Old 24th July 2011, 23:14   #1
Thanked: 13 Times
Default Alpine 117 vs Pioneer P80rs2
this is for SPL/SQL setup.
i have already have rainbow germaniums and genesis profile 3 dual mono.
now need to choose HU for my stage 1.
planing for really good mono(1000-1500rms) and 2 subs in future.
damn confused for HU.
if i go for pioneer i will also get usb adapter because i use only USB.
please suggest need to buy HU as soon as possible.now cant see my amp and compos lying on my bed...
procircuit_234 is offline   Reply With Quote
Old 25th July 2011, 01:50   #2
Default Re: alpine 117 VS pioneer P80rs2
I would suggest you go for the Pioneer because you would have great tuning capabilities built within. To get the same from Alpine you would have to spend extra in an Imprint Kit. Moreover buy a Ipod cable for pioneer because that works much better than USB.
Piyush_Vroom is offline   Reply With Quote
Old 25th July 2011, 08:35   #3
greenhorn's Avatar
Thanked: 1,516 Times
we've had this battle before with their predecessors
http://www.team-bhp.com/forum/produc...neer-p880.html
Old 25th July 2011, 09:06   #4
SumitBahl's Avatar
Thanked: 219 Times
I am in the same boat as you.
I do not use TA and not bothered about the bluetooth that much, so I can save on the imprint kit.
Although, I have heard that USB stick does not work perfectly through the adapter on P80, it owuld not display the full filenames (5 chars is the limit, i think).
Its better to go for an iPod.
BTW, what are the prices you have been offered on both of them?
Most of the people are going to suggest P80 to you.
I really like P80, but I want a 117 for its native USB support.
SumitBahl is offline   Reply With Quote
Old 25th July 2011, 23:17   #5
Thanked: 13 Times
Default Re: Alpine 117 vs Pioneer P80rs2
i liked pioneer look wise.but my only concern is will usb adapter work fine with p80?doest matter even it shows only 5characters.anything else to worry about?no i dont use i pod also.
Old 26th July 2011, 10:23   #6
sathee46's Avatar
If you are going to use USB most times, the 117 makes sense. The USB adapter in P80 wont be great.
sathee46 is offline   Reply With Quote
Old 26th July 2011, 12:34   #7
Thanked: 294 Times
It show 8 characters and then scrolling starts with a touch of a button. But the interface is a pain and slow. But I have used the p80 with IPOD and I loved the interface. Very good. Highly recommend.
Also before buying listen to both the heads do not go buy recommendations here on the forum. The person owning the head will always say it is better. It is better you trust your ears rather than others advice !!!
low_bass_makker is offline   (2) Thanks Reply With Quote
Old 26th July 2011, 14:21   #8
abhibh's Avatar
Thanked: 34 Times
117 makes sense if you are going to use USB and not iPod. If you have an iPod and plan to buy iPod Adapter for P80 then you can go for P80 too.
Both the HU's will do just fine and are equally good.
Old 26th July 2011, 19:51   #9
Thanked: 13 Times
thanx lbm.its really difficult to audition both HUs here in mumbai.in fact P80rs2 is nt easily available.i liked P80 lookwise and hated 117 lookwise but still looks are secondary to me.wat to do???
Old 27th July 2011, 10:03   #10
sathee46's Avatar
Forgot to mention that the 117 does not use USB like most HU's, it uses a method called banking. The "Banking" will be a problem if you plan to use high capacity USB drives. IMO the HU is great with the Ipod.
Why dont you look at other options?
Old 27th July 2011, 11:09   #11
Thanked: 294 Times
I have not tried the alpine 117. So cannot coment further on the same. But if you go with Pioneer you will be happy. As many on this forum replaced there 9887 with a P80 soon or latter !!!
Old 27th July 2011, 15:02   #12
laxmanrk's Avatar
Thanked: 79 Times
Dear pro
I have the DEH-P88RS, it is the european spec version of the p80.
Currently it is playing in my dad's octavia with a cd-ub100 (usb adapter)
Works flawlessly, absolutely no complaints on SQ or even the operation of the unit. It has a very simple interface for tuning. Even a beginner will feel at home depending on his understanding of the operations.
Also it works for my dad at this level. Since he just connects a pen-drive with loads of his ghazals or old hindi songs.
Another neat trick this HU has up its sleeve is that the audio settings and yout TA settings remain on the HU for a considerable time even after you disconnect it from the battery. Although saved radio stations and some setting will be lost.
My cribs are as follows:
1) No inherent support for USB. You will need the USB adapter - CD-UB100.
2) The USB adapter does not read wav/ flac or any lossless formats. It reads only mp3s/ wma and limited files. But the HU will read cds consisting of wav files, even made by you.
3) The aux input is located to the rear. I have routed a wire from the same to the glove box.
4) The USB adapter does not display full text info of the files.
5) The USB adapter will accept only FAT format. NTFS will not be read.
If your primary source is going to be USB and you are able to stretch your budget then look at the P99rs. People actross the globe have been going ga ga over it. It reads wav files off USB drives and supports ipods also inherently.
I had auditioned a 117 quite sometime ago and found it too coloured for my liking. Although as LBM sir has mentioned elsewhere, tuning both these will yield you similar results.
That's my 2 cents mate. Hope your dilemma is cleared soon and you find a suitable HU.
Do post your review of the selected product.
PS: Forgot to mention, you can add a steering mounted remote (IR) and it works superbly. Must have party trick @ around 1~1.5k.
laxmanrk is offline   (1) Thanks Reply With Quote
Old 27th July 2011, 21:59   #13
Thanked: 13 Times
what other options i have?budget is like 20-30k max.was thinking about kenny 7016.but its lean on bass and i think these two are better options.i just want USB and detachable faceplate.
Old 28th July 2011, 00:02   #14
SumitBahl's Avatar
Thanked: 219 Times
Hi
Could you please elaborate on the 117. How does it compare to P80RSII?
Old 29th July 2011, 23:10   #15
Thanked: 13 Times
should i consider alpine IDA-305S??or anything from eclipse??
117 Royal Enfields, 140+ people. 1 Thump. Royal Riders 2nd Anniversary Ride h@r$h@l Motorbikes 5 8th February 2012 12:34
Team-BHP's first Alpine 117 sathee46 In-Car Entertainment 32 31st August 2011 18:00
Please Advise: Alpine CDA 117 vs Kenwood X8016BT Ishlesh In-Car Entertainment 15 1st July 2011 19:05
Bought an Alpine m500 and Type R sub, need advice on an all Alpine SQL setup. Astleviz In-Car Entertainment 1 23rd October 2010 23:46
The new Alpine CDA-117 SPARKled In-Car Entertainment 3 22nd January 2010 12:44
