Old 28th April 2011, 14:08   #1
Thanked: 56 Times
Default JVC HU - Occasional Misbehavior
I have JVC HU Model KD-G385 in my Palio for the past 3 years. From the past 2-3 months it has developed this problem:
Whenever I switch-off the ignition and switch-on after some time (for example, in a traffic signal) it refuses to start playing. The HU switches-on, displays the album title and everything - but it just doesn't play the songs. I have to eject the CD, insert again and it starts playing - but from the first song!!
- This doesn't happen if the HU is in FM tuner mode.
- Also note that this doesn't happen always. Sometimes it starts palying from the same song when the start the ignition.
- It's out of warranty now.
Can someone help me assess the problem?
ch.nathan is offline   Reply With Quote
Old 28th April 2011, 19:37   #2
libranof1987's Avatar
Thanked: 4,203 Times
Default Re: JVC HU - Occasional Misbehavior
Is the problem only with 1 CD?
Is so, the CD itself could have developed bad sectors and hence become unreadable at some points.
Also note that the CD reader laser has a limited life; and it eventually loses the ability to read some CDs especially CD-Rs.
In our older laptop, the CDROM drive behaved erratically; at times it wouldn't read some CDRs and almost completely lost its ability to burn CDs.
PS : In case the reader head is wearing out, there is one thing you can try prolonging its life - get it cleaned from a good accessories shop.
libranof1987 is offline   Reply With Quote
Old 29th April 2011, 08:47   #3
Thanked: 56 Times
^^ Nope. It happens with all CD's. When it runs it keeps playing without disruption. Only when I switch-off the ingnition and switch-on again, it doesn't play - that too not always, but say 5/10 times.
Old 29th April 2011, 11:36   #4
This must have something to do with the reader. Have that checked; and it should mostly solve the problem.
Old 2nd November 2011, 15:45   #5
girishglg's Avatar
Thanked: 426 Times
Default Re: JVC HU - Need a USB port
I have a JVC HU CD player with JBL speakers in my car. The CD player has gone kaput. Got it checked and it seems the digital head is gone. I am not interested in repairing the CD unit anyway. Can I get a USB port installed into it and if so what is the cost and where can I get it done in Blr?
girishglg is offline   Reply With Quote
Old 2nd November 2011, 16:17   #6
vigsom's Avatar
Thanked: 603 Times
^^ I read somewhere on the forum that Anwar(Auto Fusion) did this on a Pioneer 8450 cassette player
Old 4th November 2011, 01:32   #7
ghpk's Avatar
Thanked: 193 Times
ch.nathan Check if the time on HU also gets Reset,
if the time is reseted their are 2 possibilities
1).the wire which gives power to HU even with IGN. off is broken or has a problem.
2).check with HU manual or a service center if the HU has a battery inside to retain the settings which needs replacement.
Old 5th November 2012, 14:23   #8
girishglg's Avatar
Thanked: 426 Times
Again back to the question, can a USB in be fitted into a single din JVC unit? If so what components and at what cost? Can anyone suggest who would be able to do it in Blr?
Old 5th November 2012, 16:33   #9
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by girishglg View Post
... can a USB in be fitted into a single din JVC unit? ...
No, one cannot additionally fit a USB port in an existing HU which didn't have one. One has to replace the HU with one that already has one.
Search in the DIY section for a thread where someone has tried to build one using off-the-shelf components. Maybe that will work for you if you don't want to replace your old JVC.
DerAlte is offline   (1) Thanks Reply With Quote
Occasional RPM fluctuation : Getting to the root cause tsk1979 Technical Stuff 11 22nd May 2016 01:07
Exhaust pop on deceleration, occasional stalling hellmet Motorbikes 26 24th February 2015 12:16
Occasional Stalling ravradha Motorbikes 5 26th July 2007 10:04
Having Occasional Trouble Accessing TBHP ? Rehaan Shifting gears 2 14th June 2004 17:02
