Old 2nd June 2011, 11:20   #1
Thanked: 161 Times
Default Whats wrong with this Sub setup
Hi Folks
Was watching this Youtube video on a demo of a sub.
If you see as long as the video is from outside the car the sub sounds fine and the beats sound good, but the moment the camera enters the car, the sub goes for a toss your hear the additional buurrrrr sound
So is this is a problem with the recording microphone, Sub setup or what ?
jinu_joseph is offline   Reply With Quote
Old 2nd June 2011, 11:34   #2
Pr_007's Avatar
Thanked: 9 Times
Default Re: Whats wrong with this Sub setup
This is not an issue with the recording microphone or the sub setup. When the microphone was outside it was recording only the sound that comes, when the mic goes into the car, it also vibrates with the air that is pushed by the subwoofer.
That is the reason, I am not able to put in correct words, Guru's can...
Pr_007 is offline   Reply With Quote
Old 2nd June 2011, 11:48   #3
Thanked: 161 Times
So does that mean that if i was sitting in the car i would hear sound like that in the video. Thats bad isnt it ?
Old 2nd June 2011, 14:12   #4
DerAlte's Avatar
Thanked: 2,879 Times
What setup are you hearing the audio of the video track on? Outside the car, the level of bass recorded would be much less that inside the car. The setup that you are hearing the recording through is being made to reproduce the higher level and not being able to handle it.
For example, a laptop built-in amp and speakers are not at all meant to handle that, and will distort heavily - giving out the brrr-brrr sound. On a desktop PC with a good pair of amplified speakers, the onset of distortion will be at a higher level, but distort it will for some passages where the bass peaks are very high.
Old 2nd June 2011, 15:16   #5
Thanked: 161 Times
Oh so you are saying the problem is with the audio setup i am listening on in my computer.. Ok but not sure since I have the Klipsch Promedia GMX 2.1. Are you also facing the same distortion when you see the video ?
Whats wrong with my Corolla's Clutch and Engine? novice Technical Stuff 16 18th August 2014 21:27
Whats wrong with the suspension? tsk1979 Technical Stuff 9 18th September 2007 13:27
Whats wrong with this K&N conical filter assembly rishibravo Modifications & Accessories 25 18th April 2007 18:48
no idea whats wrong gamerno1 Technical Stuff 22 3rd April 2005 02:38
whats wrong with the emoticons?? _Crazi4Speed_ Shifting gears 2 23rd June 2004 12:29
