Old 14th June 2011, 19:10   #16
Thanked: 548 Times
Default Re: Fozzie Gets New Chips!
Already looking good. Why is the part looking blue in the top pic but in the test mount it looks black? Have you already got it painted?
Guna is online now   Reply With Quote
Old 14th June 2011, 20:22   #17
gotzuk's Avatar
Thanked: 69 Times
Originally Posted by frankmehta View Post
Oh man, that is SWEEEEET. Really good looking. As stock and barebones as it can be!
Thanks Bro. I am a sucker for stock looking mods
No. Its the phone cam playing shady tricks. It matches the dash texture and is a wee bit darker in colour. Here is a shot from another angle, have a look.
gotzuk is offline   (1) Thanks Reply With Quote
Old 17th June 2011, 09:50   #18
gotzuk's Avatar
Thanked: 69 Times
Just hit a roadblock! :(
I had planned to mount the mobo, hard disk and gps antenna in the empty space behind the touch screen but the mobo just wouldn't fit!!
The only other place in the dash is where the OEM head unit currently sits. Removing it will allow me to place the mobo and hdd in this location and the psu and gps antenna can go behind the screen on top of the dash.
But doing this would leave a gaping double din sized hole on my dash, so I am looking at the possibility of taking an aftermarket (Pioneer, Sony etc., since I don't want to destroy the original unit) double din headunit's faceplate and using it as a cover for the empty slot. The slot loading dvd drive could then be attached behind the cd slot on the stereo faceplate.
I am also looking at the possibilty of using the keys of the stereo faceplate to emulate a USB keyboard, so that the faceplate control buttons can be mapped to the hotkey combinations used by Centrafuse and control (at least) the media playback.
I hope I can make this work, otherwise the PC will have to be mounted in a fugly blackbox under the seat/ in the boot.
Something I really do not want to do
gotzuk is offline   Reply With Quote
Old 17th June 2011, 16:47   #19
mav2000's Avatar
Thanked: 123 Times
You can also use acrylic to cover that part. If you have the right dimensions, acrylic can be cut and bent as per your requirements. Also putting the motherboard in a place where it gets direct sunlight may not be conducive. So to for the HDD and PSU
mav2000 is offline   Reply With Quote
Old 17th June 2011, 21:48   #20
gotzuk's Avatar
Thanked: 69 Times
Arrow Re: Fozzie Gets New Chips!
The motherboard & hdd are being mounted behind the stereo faceplate and the psu behind the screen inside the dash top pod, so direct sunlight is not an issue at all.
For the faceplate, acrylic, though an easy way out, is not quite what I am looking at. Even with the best fit and finish, it would still be a jugaad.
Already bought an Arduino board, now need to find a non-working double din stereo whose faceplate/chassis I can hack to interface with Centrafuse.
Old 17th June 2011, 22:08   #21
Thanked: 548 Times
You are putting a double din with non functionality front face, which means the current HU will be gone and you will cover that area with a dummy mask? In that case you could have installed the touch screen itself in that place right?
Old 17th June 2011, 22:22   #22
ariesonu's Avatar
Thanked: 1,450 Times
Actually my thoughts.
@ gotzuK: You took all the pain just to keep your OEM & now this compro. How about the glove compartment?
Raab Rakha.
ariesonu is offline   Reply With Quote
Old 18th June 2011, 00:05   #23
gotzuk's Avatar
Thanked: 69 Times
Arrey, No!
The double din will not be non functional. Almost all the buttons of the faceplate will work, only difference being that since there will be nothing behind the faceplate, the buttons will control functions of Centrafuse. For eg, the volume knob will control the volume, the eject button would eject the optical media in the DVD drive behind the faceplate, the power button will turn on/off the cpu. Even the LCD display can/will be programmed to display song/artist/time info etc.
As I wrote earlier, to do this the faceplate will give output to an arduino board, which in turn will emulate centrafuse hotkeys to the pc (via USB).
So the faceplate will not a be dummy, but fully functional. Think of it as programmable buttons/hotkeys to control the pc.
If it all works as I am hoping, then I will hunt down a non working OEM HU and replace the aftermarket face place with it. Right now I am experimenting with this stuff, so don't want to butcher the working unit installed in the car.
If all this doesn't work then I'll be a looking for a fugly black box to install the cpu under the front seats
Old 21st June 2011, 00:14   #24
gotzuk's Avatar
Thanked: 69 Times
The teeny tiny Arduino UNO got delivered today. Some more supplies coming in tomorrow. Can't wait to get cracking on it!
Old 21st June 2011, 09:36   #25
Thanked: 548 Times
Tata Photon is just to give the impression of size?
Old 21st June 2011, 09:42   #26
gotzuk's Avatar
Thanked: 69 Times
Yes Guna. Just that.
Old 21st June 2011, 10:07   #27
mayankk's Avatar
Thanked: 3,559 Times
this is really nice!!
I have been wanting to do this for a long time, but just cant find the energy to follow through!
About the faceplate, why not put a ipad sized bluetooth keyboard hinged on the right side of the din enclosure, so it tilts towards you?
mayankk is online now   Reply With Quote
Old 21st June 2011, 10:38   #28
gotzuk's Avatar
Thanked: 69 Times
Can you post some links for keyboards which would fit on the panel? And how would the hinge system work?
Old 21st June 2011, 11:04   #29
mayankk's Avatar
Samsung Galaxy Tab P1000 Case with Bluetooth Keyboard - Allymobile whole sale supplier
Somehting like this, which is made for the galaxy tab.
Its on bluetooth.
this would be approximately 8x5".
coul cover up the 2din hole completely i presume.
for the hinge mount, you could put a swivel mount inside the 2din space, bolted somewhere inside.
You know, like the swivel bases you get for gps unit's windscreen mounts, or something like a "bracketron" system, which basically attached to the back of the keyboard, and the inside wall of the enclosure in an L-sahped.
am just bouncing stuff which i had thought about.
a lot of retrofit will have to be done, i presume, but nothing majorly technical.
more on getting it to be mounted in place.
Old 23rd June 2011, 11:05   #30
gotzuk's Avatar
Thanked: 69 Times
It wouldn't really be possible to type on the keyboard in that position. I Tried
Plus the swivel mounts take up a lot of space which I am already short of.
Performance Chips Dovin Modifications & Accessories 26 17th October 2015 06:49
Fozzie gets new ICE! gotzuk In-Car Entertainment 18 17th November 2011 23:13
About chips and mods tsk1979 Technical Stuff 31 14th July 2005 13:51
chips for City vtec and exi speedsatya Modifications & Accessories 4 16th March 2005 15:57
