Old 3rd September 2011, 23:58   #1
sj_koova's Avatar
Thanked: 176 Times
Default STAGE - II ICE upgrade :: Rear Speakers and Sub
Hello Gurus,
I have already done the STAGE-1 with minor upgrades. Here is what I have at present,
Amp - JBL GTO 1004
Front Components - Infinity Kappa 60.9
HU - JBL X333
Rear - CEDIA stock speakers powered by HU
Sub - none
2 channels from the amp are already used for front components. Original plan was to bridge the other 2 channels for the Sub and run the rear speakers directly from HU.
Change in plan and now I am looking for an upgrade for the rear speakers and sub. If I have to attach new rear speakers to GTO 1004, I will need to add another monoblock for the sub.
Considering all these, I am keeping a budget of around 25k-35k.
80% of the time I listen to Hindi music. The rest goes to FM and other regional songs.
My preference is more for a crisp and balanced sound.
Looking for suggestions on,
1. rear coax speakers (6.5") - will be attached to GTO 1004
2. 12" sub (preferably detachable)
3. Monoblock amp
sj_koova is offline   Reply With Quote
Old 4th September 2011, 00:12   #2
vigsom's Avatar
Thanked: 607 Times
Default Re: STAGE - II ICE upgarde :: Rear Speakers and Sub
Does the Cedia provide for ovals in the rear?I believe you should get a pair of ovals and not 6.5".
Old 4th September 2011, 16:19   #3
sj_koova's Avatar
Thanked: 176 Times
Rear is round in CEDIA. Any reason you suggested oval?
Old 5th September 2011, 00:55   #4
vigsom's Avatar
Thanked: 607 Times
^^ just that ovals work better in a boot,especially in the absence of a sub since the cone area is larger ; so more air displacement
In your case,6.5" coaxes off the amp and a 12" sub off a mono should work well ;
You can check out the new JBL BassPro12(which I believe is an amp +sub in one)
Old 5th September 2011, 01:19   #5
shuvc's Avatar
Thanked: 287 Times
I would not buy a monoblock. Save the cash. And use it to damp the front doors if not already done.
Step 1.
- Damp front doors.
- Bridge the remaining two channels of the 1004 (280W?) to drive the sub.
- Drive the new rear speakers directly from the HU.
Hear how this setup sounds to you.
If dissatisfied
Step 2:
- Get a basic 2 channel amp (60W-70W) to drive the rears.
Old 5th September 2011, 10:38   #6
sj_koova's Avatar
Thanked: 176 Times
Step 1.
- Damp front doors.
If dissatisfied
Step 2:
Thanks shuvc. This kind of makes sense to me too. I can do it in stages. I would rather go with Sub on 1004 as of now.
Do you have any suggestions on Sub?
Also the rear speakers?.
Old 5th September 2011, 13:05   #7
shuvc's Avatar
Thanked: 287 Times
I'm not too clued into the current products. You could however JBL'fy your ride !
I use an earlier version of this sub in one car. It's entry level but good VFM. The 1004 will also supply enough juice to it.
JBL CS 1215
And JBL rears too.
JBL GT6-S366
These + damping + a 2 channel (if you want too) should cost you less than 20K !
Skoda Octavia VRS - Should I go for the stage 2 upgrade? crdhanak Modifications & Accessories 15 8th September 2011 14:05
ICE Upgrades for Verna SX - Budget 15K, Amp, Speakers and Sub newcoolgadgets In-Car Entertainment 3 21st September 2009 16:04
Getz ICE upgrade - Alpine HU, IDQ sub and Eclipse mono PatienceWins In-Car Entertainment 29 23rd August 2008 20:59
second stage upgrade in illusioned swift gandolf_thewise In-Car Entertainment 4 7th July 2008 17:56
How to differentiate between Genuine and Fake Amp Speakers Sub etc ST7677 In-Car Entertainment 10 24th August 2006 12:52
