutch magnet.
Man, that's a pretty comprehensive coverage I'd say. Tata definitely covers you adequately during your extended warranty.
I will post details of my Fiesta extended warranty in a few days time. This is quite a time consuming exercise & I gotta run........
__________________
Making my own road, 4.81 meters at a time - Safari Dicor VX 3.0L 4x4
suman is online now   Reply With Quote
Old 31st March 2008, 14:10   #78 (permalink)
svsantosh's Avatar
Hi Suman. Pretty comprehensive I say. Very impressive homework, looking forward to the fiesta parts line up.
__________________
Dont wear Helmets & Seatbelts to reach Heaven Faster
You hardly have any time left in this world to be a sinner
svsantosh is offline   Reply With Quote
Old 31st March 2008, 15:09   #79 (permalink)
ram_hyundai's Avatar
Infractions: 0/1 (7)
Good description and very exhaustive post buddie.You have gone in depth in the subject buddie.Good job done.
ram
__________________
had loved hyundai,now starting to love others too
ram_hyundai is offline   Reply With Quote
Old 1st April 2008, 02:21   #80 (permalink)
Good thing. I made the mistake of not taking an extended warranty for my Santro since none of my earlier cars needed it and almost ended up paying through my nose for a crankshaft failure.
http://www.team-bhp.com/forum/long-t...-1-2years.html (Hyundai Santro Xing - Crankshaft & engine repair/ failure-only 26000 Kms & 2 1/2years)
Murugan is offline   Reply With Quote
Thread Tools
Should I go for extended warranty? sbhalkikar The Indian Car Scene!! 29 30th November 2007 09:48
Of Free flow exhausts and Warranties GTO Modifications & Accessories 39 26th December 2006 12:05
Toyota India makes 3 year warranties standard! GTO The Indian Car Scene!! 16 20th March 2005 23:41
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
