Old 6th December 2011, 13:23   #16
gauravdgr8's Avatar
Thanked: 372 Times
Default Re: Tata Manza - ICE'd
Originally Posted by skumare View Post
Having upgraded the stock speakers ONLY in my Vista VX (I presume the HU is the same as Manza), I can say it does make a difference. My upgrade was constrained a bit as Vista could accommodate only 5" speakers. I went with JBL 5" coaxials for lack of options in 5" components, or do we have any?. If Manza has 6" slots, you could go for components in the front and coaxials in the back. This may up the quality to around 80%, you should do this first and then take a call on the HU based on your listening preferences.
Hey buddy. I too have bought a Vista VX. Need to discuss about the HU setup changes. I am also in Hyderabad. Could you PM me your contact.
gauravdgr8 is offline   Reply With Quote
Old 6th December 2011, 14:38   #17
skumare's Avatar
Thanked: 29 Times
Noob here :-) Pls PM me your contacts and I will get in touch.
skumare is offline   Reply With Quote
Old 6th December 2011, 18:31   #18
BeantownThinker's Avatar
Thanked: 232 Times
... you should do this first and then take a call on the HU based on your listening preferences.
For me to change the head unit it would have to be compatible with the steering mounted controls. Have got so used to them.
But am pretty much satisfied with the Hu.
With regard to the amp, there are a lot of amps that take a high level input so would not really need a converter. Still searching for them. Will look at other amps only if my options work out to be expensive.
BeantownThinker is offline   Reply With Quote
Old 28th August 2012, 01:09   #19
rki2007's Avatar
Thanked: 139 Times
Hi i am actually planning to upgrade to better quality music experience for my Manza. I am currently using the company fiitted stuffs without any upgradation. Please tell me whether adding front speakers and tweeters will suffice or the whole head unit is a better option. Also suggest the best brands with approx price.
rki2007 is offline   Reply With Quote
Old 28th August 2012, 10:54   #20
Sridhar K's Avatar
Thanked: 192 Times
Thumbs up Re: Tata Manza - ICE'd
It all depends on your budget. You can scrap the speakers, HU and go for a completely new ICE for the best sound quality. However, you can try the incremental upgrades step by step (if you are not satisfied with the output).
1) Upgrade the front components alone with hertz DSK165 or JBL 265c or Helix blue
2) add an 4 channel amp that can take high level inputs like Hertz HE4 or Focal Solid 4 or Blau Velocity.
3) Then add a mid bass or a 3 way at the rear with front comps and the rear being powered of the amp or alternatively,
4) Add a sub and power the sub and the front comps from the amp and leave the rear coax as is.
5) Still not satisfied - replace the HU with the PAC converter to retain the steering control.
I did #4 and was reasonably satisfied and moved the same (comps, sub and amps) to my new Swift.
Sridhar K is offline   Reply With Quote
Old 9th December 2012, 23:30   #21
rki2007's Avatar
Thanked: 139 Times
I am very happy with the above reply but believe me for a person like me who is very much ignorant all these things become difficult to understand. I want to retain the Music system ie.., the head unit. Also the rear speakers are quiet ok .Now if i have to improve the quality and clarity of sound, should i just insert speakers on the front doors or is there anything else to be done including replacement of rear speakers with a better quality one.
A story of 3 workhorses: 2 Santro's and a Manza, Edit: Santro sold, Manza at 100k+ amit1234singla Long-Term Ownership Reviews 115 10th August 2014 21:53
Tata Manza Club Class! Climate Control, Leather Seats, Touchscreen ICE and more parrys The Indian Car Scene 102 4th February 2013 09:20
Problem with my Manza ICE tajender In-Car Entertainment 11 24th November 2012 17:48
Tata Manza Recall : Tata to replace anti-roll bar bush Turbo_Charger Technical Stuff 6 5th April 2012 11:21
New Tata Indigo Manza Details : Brochure on Page 36 EDIT : Now launched sidindica The Indian Car Scene 689 15th October 2009 16:37
