Old 12th March 2008, 18:38   #31
BomBatt's Avatar
Thanked: 11 Times
Originally Posted by Sam Kapasi View Post
Main zara bhagwan ko private message bhejta hoon.... hmmm... to see if he wakes up.
Seems like finally BHAGWAN wakes up exactly after 2 years !!
BomBatt is offline   Reply With Quote
Old 12th March 2008, 19:19   #32
BHAGWAN's Avatar
Thanked: 13 Times
Talking This was put here by the Moderator
Hi !
Yes, it does look strange;
As if I woke up after 2 years.
However, that Swift was installed 3 times over.
Soundstream Amps
MTX Amps
Audiobahn Amps
Stag Amps
Lots of changes & component changes & position alterations.
However, I actually posted these pictures of the alloys on another thread since some one wanted to see the rims.
The Moderator moved the thread here.
I should actually take pictures of the entire install & put them here. Should be interesting. The car sounds OK - not bad.
What I have finally used is :-
MB Quart - Q Line - Front
Illusion Audio - Carbon - Rear
Illusion Audio - Carbon - ND 12's - 02 pcs in a 'custom' sealed enclosure
02 Steg Power Amps - Fronts + Subs
01 Audiobahn Power Amp - Rears
Alpine HU - 9855 [I think]
Optima - Yellow top battery
Monster - Top of the line RCA Interconnect Cables [forget the model]
Power Cords are Kicker & so is the Power Distribution Block etc.
cheers:
This install is complete - I think !!
BHAGWAN is offline   Reply With Quote
Old 12th March 2008, 19:37   #33
Technocrat's Avatar
Thanked: 2,589 Times
I agree please post complete install pics
Old 18th March 2008, 09:44   #34
moralfibre's Avatar
Thanked: 6,533 Times
I happened to take a picture of your car once. Those alloys look killer. Could you please post images of your install if you have documented this one?
Old 19th March 2008, 14:51   #35
BHAGWAN's Avatar
Thanked: 13 Times
Arrow I shall do it next week !
I will get that done - next week.
Will be travelling until Monday;
Hence will do it upon my return.
Old 19th March 2008, 14:56   #36
Technocrat's Avatar
We shall be waiting
Need an Audio system for Swift - Budget 30-35k zerocritical In-Car Entertainment 13 7th August 2010 22:53
Need advice: options for specific needs and budget sonic In-Car Entertainment 10 6th June 2008 15:52
Yoko es 100 woes, need a new set naman Tyre & Alloy wheel Section 36 7th March 2008 14:45
