Old 21st February 2006, 12:13   #31
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Originally Posted by navin
Geez. Guys. If it aint broken dont fix it. Just becuase you got a solution dont go looking for a problem.
Lesson: If the bass peaks are clean let the amps be.
You guys seem to have found a hammer and are now everything looks like a nail!
P.S. This is the abridged version. Longer explantions are found on audio forums.
very well explained .. Lol , navin seems like ur high on NOS these days ..
Old 21st February 2006, 12:19   #32
navin's Avatar
Thanked: 4,286 Times
which NOS? New Old Stock?
McLaren if you hiding some NOS RCA or Mullard 6550s I want them. Willing to pay Rs. 1K each.
Old 21st February 2006, 12:37   #33
Thanked: 35 Times
i meant Nitrous Oxide navin (*wakey wakey* laughing gas ???).. Bcoz u really are sounding very funny these days .. Seems u have taken over the reigns of making us laugh since sams absence .. Im loving it !!!
Old 21st February 2006, 13:41   #34
navin's Avatar
not much of my post #28 was said in jest. I rarely joke about audio.
wonder what you found funny mclaren?
Old 21st February 2006, 13:57   #35
Thanked: 35 Times
HHMM .. I meant the highlighted quotes in ur post , the hiring tree wala and many others.. We are seriously going OT here ..
Old 22nd February 2006, 02:08   #36
Buzzin_hornets,
Like Navin said first listen to your system. If you think the bass is more of a bhok-bhok rather than a thump-thump kind consider putting in a cap. You may actually never need a cap. We have seen so many systems with two amps and with the works which work well without caps. Something like the eyeballer is different.
Vivekphadnis is offline   Reply With Quote
Old 22nd February 2006, 19:26   #37
rsjaurr's Avatar
Thanked: 27 Times
I guess i may need capacitor in future.I have not driven my car since my FIL left india on 4th.
So when i play some music,with engine on though,the cabin light does flicker a bit on medium to high volume and also i can feel spk producing low volume than when i am running my car.
Amp also gets bit warm after 20-30 min.Probably my subw in sealed box is drawing too much power from amp.
rsjaurr is offline   Reply With Quote
Old 23rd February 2006, 09:37   #38
navin's Avatar
if the sub is 2 ohms it might be drawing too much from the amp. car amps can be run to 4 ohms and even 2 ohms but most are happier being run to 4 ohms.
if your sub is demanding too much power from your amp and your amp in turn is demanding too much from the battery you can have a problem. a cap might solve it but a small 2 ch amp might work just as well.
I notice the second amp works better in installs where 4 speakers and the sub are being run off a single 4 ch amp.
Old 23rd February 2006, 18:01   #39
Autophile's Avatar
RSJ take care of your amplifier..hope it does not burn before i come there. So play nice
Autophile is offline   Reply With Quote
Old 23rd February 2006, 19:19   #40
rsjaurr's Avatar
Thanked: 27 Times
My subw is 4 ohms and SVC.
All Door spk r 2 ohms.
Amp doesn't get hot but onoly bit warm after 20min continous with medium [15-22] volume.Maximum limit is 35.
i'm waiting for u guys.
Old 24th February 2006, 09:42   #41
navin's Avatar
2 ohms for fullrange speaker - i've seen these but never liked the idea. some amps balk at that load. there are few amps designed to run 2 ohms easily.
Old 24th February 2006, 11:49   #42
Sam Kapasi's Avatar
Thanked: 1,473 Times
2 ohms is harman's direction Navin... soon for all car audio from Infinity and JBL. I have a white paper on this. How do i send it to you? PM me your email addy
Old 24th February 2006, 12:23   #43
Thanked: 23 Times
Am curious too. Anythin brief u can share with us Sammie or it is classified info. Any distinct advantage in the 2 Ohm direction?!
muni is offline   Reply With Quote
Old 24th February 2006, 13:22   #44
navin's Avatar
the only advnatage is that a voltage amp can dump more current and deliver higher watts.
Old 24th February 2006, 17:45   #45
Thanked: 23 Times
Certainly not ur cup of T
Capacitor? Need to stabilize voltage Ford Rocam Technical Stuff 38 7th May 2014 14:28
Power capacitor, anyone? clevermax In-Car Entertainment 5 29th March 2008 00:04
Is it better to add a Capacitor or a Secondary battery? j_j In-Car Entertainment 7 3rd August 2007 17:22
Need Help With Car Audio Capacitor passion4cars In-Car Entertainment 10 4th July 2006 10:40
how to decide capacitor?? amit_sound In-Car Entertainment 2 28th June 2006 12:24
