Old 14th August 2011, 16:18   #1
Thanked: 54 Times
Default My Alto's Audio System!
Got my car delivered about 2 months back and I haven't had the time to ICE it up . Basically the car bought for school errands and i had no intention for using it otherwise .
My other car was given for service and I had no other option but to use the alto for my use and I found it boring to drive without music .
My search started 2 weeks back and looking at the HU , my options were that pre -out was necessary . The cd was not essential as after a couple of uses I found skipping and pot holes unavoidable .
Zeroed on a Sony DSX-100 as it was very cheap , decent build quality can be expected from sony and other similar models from different brands were not avaliable .
The Alto can accomodate only 4 inch speakers and I did not want to mount the speakers on the doors , so I had only 2 options
1. illusion audio comps
2. JBL coaxials
I mentioned only 2 options because I ruled out sony , and most of the brands did not have a coaxial speakers ..
The illusion audio coax were not avaliable and I am not really a patient person when it comes to waiting for something . Finalised on the JBL coaxials .
I had a pio d991s speakers which i bought about 3 years back and never used it , so thought i would use it for the rears .
The installation was done and the first thing I noticed was that the setup was very harsh sounding . It was not my taste and I knew that I had to get an amplifier to power the speakers . Before that I decided to do some tinkering with the speakers to reduce the harshness and I started out with the front coaxials .
The front coaxials were JBL models and the tweeter was crossed with a 3.3Uf cap . The cap was a bipolar electrolytic type and this had to go . So I got 1uf polyester cap and tried it , but the tweeter was too soft for my liking , so I finally zeroed on a 2uf for each tweeter . The tweeter is now much more smoother and the harshness is gone , but it still retains the brightness .
The rear pio speakers proved to be too powerful for the fronts and on top of that the music outside the car was much more than inside . So finally decided to remove the rear speakers and now I getting a custom enclosure for the rear speakers . I have zeroed on the 5.1/4 inch speakers for the rears .
Another mod was that i got a 10,000 uf cap for the powersupply and 4,700uf cap for the ignition . The HU does not flicker when the volume is pushed to its max .
Will post the pics if any of you are interested .
Old 14th August 2011, 20:56   #2
DerAlte's Avatar
Thanked: 2,879 Times
Default Re: Alto ICE
Do post pictures!
1. Did you do the installation yourself or did you get it done?
2. You have used a 10,000 uF cap in a setup without an amplifier or a woofer!?! Any specific reason? No one does that for such setups - no harm, but it doesn't do anything beneficial either
3. What is the 4,700 uF cap for the 'ignition'? Where in the ignition circuit?
Old 14th August 2011, 22:39   #3
sajjt's Avatar
Thanked: 97 Times
Originally Posted by DerAlte
Do post pictures!
Sir I guess he meant to say the power cut off during cranking the engine. But like you rightly said I still dont know the benefit of 10000uf cap across the power supply. Is it because of the power supply the HU is blinking at higher volume levels? I dont think so. Is it something related to clipping?
sajjt is offline   Reply With Quote
Old 15th August 2011, 11:06   #4
Thanked: 54 Times
The 10,000uf gives a beefier power supply to the HU , maintains a steady voltage on the line and when the volume is cranked up the voltage does not dip . The HU sounds much much better with this cap .
The 4700uf for the ignition is to keep the voltage when the car stalls in traffic . Normally when the car stalls the HU switches off during cranking and this is avoided .
Old 15th August 2011, 11:10   #5
Thanked: 54 Times
Originally Posted by DerAlte View Post
Do post pictures!
I stopped DIY when i found that i was wasting too much of time with too less of return . I had taken the car to an installer , but practically I did the installation.
The benefit is there .. my Hu sounds cleaner and better . plus I do not lose anything when i am spending just Rs.100 .
When the key is switched on , the wire that powers the HU from its standby mode is the ign circuit .
Old 15th August 2011, 11:14   #6
Thanked: 54 Times
clipping is when the amplifier runs out of breath and distorts .Clipping happens typically when the amplifier section in the HU is driven to its max ( max volume) . The blinking of the HU is basically when the HU needs "extra" juice to drive the woofers and the caps in the Hu are not enough .
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! Sam Kapasi In-Car Entertainment 13667 19th July 2018 16:52
BlueTooth Car Audio System + Security System venky6009 In-Car Entertainment 1 2nd November 2007 04:45
Car Audio System for ALTO Budget Rs 20,000 sandekumar In-Car Entertainment 19 28th August 2006 16:06
Pioneer Audio system - My choice for Alto mail4ajo In-Car Entertainment 72 27th July 2006 06:40
